Сообщение от DDimon
И еще вопросик - беру из АЦП значение в двоизной форме, как его перевести в десятичную? Так почемуто не выходит
[/code]
У тебя нет папки EXAMPLES ?
* Project name:
ADC_on_LCD (Displaying ADC result on LCD)
* Copyright:
(c) Mikroelektronika, 2005-2008.
* Description:
This code demonstrates how to use library function ADC_read, and library
procedures and functions for LCD display (4 bit interface).
* Test configuration:
MCU: PIC16F877A
Dev.Board: EasyPIC4
Oscillator: HS, 08.0000 MHz
Ext. Modules: LCD
SW: mikroC v8.0.0.0
* NOTES:
On EasyPIC4 jumper should be on RA2 at A-D Converter Input.
#include"built_in.h"
unsigned char ch;
unsigned int adc_rd;
char *text;
long tlong;
void main() {
INTCON = 0; // disable all interrupts
Lcd_Init(&PORTD); // Lcd_Init_EP4, see Autocomplete
LCD_Cmd(LCD_CURSOR_OFF); // send command to LCD (cursor off)
LCD_Cmd(LCD_CLEAR); // send command to LCD (clear LCD)
text = "mikroElektronika"; // assign text to string
LCD_Out(1,1,text); // print string a on LCD, 1st row, 1st column
text = "LCD example"; // assign text to string
LCD_Out(2,1,text); // print string a on LCD, 2nd row, 1st column
ADCON1 = 0x82; // configure VDD as Vref, and analog channels
TRISA = 0xFF; // designate PORTA as input
Delay_ms(5000);
text = "voltage:"; // assign text to string
while (1) {
adc_rd = ADC_read(2); // get ADC value from 2nd channel
tlong = (long)adc_rd * 5000; // covert adc reading to milivolts
tlong = tlong / 1023; // 0..1023 -› 0-5000mV
ch = tlong / 1000; // extract volts digit
LCD_Chr(2,9,48+ch); // write ASCII digit at 2nd row, 9th column
LCD_Chr_CP('.');
ch = (tlong / 100) % 10; // extract 0.1 volts digit
LCD_Chr_CP(48+ch); // write ASCII digit at cursor point
ch = (tlong / 10) % 10; // extract 0.01 volts digit
ch = tlong % 10; // extract 0.001 volts digit
LCD_Chr_CP('V');
Delay_ms(1);
