---- UNKNOWN_FILE ---------------------------------------------------------------------------------
0: File not found
+00000000: C012 RJMP PC+0x0013 Relative jump
+00000001: C021 RJMP PC+0x0022 Relative jump
+00000002: C020 RJMP PC+0x0021 Relative jump
+00000003: C01F RJMP PC+0x0020 Relative jump
+00000004: C01E RJMP PC+0x001F Relative jump
+00000005: C01D RJMP PC+0x001E Relative jump
+00000006: C01C RJMP PC+0x001D Relative jump
+00000007: C01B RJMP PC+0x001C Relative jump
+00000008: C01A RJMP PC+0x001B Relative jump
+00000009: C01A RJMP PC+0x001B Relative jump
+0000000A: C018 RJMP PC+0x0019 Relative jump
+0000000B: C017 RJMP PC+0x0018 Relative jump
+0000000C: C016 RJMP PC+0x0017 Relative jump
+0000000D: C015 RJMP PC+0x0016 Relative jump
+0000000E: C014 RJMP PC+0x0015 Relative jump
+0000000F: C013 RJMP PC+0x0014 Relative jump
+00000010: C012 RJMP PC+0x0013 Relative jump
+00000011: C011 RJMP PC+0x0012 Relative jump
+00000012: C010 RJMP PC+0x0011 Relative jump
+00000013: 2411 CLR R1 Clear Register
+00000014: BE1F OUT 0x3F,R1 Out to I/O location
+00000015: E5CF LDI R28,0x5F Load immediate
+00000016: E0D4 LDI R29,0x04 Load immediate
+00000017: BFDE OUT 0x3E,R29 Out to I/O location
+00000018: BFCD OUT 0x3D,R28 Out to I/O location
+00000019: E010 LDI R17,0x00 Load immediate
+0000001A: E6A0 LDI R26,0x60 Load immediate
+0000001B: E0B0 LDI R27,0x00 Load immediate
+0000001C: C001 RJMP PC+0x0002 Relative jump
+0000001D: 921D ST X+,R1 Store indirect and postincrement
+0000001E: 36A2 CPI R26,0x62 Compare with immediate
+0000001F: 07B1 CPC R27,R17 Compare with carry
+00000020: F7E1 BRNE PC-0x03 Branch if not equal
+00000021: D02E RCALL PC+0x002F Relative call subroutine
+00000022: C048 RJMP PC+0x0049 Relative jump
+00000023: CFDC RJMP PC-0x0023 Relative jump
@00000024: __vector_9
---- main.c ---------------------------------------------------------------------------------------
13: {
+00000024: 921F PUSH R1 Push register on stack
+00000025: 920F PUSH R0 Push register on stack
+00000026: B60F IN R0,0x3F In from I/O location
+00000027: 920F PUSH R0 Push register on stack
+00000028: 2411 CLR R1 Clear Register
+00000029: 938F PUSH R24 Push register on stack
14: TCNT0 = 0xc1; // 1ms for 4MHz & prescaller = 64
+0000002A: EC81 LDI R24,0xC1 Load immediate
+0000002B: BF82 OUT 0x32,R24 Out to I/O location
15: if(couScanKeys)
+0000002C: 91800060 LDS R24,0x0060 Load direct from data space
+0000002E: 2388 TST R24 Test for Zero or Minus
+0000002F: F021 BREQ PC+0x05 Branch if equal
16: couScanKeys--;
+00000030: 5081 SUBI R24,0x01 Subtract immediate
+00000031: 93800060 STS 0x0060,R24 Store direct to data space
+00000033: C006 RJMP PC+0x0007 Relative jump
19: couScanKeys = 100; // t = 0.1 s
+00000034: E684 LDI R24,0x64 Load immediate
+00000035: 93800060 STS 0x0060,R24 Store direct to data space
20: fScanKey = 1;
+00000037: E081 LDI R24,0x01 Load immediate
+00000038: 93800061 STS 0x0061,R24 Store direct to data space
22: }
+0000003A: 918F POP R24 Pop register from stack
+0000003B: 900F POP R0 Pop register from stack
+0000003C: BE0F OUT 0x3F,R0 Out to I/O location
+0000003D: 900F POP R0 Pop register from stack
+0000003E: 901F POP R1 Pop register from stack
+0000003F: 9518 RETI Interrupt return
@00000040: initProc
27: TIMSK = (1‹‹TOIE0); // ðàçðåøàþ ïðåðûâàíèå ïî ïåðåïîëíåíèþ Ò0
+00000040: E081 LDI R24,0x01 Load immediate
+00000041: BF89 OUT 0x39,R24 Out to I/O location
28: TCNT0 = 0xc1; //(0x82 - 2 ms) (0xc1 - 1ms)
+00000042: EC81 LDI R24,0xC1 Load immediate
+00000043: BF82 OUT 0x32,R24 Out to I/O location
29: TCCR0 = (1‹‹CS01)|(1‹‹CS00); // âêëþ÷àþ Ò0 ñ ïðåñêàëëåðîì 64
+00000044: E083 LDI R24,0x03 Load immediate
+00000045: BF83 OUT 0x33,R24 Out to I/O location
31: DDRB = 0xff; // out
+00000046: EF8F SER R24 Set Register
+00000047: BB87 OUT 0x17,R24 Out to I/O location
32: DDRB &= ~(1‹‹0); // in
+00000048: 98B8 CBI 0x17,0 Clear bit in I/O register
33: DDRD = 0; // in
+00000049: BA11 OUT 0x11,R1 Out to I/O location
34: asm("sei");
+0000004A: 9478 SEI Global Interrupt Enable
35: }
+0000004B: 9508 RET Subroutine return
@0000004C: initVars
39: couScanKeys = 100;
+0000004C: E684 LDI R24,0x64 Load immediate
+0000004D: 93800060 STS 0x0060,R24 Store direct to data space
40: }
+0000004F: 9508 RET Subroutine return
@00000050: main
43: initProc();
+00000050: DFEF RCALL PC-0x0010 Relative call subroutine
44: initVars();
+00000051: DFFA RCALL PC-0x0005 Relative call subroutine
51: if(!(PIND & (1‹‹7)))PORTB ^= 1‹‹5;//left
+00000052: E290 LDI R25,0x20 Load immediate
52: if(!(PIND & (1‹‹6)))PORTB ^= 1‹‹3;//right
+00000053: E028 LDI R18,0x08 Load immediate
48: if(fScanKey)
+00000054: 91800061 LDS R24,0x0061 Load direct from data space
+00000056: 2388 TST R24 Test for Zero or Minus
+00000057: F091 BREQ PC+0x13 Branch if equal
50: fScanKey = 0;
+00000058: 92100061 STS 0x0061,R1 Store direct to data space
+0000005A: 9987 SBIC 0x10,7 Skip if bit in I/O register cleared
+0000005B: C003 RJMP PC+0x0004 Relative jump
+0000005C: B388 IN R24,0x18 In from I/O location
+0000005D: 2789 EOR R24,R25 Exclusive OR
+0000005E: BB88 OUT 0x18,R24 Out to I/O location
+0000005F: 9986 SBIC 0x10,6 Skip if bit in I/O register cleared
+00000060: C003 RJMP PC+0x0004 Relative jump
+00000061: B388 IN R24,0x18 In from I/O location
+00000062: 2782 EOR R24,R18 Exclusive OR
+00000063: BB88 OUT 0x18,R24 Out to I/O location
53: if(!(PINB & (1‹‹0)))PORTB |= 1‹‹4;//up
+00000064: 9BB0 SBIS 0x16,0 Skip if bit in I/O register set
+00000065: 9AC4 SBI 0x18,4 Set bit in I/O register
54: if(!(PIND & (1‹‹5)))PORTB &= ~(1‹‹4);//down
+00000066: 9985 SBIC 0x10,5 Skip if bit in I/O register cleared
+00000067: CFEC RJMP PC-0x0013 Relative jump
+00000068: 98C4 CBI 0x18,4 Clear bit in I/O register
+00000069: CFEA RJMP PC-0x0015 Relative jump
+0000006A: CFFF RJMP PC-0x0000 Relative jump
+0000006B: 94F8 CLI Global Interrupt Disable
+0000006C: CFFF RJMP PC-0x0000 Relative jump
+0000006D: CFFF RJMP PC-0x0000 Relative jump
+0000006E: E0FF LDI R31,0x0F Load immediate
+0000006F: 01F9 MOVW R30,R18 Copy register pair
+00000070: 8120 LDD R18,Z+0 Load indirect with displacement
+00000071: 7F2E ANDI R18,0xFE Logical AND with immediate
+00000072: 01FC MOVW R30,R24 Copy register pair
+00000073: 8320 STD Z+0,R18 Store indirect with displacement
+00000074: E381 LDI R24,0x31 Load immediate
+00000075: E090 LDI R25,0x00 Load immediate
+00000076: 01FC MOVW R30,R24 Copy register pair
+00000077: 8210 STD Z+0,R1 Store indirect with displacement
+00000078: 9478 SEI Global Interrupt Enable
+00000079: 91CF POP R28 Pop register from stack
+0000007A: 91DF POP R29 Pop register from stack
+0000007B: 9508 RET Subroutine return
+0000007C: 93DF PUSH R29 Push register on stack
+0000007D: 93CF PUSH R28 Push register on stack
+0000007E: B7CD IN R28,0x3D In from I/O location
+0000007F: B7DE IN R29,0x3E In from I/O location
+00000080: E684 LDI R24,0x64 Load immediate
+00000081: 93800060 STS 0x0060,R24 Store direct to data space
+00000083: 91CF POP R28 Pop register from stack
+00000084: 91DF POP R29 Pop register from stack
+00000085: 9508 RET Subroutine return
+00000086: 93DF PUSH R29 Push register on stack
+00000087: 93CF PUSH R28 Push register on stack
+00000088: B7CD IN R28,0x3D In from I/O location
+00000089: B7DE IN R29,0x3E In from I/O location
+0000008A: DFC8 RCALL PC-0x0037 Relative call subroutine
+0000008B: DFF0 RCALL PC-0x000F Relative call subroutine
+0000008C: C003 RJMP PC+0x0004 Relative jump
+0000008D: 0000 NOP No operation
+0000008E: C001 RJMP PC+0x0002 Relative jump
+0000008F: 0000 NOP No operation
+00000090: 91800061 LDS R24,0x0061 Load direct from data space
+00000092: 2388 TST R24 Test for Zero or Minus
+00000093: F3C9 BREQ PC-0x06 Branch if equal
+00000094: 92100061 STS 0x0061,R1 Store direct to data space
+00000096: E380 LDI R24,0x30 Load immediate
+00000097: E090 LDI R25,0x00 Load immediate
+00000098: 01FC MOVW R30,R24 Copy register pair
+00000099: 8180 LDD R24,Z+0 Load indirect with displacement
+0000009A: 2388 TST R24 Test for Zero or Minus
+0000009B: F054 BRLT PC+0x0B Branch if less than, signed
+0000009C: E388 LDI R24,0x38 Load immediate
+0000009D: E090 LDI R25,0x00 Load immediate
+0000009E: E328 LDI R18,0x38 Load immediate
+0000009F: E030 LDI R19,0x00 Load immediate
+000000A0: 01F9 MOVW R30,R18 Copy register pair
+000000A1: 8130 LDD R19,Z+0 Load indirect with displacement
+000000A2: E220 LDI R18,0x20 Load immediate
+000000A3: 2723 EOR R18,R19 Exclusive OR
+000000A4: 01FC MOVW R30,R24 Copy register pair
+000000A5: 8320 STD Z+0,R18 Store indirect with displacement
+000000A6: E380 LDI R24,0x30 Load immediate
+000000A7: E090 LDI R25,0x00 Load immediate
+000000A8: 01FC MOVW R30,R24 Copy register pair
+000000A9: 8180 LDD R24,Z+0 Load indirect with displacement
+000000AA: 2F88 MOV R24,R24 Copy register
+000000AB: E090 LDI R25,0x00 Load immediate
+000000AC: 7480 ANDI R24,0x40 Logical AND with immediate
+000000AD: 7090 ANDI R25,0x00 Logical AND with immediate
+000000AE: 9700 SBIW R24,0x00 Subtract immediate from word
+000000AF: F451 BRNE PC+0x0B Branch if not equal
+000000B0: E388 LDI R24,0x38 Load immediate
+000000B1: E090 LDI R25,0x00 Load immediate
+000000B2: E328 LDI R18,0x38 Load immediate
+000000B3: E030 LDI R19,0x00 Load immediate
+000000B4: 01F9 MOVW R30,R18 Copy register pair
+000000B5: 8130 LDD R19,Z+0 Load indirect with displacement
+000000B6: E028 LDI R18,0x08 Load immediate
+000000B7: 2723 EOR R18,R19 Exclusive OR
+000000B8: 01FC MOVW R30,R24 Copy register pair
+000000B9: 8320 STD Z+0,R18 Store indirect with displacement
+000000BA: E386 LDI R24,0x36 Load immediate
+000000BB: E090 LDI R25,0x00 Load immediate
+000000BC: 01FC MOVW R30,R24 Copy register pair
+000000BD: 8180 LDD R24,Z+0 Load indirect with displacement
+000000BE: 2F88 MOV R24,R24 Copy register
+000000BF: E090 LDI R25,0x00 Load immediate
+000000C0: 7081 ANDI R24,0x01 Logical AND with immediate
+000000C1: 7090 ANDI R25,0x00 Logical AND with immediate
+000000C2: 9700 SBIW R24,0x00 Subtract immediate from word
+000000C3: F449 BRNE PC+0x0A Branch if not equal
+000000C4: E388 LDI R24,0x38 Load immediate
+000000C5: E090 LDI R25,0x00 Load immediate
+000000C6: E328 LDI R18,0x38 Load immediate
+000000C7: E030 LDI R19,0x00 Load immediate
+000000C8: 01F9 MOVW R30,R18 Copy register pair
+000000C9: 8120 LDD R18,Z+0 Load indirect with displacement
+000000CA: 6120 ORI R18,0x10 Logical OR with immediate
+000000CB: 01FC MOVW R30,R24 Copy register pair
+000000CC: 8320 STD Z+0,R18 Store indirect with displacement
+000000CD: E380 LDI R24,0x30 Load immediate
+000000CE: E090 LDI R25,0x00 Load immediate
+000000CF: 01FC MOVW R30,R24 Copy register pair
+000000D0: 8180 LDD R24,Z+0 Load indirect with displacement
+000000D1: 2F88 MOV R24,R24 Copy register
+000000D2: E090 LDI R25,0x00 Load immediate
+000000D3: 7280 ANDI R24,0x20 Logical AND with immediate
+000000D4: 7090 ANDI R25,0x00 Logical AND with immediate
+000000D5: 9700 SBIW R24,0x00 Subtract immediate from word
+000000D6: F009 BREQ PC+0x02 Branch if equal
+000000D7: CFB7 RJMP PC-0x0048 Relative jump
+000000D8: E388 LDI R24,0x38 Load immediate
+000000D9: E090 LDI R25,0x00 Load immediate
+000000DA: E328 LDI R18,0x38 Load immediate
+000000DB: E030 LDI R19,0x00 Load immediate
+000000DC: 01F9 MOVW R30,R18 Copy register pair
+000000DD: 8120 LDD R18,Z+0 Load indirect with displacement
+000000DE: 7E2F ANDI R18,0xEF Logical AND with immediate
+000000DF: 01FC MOVW R30,R24 Copy register pair
+000000E0: 8320 STD Z+0,R18 Store indirect with displacement
+000000E1: CFAE RJMP PC-0x0051 Relative jump
+000000E2: 94F8 CLI Global Interrupt Disable
+000000E3: CFFF RJMP PC-0x0000 Relative jump
+000000E4: CFFF RJMP PC-0x0000 Relative jump
+000000E5: 0001 ??? Data or unknown opcode
+000000E6: FFFF ??? Data or unknown opcode |
