Всем доброго времени суток.
Может кто-нибудь подсказать,где взять иформацию по протоколу C-Bus (не путать с CBus).
Все что удалось найти в сети:
http://www.cbus-enabled.com/cbus-open-c-ccode.htm
The source code for an interface or driver for C-Bus can be provided to simplify the development of applications controlling C-Bus. The files consist of over 9,000 lines of ANSI C code, called the "C-Bus Modules" which provide :
Functions to send messages onto C-Bus.
Call-back functions to provide notification of C-Bus events.
Customisation features (compile directives) to match the C-Bus Module features to your requirements.
Modelling of C-Bus Network Variables, and functions to access them.
The C-Bus Modules implement the full C-Bus Protocol, including the following C-Bus Applications :
Lighting
Security
Telephony
Trigger Control
Enable Control
Measurement
Access Control
Time
Network Discovery
The C-Bus Modules can be used with virtually any processor, as long as an ANSI C compiler is available. If you have an x86 family processor, you should consider using the C-Bus Windows and Linux Drivers or C-Gate.
The C-Bus Modules are only available to partners under the C-Bus Enabled Program.
To obtain more information, contact the C-Bus Enabled Program Coordinator.
