04.02.2017, 23:15
Сказал спасибо: 337
Сказали Спасибо 30,207 раз(а) в 6,808 сообщении(ях)
Re: Книги (не радиотехнической тематики)
Beginning Drupal 8 (+code)
Название: Beginning Drupal 8 (+code)
Автор: Todd Tomlinson
Издательство: Apress
Год: 2015
Страниц: 297
ISBN: 1430265809, 978-1430265801
Формат: PDF
Язык: English
Beginning Drupal 8 teaches you how to build, maintain, and manage Drupal 8-based web sites. The book covers what Drupal is, using Drupal when building a new web site, installing and configuring Drupal, creating and managing content, managing users, adding functionality to your web site through Drupal modules, and advanced topics on using themes, panels, and views.
The book also builds practical examples of common Drupal sites, such as a company website, a community website, and a commerce website, that you can take and expand on to create your own Drupal 8 sites. By reading this book, you will understand the power of the Drupal platform, and why you should be using Drupal if you're not already. Through following the samples in the book, you will quickly build your confidence and your ability to use Drupal. Beginning Drupal 8 gives you the knowledge necessary to build, deploy, and manage web sites on Drupal 8.
На всякий Гугол свой Йобибайт найдется!
Сказали "Спасибо" mihail62
05.02.2017, 10:38
Сказал спасибо: 337
Android App Development in Android Studio
Название: Android App Development in Android Studio: Java + Android Edition For Beginners
Автор: Paul Cardle
Издательство: Independently published
Год: 2017
Страниц: 202
ISBN: 1542885841
Формат: PDF (True)
Язык: English
This book covers Android app design fundamentals in Android Studio using Java programming language.
The author assumes you have no experience in app development. The book starts with the installation of the required development environment and setting up the emulators. Then, the simplest "Hello World" app is developed step by step. In the next chapter, basics of the Java programming language are given with practical examples. Screenshots and code snippets are clearly given in the book to guide the reader. After the Java lecture, 6 complete Android apps are developed again by step by step instructions.
Each code line is explained. As the reader follows the development of the example apps, he/she will learn designing user interfaces, connecting interface objects to code, developing efficient Java code and testing the app on emulators and real devices.
The sample apps developed in this book are as follows:
1. Headlight app: Learn the basics of app development and use buttons in your code.
2. Body mass index (BMI) calculator app: Using input boxes, performing calculations and displaying the results on the screen.
3. Simple dice roller app: Using random number generator functions, including images in your project, displaying images on the screen and changing the displayed image programmatically.
4. The compass app: Accessing the magnetic field sensor, setting required permissions, extracting the direction angle and animating a compass figure.
5. Show my location app: Creating a map project, setting required permissions, accessing GPS device and showing real time location on the map.
6. S.O.S. sender app: Adding SMS functionality, setting required permissions and sending real time location using SMS.
05.02.2017, 11:07
Сказал спасибо: 337
Adaptive Control for Robotic Manipulators
Название: Adaptive Control for Robotic Manipulators
Автор: Dan Zhang
Издательство: CRC Press
Год: 2017
Страниц: 240
ISBN: 1498764878
Формат: PDF (conv)
Язык: English
The robotic mechanism and its controller make a complete system. As the robotic mechanism is reconfigured, the control system has to be adapted accordingly. The need for the reconfiguration usually arises from the changing functional requirements. This book will focus on the adaptive control of robotic manipulators to address the changed conditions.
The aim of the book is to summarise and introduce the state-of-the-art technologies in the field of adaptive control of robotic manipulators in order to improve the methodologies on the adaptive control of robotic manipulators. Advances made in the past decades are described in the book, including adaptive control theories and design, and application of adaptive control to robotic manipulators.
05.02.2017, 19:39
Сказал спасибо: 337
C++. Трюки и эффекты (+CD)
Название: C++. Трюки и эффекты (+CD)
Автор: Кондратюк Е.В.
Издательство: Питер
Год: 2006
Страниц: 400
ISBN: 5-469-01061-9
Формат: PDF
Язык: русский
Серия: Трюки и эффекты
Данная книга о программировании в C++ не имеет аналогов. В ней описаны оригинальные приемы создания программ и использования системных ресурсов. Применена самая эффективная методика обучения - на реальных примерах, которые можно немедленно использовать при создании собственных приложений. Емкая теоретическая часть содержит необходимый минимум сведений о программировании в C++ (в частности в Borland C++Builder).
На прилагаемом компакт-диске - коды всех программ, рассмотренных в книге, и дистрибутив триал-версии Borland C++Builder 6. Данное издание можно рекомендовать и опытным программистам, и новичкам.
Эти 2 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
05.02.2017, 22:17
Сказал спасибо: 337
Java to Python
Название: Java to Python
Автор: Vishnevskiy Igor
Год: 2016
Страниц: 159
Формат: PDF (conv)
Язык: English
Python is much like Java and at times even looks simpler. But Python is just as powerful as Java. If Java is the heavy metal of computer programming, then Python is the jazz that opens doors of freedom in software development. Both Java and Python are object-oriented programming languages.
Both support Java’s famous features such as encapsulation, inheritance and polymorphism. Both can be used to develop desktop and web-based applications. Both are multi-platform and run on all major platforms such as Linux, MS Windows, and Mac OS. Both support graphical user interface development.
Of course, there are also differences between Java and Python. For example, Java programs must be compiled, but in Python you have a choice of compiling your programs into stand-alone applications or running them as interpreted scripts or programs launched by a command from the Command Prompt. There are many other similarities and differences between these two languages, and those similaries make it a lot easier than you might think to learn Python, if you already know Java.
This book is for those who are already comfortable with developing using Java programming language and therefore assumes knowledge of Java. Designed for Java engineers who want to learn Python, this book walks you through the differences between Java 8 and Python 2.7 syntax using examples from both languages. Specifically, the book will demonstrate how to perform the same procedures in Java and Python. For each procedure, the class names, method names, and variable names are kept consistent between Java and Python examples. This way you can see clearly the differences in syntax between the two languages. Using this approach, you will be up to speed with Python in no time.
05.02.2017, 23:27
Сказал спасибо: 337
97 этюдов для архитекторов программных систем
Название: 97 этюдов для архитекторов программных систем. Опыт ведущих экспертов
Автор: Нил Форд, Майкл Найгард и др.
Издательство: Символ-Плюс
Год: 2010
Страниц: 224
Формат: DjVu
ISBN: 978-5-93286-176-9
Качество: Хорошее
Серия: Профессионально
Успешная карьера архитектора программного обеспечения требует хорошего владения как технологической, так и деловой сторонами вопросов, связанных с проектированием архитектуры. В этой необычной книге ведущие архитекторы ПО со всего света обсуждают важные принципы разработки, выходящие далеко за пределы чисто технологических вопросов.
Архитектор ПО выполняет роль посредника между командой разработчиков и бизнес-руководством компании, поэтому чтобы добиться успеха в этой профессии, необходимо не только овладеть различными технологиями, но и обеспечить работу над проектом в соответствии с бизнес-целями. В книге более 50 архитекторов рассказывают о том, что считают самым важным в своей работе, дают советы, как организовать общение с другими участниками проекта, как снизить сложность архитектуры, как оказывать поддержку разработчикам. Они щедро делятся множеством полезных идей и приемов, которые вынесли из своего многолетнего опыта. Авторы надеются, что книга станет источником вдохновения и руководством к действию для многих профессиональных программистов.
06.02.2017, 01:19
Сказал спасибо: 337
Как сложить печь
Название: Как сложить печь
Автор: Воропай П.И.
Издательство: Стройиздат
Год: 1989
Страниц: 144
ISBN: 5-274-00623-Х
Формат: PDF
Язык: русский
В популярной форме рассказано о конструкции печей - бытовых и специального назначения, предназначенных для строительства в сельской местности. Описаны приемы кладки печей, дан расчет теплопроводности стен, площади обогрева. Приведены рабочие чертежи (порядовки) печей различного назначения. Даны рекомендации по эксплуатации печей, ремонту и способам устранения неисправностей.
Содержание
- Материалы для сооружения печей;
- Как читать чертеж печи; Устройство отопительных печей;
- Виды и конструкции отопительных печей;
- Варочные и кухонные печи, печи и очаги различного назначения (Отопительно-варочные печи; Кухонные очаги; Хлебопекарские печи; Печи и очаги различного назначения);
- Печной инструмент, устройства и приспособления для кладки печей;
- Кладка печей;
- Наружная отделка печей;
- Устройство дымовых труб, перекидных рукавов и патрубков;
- Техника безопасности при кладке печей;
- Противопожарные мероприятия;
- Эксплуатация и ремонт печей;
- Практические советы домашнему мастеру;
- Справочные данные (Краткое описание бытовых печей других конструкций; Тепловые характеристики печей);
Приложения (Чертежи печей и очагов; Правила проведения контрольной топки; Размеры изразцов; Масса листа стали; Коэффициент твердости различных пород древесины).
07.02.2017, 11:54
Сказал спасибо: 337
AutoCAD 2017 and AutoCAD LT 2017 Essentials
Название: AutoCAD 2017 and AutoCAD LT 2017 Essentials
Автор: Scott Onstott
Издательство: Sybex
Год: 2016
Страниц: 435
ISBN: 1119243335, 978-1119243335
Формат: PDF
Язык: English
Hands-on AutoCAD 2017 instruction for a real-world workflow
AutoCAD 2017 and AutoCAD LT 2017 Essentials is the unique task-based tutorial designed for both students and the professional AutoCAD user. Concise, straightforward explanations and real-world, hands-on exercises provide an authoritative, easy-to-follow guide to the platform's core features and functions.
Step-by-step tutorials are backed by full-color screenshots, and each chapter ends with an open-ended project to reinforce the chapter's lessons and provide a fully immersive learning experience. The companion website features downloadable before-and-after tutorial files, so you can jump in at any point and compare your work with the pros. This new edition has been fully updated to align with AutoCAD's newest features and capabilities, and features a more approachable, easy-to-read style based on instructor and reader feedback to help you get up to speed and quickly become productive with the software.
AutoCAD is the leading design and drawing software, and an essential skill for designers, architects, and engineers. Whether you're new to the software, upgrading, or preparing for certification, this no-nonsense guide is your ideal resource for complete AutoCAD instruction.
07.02.2017, 12:23
Сказал спасибо: 337
Полная лунная энциклопедия
Название: Полная лунная энциклопедия
Автор: Зюрняева Т.Н.(ред.)
Издательство: СПб.: ИГ «Весь»
Год: 2010
Страниц: 889
ISBN: 978-5-9573-0672-6
Формат: PDF
Язык: русский
Серия: Лунные ритмы
«Полная лунная энциклопедия» — это книга, в которой впервые раскрыты все тайны влияния Луны на жизнь человека, обозначены благоприятные и неблагоприятные дни для всевозможных видов деятельности: от закладки сада до зачатия ребенка.
С древнейших времен люди заметили, что ночное светило по-особому воздействует на различные стороны жизни. Гиппократ укорял тех врачей, которые лечат, не обращая внимания на движение звезд, — теперь многие современные клиники планируют операции с учетом лунных ритмов. Опытные садоводы давно руководствуются правилами лунного календаря и видят в этом немалые преимущества. Домашние хлопоты могут приносить удовольствие, если заниматься ими в нужное время.
Тайные стороны души открываются при изучении влияния Луны на психологию. Книга снабжена уникальным лунным календарем на 80 лет (1940-2019), по которому легко можно планировать свои дела. Книга станет прекрасным подарком для всех интересующихся данной темой.
07.02.2017, 12:42
Сказал спасибо: 337
Автор: Кановская М.
Издательство: М.: АСТ, Сова
Год: 2008
Страниц: 640
ISBN: 978-5-17-049709-6
Формат: PDF
Язык: русский
Луна. Загадочная и таинственная, привычная и изменчивая, она будоражит ум, притягивает взгляд. Ее фазы влияют на наше здоровье, быт, успехи в бизнесе и на работе, на жизнь растений. Какими особенностями наделяет нас ночное светило, какую судьбу предрекает, об этом и многом другом вы прочитаете на страницах самой полной лунной энциклопедии.
Часовой пояс GMT +4, время: 10:19.
