Непрочитано 16.10.2014, 17:32
val_ka
Сказал спасибо: 71
Сказали Спасибо 125 раз(а) в 78 сообщении(ях)
val_ka на пути к лучшему
По умолчанию QL200 PIC MCU Development Board kit & USB Programmer
Купил вчера этот demo-board - просто супер (для моих потребностей).
Привожу данные:
Board Resource Introduction:
1) Switch between power supply thru USB or external power supply.
2) 128*64LCD and 16*2 LCD module
3) 32 LEDs are provided.
4) 4x4 matrix keyboard module
5) 8 buttons are provided.
6) Potentionmeters for simulating analog voltage input.
7) IIC (24C01/02 EEPROM)communication module
SPI (93C46 EEPROM)communication module
9) Real Time Clock DS1302. (Battery is not include)
10) Reset circuit.
11) ICD2 connector for customers who want to use it.
12) On-board programming module (USB Communication)
13) Chip socket and system clock selection
14) Digital LED display with 6bit 7-segment
15) Remote control receiver and decoder module
16) Digital thermometer DS1820 for temperature measurement from -55°C to 125°C.
17) Beeper experimental module
1 RS-232 communication for connection with a PC or any other device with a DB9 connector
19) Serial 10-bit voltage DA (TLC5615) converter for applications in measure - regulating devices.
20) All pins are taken out on IDC10 connectors to make them available for further connections.
21) Stepper Motor Driver Module
22) SD/MMC card Read/Write Module
23) Free Chip PIC16F877A-I/P
The auction includes
QL200 PIC DEVELOPMENT Board +
USB cable
ICSP cable
RS232 Cable
16F877A Chip
1602 LCD with Yellow backlight
CD-ROM (Programmer Driver , English version PDF User manual ,QL200 Layout,QL200 Board Schematic , Sample code (C / ASM) , MPLAB 7.50 .)
Compatible for OS including Windows 98, Windows 2000/NT, Windows XP , Windows 2003 and Vista
Dupont thread expansion connection 20x wire
12864-Graphic LCD Display Yellow Backlight
10-bit D/A converter TLC5615 (DIP8 package) *1
DS18B20 ( DS1820 ) Temperature Sensor(TO-92 package) *1
Sample with C and ASM Program sources code as below :
DS1820
Buzzer
128x64 GLCD (See the following Photos)
1602 LCD (See the following Photos)
93C46
24C02
4x4 Key testing
8x LED
7x segment
ADC / DAC
Infrared Remote
Stepper motor driver
MMC\SD card Read/Write (Only have C)
Сколько времени я тратил рвньше на всякие поиски и сборки для проверки... Отписывайтесь у кого есть.
И если б не было Одессы, шоб я делал?!
Последний раз редактировалось val_ka; 16.10.2014 в 17:34.
val_ka вне форума
Непрочитано 16.10.2014, 18:32
Easyrider83
Аватар для Easyrider83
Сказал спасибо: 918
Easyrider83 на пути к лучшему
По умолчанию Re: QL200 PIC MCU Development Board kit & USB Programmer
Когда все уже давно похоронили PIC, вы радостно за него хватаетесь. Демоборд нужен для базовых знаний и отладки своих библиотек. Такой навороченный трудно куда-то приспособить. Зачем? Все эти модули по отдельности уже давно освоены и отлажены. Лучший демоборд - ваше готовое устройство.
Easyrider83 вне форума
Эти 2 пользователя(ей) сказали Спасибо Easyrider83 за это сообщение:
dosikus (16.10.2014), SergeyNT_ (30.10.2014)
Непрочитано 16.10.2014, 20:17
NewWriter
Аватар для NewWriter
Сказал спасибо: 401
Сказали Спасибо 2,218 раз(а) в 1,316 сообщении(ях)
NewWriter на пути к лучшему
Даже я уже приобрел STM8S-Discovery, и потихоньку копаюсь.
Но для начала с PICами такая демоплата вполне пойдет. Дороговато правда. Зато не надо на макетной плате соединять перемычками и искать более удачное расположение компонентов. Но макетные платы все равно бы желательно иметь.
PIC16 и графический дисплей - както не вяжутся...
Последний раз редактировалось NewWriter; 16.10.2014 в 20:22.
NewWriter вне форума
Непрочитано 16.10.2014, 20:48
vavan1983
Аватар для vavan1983
Сказал спасибо: 70
vavan1983 на пути к лучшему
Сообщение от Easyrider83 Посмотреть сообщение
До сих пор многие автомобильные сигнализации, радары детекторы выходят с завода на PIC.
Плата очень даже к стати новичкам кто решил с нуля изучать МК.
vavan1983 вне форума
Сказали "Спасибо" vavan1983
Прохожий2 (30.10.2014)
Непрочитано 16.10.2014, 23:49
val_ka
Сказал спасибо: 71
Полгода назад был на одной приёмке, скажем так завода (пригласили на месяцок), в Южной Корее (запрещено фоткать и т.п.). Открыл одну из Boards сигнализации (их штук 20 щитов - работают под общим управлением) - там как раз pic16f877a в каждом щите (открыл, как говорят "без шухера", т.к. на приёмках ничего трогать нельзя).
Реле времени, счётчики часов работы и т.п. - некоторые фирмы делают на pic12f675.
Есть и другие темы, для которых мне нужна именно такая плата. (proteus штука не плохая, но всё же протестировать в железе всегда лучше, как по мне).
val_ka вне форума
Сказали "Спасибо" val_ka
Непрочитано 17.10.2014, 08:44
shindax
Сказали Спасибо 34 раз(а) в 25 сообщении(ях)
shindax на пути к лучшему
Согласен со всем, кроме похорон PIC. Не холивара ради и только IMHO. PIC-PIC-у рознь. Я вот сейчас на малоногих ( 20-28 ног ) PIC24 и PIC32 проект делаю, пока доволен. А демоборды у меня всего две, да и только те, что с PicKit2 в комплекте пришли, по-сути, просто макетки.
Последний раз редактировалось shindax; 17.10.2014 в 13:52.
shindax вне форума
Сказали "Спасибо" shindax
Непрочитано 19.10.2014, 23:47
katalianin
Сказал спасибо: 24
katalianin на пути к лучшему
Народ, зачем нападать на пики, ну если чуете что выросли берите одноплатные компьютеры и на них ваяйте.
katalianin вне форума
Непрочитано 20.10.2014, 21:57
vavan1983
Сказал спасибо: 70
Сообщение от katalianin Посмотреть сообщение
Да. Нам надо управлять тремя лампами накала на 220, а именно с помощью одной кнопки.
Один раз нажал светится одна лампа второй раз нажал вторая загорелась третий раз нажал третья загорелась четвертый раз все потухли.
И всё это надо будет организовать на одноплатном компьютере.
А можно взять и по меньше МК скажем PIC12F683 компактно дешево практично и экономично.
А пики вряд ли снимут с производства.
Непрочитано 21.10.2014, 12:06
Easyrider83
Сказал спасибо: 918
Сообщение от vavan1983 Посмотреть сообщение
Тут в соседней теме один такой "горе-разработчик" признался, что до сих пор лепит драйвера на 8051. Спрашивать "почему" не пришлось - сам сказал. Больше ничего не знает и знать не хочет.
Непрочитано 27.10.2014, 21:12
katalianin
Сказал спасибо: 24
Может дедок какой, вот и знать не хочет.
usb cdc pic18f14k50 gromovi Proteus, KiCAD и другие ECAD 9 21.04.2013 15:31
Литература по микроконтроллерам (AVR, PIC, ПЛИС и т.д.). Сборка книг - (256 книг+ 27 CD c примерами из книг) [обновление 2011, PDF, DJVU] yurinform Микроконтроллеры, АЦП, память и т.д 5 05.07.2011 19:00
Часовой пояс GMT +4, время: 11:25.
