Непрочитано 02.06.2019, 12:46
Alex_golubev
Alex_golubev на пути к лучшему
По умолчанию imx287 ошибка загрузки линукса
Привет.
Сразу опишу что делал и как дошел до ошибки.
Создал рабочею директорию и клонировал buildroot.
mkdir work
cd work
git clone https://github.com/buildroot/buildroot
После собрал.
cd buildroot
make freescale_imx28evk_defconfig
make
Записал на sd-карту.
sudo dd if=output/images/sdcard.img of=/dev/sdb bs=4M
Запустил.
Получил ошибку
HTLLCLLC
U-Boot 2018.05 (May 13 2019 - 20:18:27 +0700)
CPU: Freescale i.MX28 rev1.2 at 454 MHz
BOOT: SSP SD/MMC #0, 3V3
SPI: ready
DRAM: 128 MiB
No arch specific invalidate_icache_all available!
NAND: 256 MiB
MMC: MXS MMC: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
Failed (-5)
Video: MXSFB: 'videomode' variable not set!
In: serial
Out: serial
Err: serial
Net: FEC0 [PRIME], FEC1
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
** Unable to read file boot.scr **
4506320 bytes read in 1333 ms (3.2 MiB/s)
Booting from mmc ...
22340 bytes read in 31 ms (703.1 KiB/s)
Kernel image @ 0x42000000 [ 0x000000 - 0x44c2d0 ]
## Flattened Device Tree blob at 41000000
Booting using the fdt blob at 0x41000000
Loading Device Tree to 47b17000, end 47b1f743 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.17.8 (alexey@debian) (gcc version 7.4.0 (Buildroot 2019.05-rc1-00022-g653bf93837)) #1 Mon May 13 20:20:07 +07 2019
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] OF: fdt: Machine model: Freescale i.MX28 Evaluation Kit
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] random: get_random_bytes called from start_kernel+0x84/0x474 with crng_init=0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyAMA0,115200 root=/dev/mmcblk0p3 rw rootwait
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 113240K/131072K available (6064K kernel code, 555K rwdata, 2008K rodata, 300K init, 7442K bss, 17832K reserved, 0K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xc8800000 - 0xff800000 ( 880 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (6066 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) ( 300 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 556 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) (7443 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Running RCU self tests
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] clocksource: mxs_timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000032] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.002268] Console: colour dummy device 80x30
[ 0.002431] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[ 0.002498] ... MAX_LOCKDEP_SUBCLASSES: 8
[ 0.002552] ... MAX_LOCK_DEPTH: 48
[ 0.002604] ... MAX_LOCKDEP_KEYS: 8191
[ 0.002653] ... CLASSHASH_SIZE: 4096
[ 0.002703] ... MAX_LOCKDEP_ENTRIES: 32768
[ 0.002753] ... MAX_LOCKDEP_CHAINS: 65536
[ 0.002803] ... CHAINHASH_SIZE: 32768
[ 0.002854] memory used by lock dependency info: 4655 kB
[ 0.002904] per task-struct memory footprint: 1536 bytes
[ 0.003104] Calibrating delay loop... 226.09 BogoMIPS (lpj=1130496)
[ 0.071444] pid_max: default: 32768 minimum: 301
[ 0.072578] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.072688] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.081135] CPU: Testing write buffer coherency: ok
[ 0.090281] Setting up static identity map for 0x40008400 - 0x40008458
[ 0.103357] devtmpfs: initialized
[ 0.165055] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.165303] futex hash table entries: 256 (order: 1, 11264 bytes)
[ 0.166948] pinctrl core: initialized pinctrl subsystem
[ 0.181233] NET: Registered protocol family 16
[ 0.184234] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.389720] Serial: AMBA PL011 UART driver
[ 0.393358] 80074000.serial: ttyAMA0 at MMIO 0x80074000 (irq = 236, base_baud = 0) is a PL011 rev2
[ 0.715045] console [ttyAMA0] enabled
[ 0.802110] mxs-dma 80004000.dma-apbh: initialized
[ 0.820126] mxs-dma 80024000.dma-apbx: initialized
[ 0.847131] SCSI subsystem initialized
[ 0.854109] usbcore: registered new interface driver usbfs
[ 0.860383] usbcore: registered new interface driver hub
[ 0.866692] usbcore: registered new device driver usb
[ 0.881533] pps_core: LinuxPPS API ver. 1 registered
[ 0.886802] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti ‹giometti@linux.it›
[ 0.896210] PTP clock support registered
[ 0.903170] Advanced Linux Sound Architecture Driver Initialized.
[ 0.917667] clocksource: Switched to clocksource mxs_timer
[ 1.575246] NET: Registered protocol family 2
[ 1.584911] tcp_listen_portaddr_hash hash table entries: 128 (order: 0, 5120 bytes)
[ 1.593098] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 1.600461] TCP bind hash table entries: 1024 (order: 3, 36864 bytes)
[ 1.608070] TCP: Hash tables configured (established 1024 bind 1024)
[ 1.615633] UDP hash table entries: 256 (order: 2, 20480 bytes)
[ 1.622424] UDP-Lite hash table entries: 256 (order: 2, 20480 bytes)
[ 1.630647] NET: Registered protocol family 1
[ 1.641515] RPC: Registered named UNIX socket transport module.
[ 1.648027] RPC: Registered udp transport module.
[ 1.652821] RPC: Registered tcp transport module.
[ 1.657806] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.679156] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 1.769294] NFS: Registering the id_resolver key type
[ 1.775504] Key type id_resolver registered
[ 1.780272] Key type id_legacy registered
[ 1.784864] jffs2: version 2.2. (NAND) В© 2001-2006 Red Hat, Inc.
[ 1.816384] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 24
[ 1.824400] io scheduler noop registered (default)
[ 1.829534] io scheduler mq-deadline registered
[ 1.834162] io scheduler kyber registered
[ 1.848166] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 1.906739] Console: switching to colour frame buffer device 100x30
[ 1.933880] mxsfb 80030000.lcdif: initialized
[ 1.945627] 8006a000.serial: ttyAPP0 at MMIO 0x8006a000 (irq = 234, base_baud = 1500000) is a 8006a000.serial
[ 1.958143] mxs-auart 8006a000.serial: Found APPUART 3.1.0
[ 1.966116] 80070000.serial: ttyAPP3 at MMIO 0x80070000 (irq = 235, base_baud = 1500000) is a 80070000.serial
[ 1.978757] mxs-auart 80070000.serial: Found APPUART 3.1.0
[ 2.029812] random: fast init done
[ 2.070123] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[ 2.076578] nand: Micron MT29F2G08ABAEAWP
[ 2.080888] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 2.096923] Scanning device for bad blocks
[ 3.361197] gpmi-nand 8000c000.gpmi-nand: driver registered.
[ 3.398391] m25p80 spi1.0: unrecognized JEDEC id bytes: ff, ff, ff
[ 3.410138] libphy: Fixed MDIO Bus: probed
[ 3.566692] libphy: fec_enet_mii_bus: probed
[ 3.577215] fec 800f4000.ethernet: 800f4000.ethernet supply phy not found, using dummy regulator
[ 3.594548] usbcore: registered new interface driver asix
[ 3.600697] usbcore: registered new interface driver ax88179_178a
[ 3.607240] usbcore: registered new interface driver cdc_ether
[ 3.613914] usbcore: registered new interface driver smsc95xx
[ 3.620420] usbcore: registered new interface driver net1080
[ 3.626526] usbcore: registered new interface driver cdc_subset
[ 3.633131] usbcore: registered new interface driver zaurus
[ 3.639581] usbcore: registered new interface driver cdc_ncm
[ 3.645341] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.652689] usbcore: registered new interface driver usb-storage
[ 3.690017] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 3.695981] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[ 3.727977] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 3.748559] hub 1-0:1.0: USB hub found
[ 3.753477] hub 1-0:1.0: 1 port detected
[ 3.773581] input: mxs-lradc-ts as /devices/soc0/80000000.apb/80040000.apbx/80050000.lradc/mxs-lradc-ts/input/input0
[ 3.794488] stmp3xxx-rtc 80056000.rtc: rtc core: registered 80056000.rtc as rtc0
[ 3.804062] i2c /dev entries driver
[ 3.818414] stmp3xxx_rtc_wdt stmp3xxx_rtc_wdt: initialized watchdog with heartbeat 19s
[ 3.832872] mxs-mmc 80010000.ssp: Got WP GPIO
[ 3.870302] mxs-mmc 80010000.ssp: initialized
[ 3.897334] mxs-dcp 80028000.dcp: Failed to register sha1 hash!
[ 3.906933] mxs-dcp: probe of 80028000.dcp failed with error -22
[ 3.920738] usbcore: registered new interface driver usbhid
[ 3.926401] usbhid: USB HID core driver
[ 3.946834] mmc0: new high speed SDHC card at address aaaa
[ 3.972649] mmcblk0: mmc0:aaaa SL16G 14.8 GiB (ro)
[ 4.013409] mxs-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
[ 4.026085] mmcblk0: p1 p2 p3
[ 4.030852] NET: Registered protocol family 17
[ 4.036616] Key type dns_resolver registered
[ 4.065853] registered taskstats version 1
[ 4.153987] sgtl5000 0-000a: Error reading chip id -6
[ 4.165340] mxs-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
[ 4.176079] stmp3xxx-rtc 80056000.rtc: setting system clock to 1970-01-01 00:14:10 UTC (850)
[ 4.186265] usb0_vbus: disabling
[ 4.190536] can-3v3: disabling
[ 4.193703] ALSA device list:
[ 4.196739] No soundcards found.
[ 4.205365] uart-pl011 80074000.serial: no DMA platform data
[ 4.214481] VFS: Cannot open root device "mmcblk0p3" or unknown-block(179,3): error -30
[ 4.222873] Please append a correct "root=" boot option; here are the available partitions:
[ 4.231696] 1f00 262144 mtdblock0
[ 4.231740] (driver?)
[ 4.238636] b300 15558144 mmcblk0
[ 4.238680] driver: mmcblk
[ 4.245608] b301 16384 mmcblk0p1 00000000-01
[ 4.245642]
[ 4.252774] b302 16384 mmcblk0p2 00000000-02
[ 4.252812]
[ 4.259947] b303 61440 mmcblk0p3 00000000-03
[ 4.259988]
[ 4.266913] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,3)
[ 4.275426] CPU: 0 PID: 1 Comm: swapper Not tainted 4.17.8 #1
[ 4.281228] Hardware name: Freescale MXS (Device Tree)
[ 4.286493] [‹c0011010›] (unwind_backtrace) from [‹c000f1a4›] (show_stack+0x10/0x14)
[ 4.294360] [‹c000f1a4›] (show_stack) from [‹c001ad4c›] (panic+0xcc/0x25
[ 4.301355] [‹c001ad4c›] (panic) from [‹c0816574›] (mount_block_root+0x1bc/0x2c0)
[ 4.308942] [‹c0816574›] (mount_block_root) from [‹c0816788›] (mount_root+0x110/0x154)
[ 4.316954] [‹c0816788›] (mount_root) from [‹c08168f4›] (prepare_namespace+0x128/0x18
[ 4.325054] [‹c08168f4›] (prepare_namespace) from [‹c0816140›] (kernel_init_freeable+0x310/0x36c)
[ 4.334035] [‹c0816140›] (kernel_init_freeable) from [‹c05ed700›] (kernel_init+0x8/0xf0)
[ 4.342220] [‹c05ed700›] (kernel_init) from [‹c00090b0›] (ret_from_fork+0x14/0x24)
[ 4.349852] Exception stack(0xc7483fb0 to 0xc7483ff
[ 4.354974] 3fa0: 00000000 00000000 00000000 00000000
[ 4.363222] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.371464] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 4.378190] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,3) ]---
[ 67.597805] random: crng init done
Решение оказалось:
ssp0: ssp@80010000 {
compatible = "fsl,imx28-mmc";
pinctrl-names = "default";
pinctrl-0 = ‹&mmc0_8bit_pins_a
&mmc0_cd_cfg &mmc0_sck_cfg›;
bus-width = ‹8›;
//wp-gpios = ‹&gpio2 12 0›; // нужно убрать
vmmc-supply = ‹®_vddio_sd0›;
status = "okay";
Пересобрал.
cd /home/alexey/work/buildroot
make linux-rebuild
make
Запрограммировал SD-карту. Все тем же dd.
И получил:
Код:
‹0›‹0›HTLLCLLC
U-Boot 2018.05 (May 15 2019 - 08:52:49 +0700)
SPI:   ready
DRAM:  128 MiB
NAND:  256 MiB
MMC:   MXS MMC: 0
Failed (-5)
In:    serial
Out:   serial
Err:   serial
4506312 bytes read in 1333 ms (3.2 MiB/s)
22316 bytes read in 31 ms (702.1 KiB/s)
Kernel image @ 0x42000000 [ 0x000000 - 0x44c2c8 ]
   Loading Device Tree to 47b17000, end 47b1f72b ... OK
Starting kernel ...
[    0.000000] Linux version 4.17.8 (alexey@alexey) (gcc version 7.4.0 (Buildroot 2019.05-rc1-00043-g47840289bf)) #1 Wed May 15 08:54:19 +07 2019
[    0.002269] Console: colour dummy device 80x30
[    0.002430] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[    0.002497] ... MAX_LOCKDEP_SUBCLASSES:  8
[    0.002551] ... MAX_LOCK_DEPTH:          48
[    0.002603] ... MAX_LOCKDEP_KEYS:        8191
[    0.002652] ... CLASSHASH_SIZE:          4096
[    0.002702] ... MAX_LOCKDEP_ENTRIES:     32768
[    0.002802] ... CHAINHASH_SIZE:          32768
[    0.002853]  memory used by lock dependency info: 4655 kB
[    0.002903]  per task-struct memory footprint: 1536 bytes
[    0.003102] Calibrating delay loop... 226.09 BogoMIPS (lpj=1130496)
[    0.071448] pid_max: default: 32768 minimum: 301
[    0.072579] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.072689] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.081138] CPU: Testing write buffer coherency: ok
[    0.090278] Setting up static identity map for 0x40008400 - 0x40008458
[    0.103344] devtmpfs: initialized
[    0.165096] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.165346] futex hash table entries: 256 (order: 1, 11264 bytes)
[    0.167003] pinctrl core: initialized pinctrl subsystem
[    0.181270] NET: Registered protocol family 16
[    0.184276] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.389524] Serial: AMBA PL011 UART driver
[    0.393133] 80074000.serial: ttyAMA0 at MMIO 0x80074000 (irq = 236, base_baud = 0) is a PL011 rev2
[    0.714817] console [ttyAMA0] enabled
[    0.801795] mxs-dma 80004000.dma-apbh: initialized
[    0.819819] mxs-dma 80024000.dma-apbx: initialized
[    0.846840] SCSI subsystem initialized
[    0.853812] usbcore: registered new interface driver usbfs
[    0.860095] usbcore: registered new interface driver hub
[    0.866404] usbcore: registered new device driver usb
[    0.881253] pps_core: LinuxPPS API ver. 1 registered
[    0.886521] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti ‹giometti@linux.it›
[    0.895936] PTP clock support registered
[    0.902908] Advanced Linux Sound Architecture Driver Initialized.
[    0.917432] clocksource: Switched to clocksource mxs_timer
[    1.575134] NET: Registered protocol family 2
[    1.584781] tcp_listen_portaddr_hash hash table entries: 128 (order: 0, 5120 bytes)
[    1.592966] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    1.600326] TCP bind hash table entries: 1024 (order: 3, 36864 bytes)
[    1.607941] TCP: Hash tables configured (established 1024 bind 1024)
[    1.615499] UDP hash table entries: 256 (order: 2, 20480 bytes)
[    1.622285] UDP-Lite hash table entries: 256 (order: 2, 20480 bytes)
[    1.630503] NET: Registered protocol family 1
[    1.641416] RPC: Registered named UNIX socket transport module.
[    1.647917] RPC: Registered udp transport module.
[    1.652715] RPC: Registered tcp transport module.
[    1.657694] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.678996] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[    1.768982] NFS: Registering the id_resolver key type
[    1.775188] Key type id_resolver registered
[    1.779953] Key type id_legacy registered
[    1.784552] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    1.816105] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    1.824115] io scheduler noop registered (default)
[    1.829242] io scheduler mq-deadline registered
[    1.833867] io scheduler kyber registered
[    1.847901] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    1.906519] Console: switching to colour frame buffer device 100x30
[    1.933661] mxsfb 80030000.lcdif: initialized
[    1.945383] 8006a000.serial: ttyAPP0 at MMIO 0x8006a000 (irq = 234, base_baud = 1500000) is a 8006a000.serial
[    1.957873] mxs-auart 8006a000.serial: Found APPUART 3.1.0
[    1.965897] 80070000.serial: ttyAPP3 at MMIO 0x80070000 (irq = 235, base_baud = 1500000) is a 80070000.serial
[    1.978524] mxs-auart 80070000.serial: Found APPUART 3.1.0
[    2.029590] random: fast init done
[    2.070753] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[    2.077206] nand: Micron MT29F2G08ABAEAWP
[    2.081518] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[    2.097791] Scanning device for bad blocks
[    3.359499] gpmi-nand 8000c000.gpmi-nand: driver registered.
[    3.398153] m25p80 spi1.0: unrecognized JEDEC id bytes: ff, ff, ff
[    3.409902] libphy: Fixed MDIO Bus: probed
[    3.566642] libphy: fec_enet_mii_bus: probed
[    3.577149] fec 800f4000.ethernet: 800f4000.ethernet supply phy not found, using dummy regulator
[    3.594466] usbcore: registered new interface driver asix
[    3.600607] usbcore: registered new interface driver ax88179_178a
[    3.607152] usbcore: registered new interface driver cdc_ether
[    3.613820] usbcore: registered new interface driver smsc95xx
[    3.620293] usbcore: registered new interface driver net1080
[    3.626431] usbcore: registered new interface driver cdc_subset
[    3.633033] usbcore: registered new interface driver zaurus
[    3.639474] usbcore: registered new interface driver cdc_ncm
[    3.645235] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.652581] usbcore: registered new interface driver usb-storage
[    3.690096] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    3.696056] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[    3.727749] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    3.748361] hub 1-0:1.0: USB hub found
[    3.753288] hub 1-0:1.0: 1 port detected
[    3.773427] input: mxs-lradc-ts as /devices/soc0/80000000.apb/80040000.apbx/80050000.lradc/mxs-lradc-ts/input/input0
[    3.794275] stmp3xxx-rtc 80056000.rtc: rtc core: registered 80056000.rtc as rtc0
[    3.803857] i2c /dev entries driver
[    3.818182] stmp3xxx_rtc_wdt stmp3xxx_rtc_wdt: initialized watchdog with heartbeat 19s
[    3.863135] mxs-mmc 80010000.ssp: initialized
[    3.892303] mxs-dcp 80028000.dcp: Failed to register sha1 hash!
[    3.901989] mxs-dcp: probe of 80028000.dcp failed with error -22
[    3.915649] usbcore: registered new interface driver usbhid
[    3.921562] usbhid: USB HID core driver
[    3.938083] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.958642] mmc0: new high speed SDHC card at address aaaa
[    3.982850] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    4.013573] mxs-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
[    4.029487]  mmcblk0: p1 p2 p3
[    4.036516] NET: Registered protocol family 17
[    4.046407] Key type dns_resolver registered
[    4.070013] registered taskstats version 1
[    4.157268] sgtl5000 0-000a: Error reading chip id -6
[    4.168888] mxs-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
[    4.179336] stmp3xxx-rtc 80056000.rtc: setting system clock to 1970-01-01 00:01:51 UTC (111)
[    4.189683] usb0_vbus: disabling
[    4.193375] can-3v3: disabling
[    4.196526] ALSA device list:
[    4.199813]   No soundcards found.
[    4.208503] uart-pl011 80074000.serial: no DMA platform data
[    4.228450] EXT4-fs (mmcblk0p3): mounting ext2 file system using the ext4 subsystem
[    4.272326] EXT4-fs (mmcblk0p3): warning: mounting unchecked fs, running e2fsck is recommended
[    4.290388] EXT4-fs (mmcblk0p3): mounted filesystem without journal. Opts: (null)
[    4.298609] VFS: Mounted root (ext2 filesystem) on device 179:3.
[    4.340858] devtmpfs: mounted
[    4.346407] Freeing unused kernel memory: 300K
[    4.351194] This architecture does not have kernel memory protection.
[    4.596637] EXT4-fs (mmcblk0p3): re-mounted. Opts: block_validity,barrier,user_xattr
Starting syslogd: OK
Starting klogd: OK
Initializing random number generator... [    5.244356] random: dd: uninitialized urandom read (512 bytes read)
done.
Starting network: OK
Welcome to Buildroot
buildroot login:
Загрузил тулчейн
https://releases.linaro.org/components/ ... abi.tar.xz
распаковал его.
Далее в buildroot'е:
make menuconfig, ставим
Код:
Toolchain  ---›
    Toolchain type (External toolchain)  ---›
    Toolchain (Custom toolchain)  ---›
    Toolchain origin (Pre-installed toolchain)  ---›
    (Путь к распакованному тулчейну) Toolchain path
    ($(ARCH)-linux-gnueabi) Toolchain prefix
    External toolchain gcc version (7.x)  ---›
    External toolchain kernel headers series (4.10.x)  ---›
    External toolchain C library (glibc/eglibc)  ---›
make clean
make
1. Клонируем репозиторий ядра нужной версии (в директории ~/work):
git clone git://git.kernel.org/pub/scm/linux/kern ... /linux.git --branch=v4.19 --depth=1
2. Для удобства создадим переменную с путем и префиксом к компилятору:
export ARMCC_GNUEABI7=/home/‹что-то еще›/gcc-linaro-7.4.1-2019.02-x86_64_arm-linux-gnueabi/bin/arm-linux-gnueabi-
3. Переходим в work/linux, снова правим arch/arm/boot/dts/imx28-evk.dts
4. Запускаем defconfig:
make ARCH=arm mxs_defconfig
5. Пробуем собрать:
make ARCH=arm CROSS_COMPILE=${ARMCC_GNUEABI7} zImage modules dtbs
Подцепляем ядро к bouldroot
1. В ~/work/buildroot создаем файл local.mk со следующим содержимым:
LINUX_OVERRIDE_SRCDIR = ../linux
Это путь к отдельно лежащему ядру.
2. Правим конфигурацию:
Код:
  │ │[*] Linux Kernel                                                 │ │
  │ │          *** Linux kernel in thumb mode may be broken with binutils │ │
  │ │          Kernel version (Custom version)  ---›                      │ │
  │ │    (4.19) Kernel version                                            │ │
  │ │    ()    Custom kernel patches                                      │ │
  │ │          Kernel configuration (Using a custom (def)config file)  ---│ │
  │ │    (kernel.config) Configuration file path                          │ │
  │ │    ()    Additional configuration fragment files                    │ │
  │ │    ()    Custom boot logo file path                                 │ │
  │ │          Kernel binary format (zImage)  ---›                        │ │
  │ │          Kernel compression format (gzip compression)  ---›         │ │
  │ │[*]   Build a Device Tree Blob (DTB)                             │ │
  │ │    (imx28-evk) In-tree Device Tree Source file names                │ │
  │ │    ()      Out-of-tree Device Tree Source file paths                │ │
  │ │    [ ]   Install kernel image to /boot in target                    │ │
  │ │    [ ]   Needs host OpenSSL                                         │ │
  │ │    [ ]   Needs host libelf                                          │ │
  │ │          Linux Kernel Extensions  ---›                              │ │
  │ │          Linux Kernel Tools  ---›                                   │ │
3. Копируем linux/.config в buildroot/kernel.config
Пробуем собрать:
.../buildroot$ make linux-rebuild
Здесь у меня была ошибка но уже решили проблема с cp.
Далее записал на sd-карту с помощью dd
запустил и увидал ошибку
Код:
‹0›HTLLCLLC
U-Boot 2018.05 (May 28 2019 - 11:53:24 +0700)
SPI:   ready
DRAM:  128 MiB
NAND:  256 MiB
MMC:   MXS MMC: 0
Failed (-5)
In:    serial
Out:   serial
Err:   serial
4745472 bytes read in 1405 ms (3.2 MiB/s)
22034 bytes read in 32 ms (671.9 KiB/s)
Kernel image @ 0x42000000 [ 0x000000 - 0x486900 ]
   Loading Device Tree to 47b18000, end 47b20611 ... OK
Starting kernel ...
[    0.000000] Linux version 4.19.0 (alexey@alexey) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #2 Tue May 28 14:45:25 +07 2019
[    0.000000] random: get_random_bytes called from start_kernel+0x84/0x470 with crng_init=0
[    0.000000] Memory: 112752K/131072K available (6359K kernel code, 561K rwdata, 2176K rodata, 308K init, 7445K bss, 18320K reserved, 0K cma-reserved)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (6361 kB)
[    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   ( 308 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 562 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   (7446 kB)
[    0.000038] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.002133] Console: colour dummy device 80x30
[    0.002307] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[    0.002375] ... MAX_LOCKDEP_SUBCLASSES:  8
[    0.002433] ... MAX_LOCK_DEPTH:          48
[    0.002485] ... MAX_LOCKDEP_KEYS:        8191
[    0.002538] ... CLASSHASH_SIZE:          4096
[    0.002592] ... MAX_LOCKDEP_ENTRIES:     32768
[    0.002648] ... MAX_LOCKDEP_CHAINS:      65536
[    0.002701] ... CHAINHASH_SIZE:          32768
[    0.002754]  memory used by lock dependency info: 4655 kB
[    0.002808]  per task-struct memory footprint: 1536 bytes
[    0.003125] Calibrating delay loop... 226.09 BogoMIPS (lpj=1130496)
[    0.071463] pid_max: default: 32768 minimum: 301
[    0.072677] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.072794] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.080991] CPU: Testing write buffer coherency: ok
[    0.090572] Setting up static identity map for 0x40008400 - 0x40008458
[    0.102055] devtmpfs: initialized
[    0.170348] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.170599] futex hash table entries: 256 (order: 1, 11264 bytes)
[    0.172200] pinctrl core: initialized pinctrl subsystem
[    0.187004] NET: Registered protocol family 16
[    0.189990] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.413906] Serial: AMBA PL011 UART driver
[    0.417850] 80074000.serial: ttyAMA0 at MMIO 0x80074000 (irq = 236, base_baud = 0) is a PL011 rev2
[    0.745079] console [ttyAMA0] enabled
[    0.844396] mxs-dma 80004000.dma-apbh: initialized
[    0.863665] mxs-dma 80024000.dma-apbx: initialized
[    0.894982] SCSI subsystem initialized
[    0.902132] usbcore: registered new interface driver usbfs
[    0.908521] usbcore: registered new interface driver hub
[    0.914841] usbcore: registered new device driver usb
[    0.930794] pps_core: LinuxPPS API ver. 1 registered
[    0.936076] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti ‹giometti@linux.it›
[    0.945501] PTP clock support registered
[    0.952698] Advanced Linux Sound Architecture Driver Initialized.
[    0.968729] clocksource: Switched to clocksource mxs_timer
[    1.615856] NET: Registered protocol family 2
[    1.625687] tcp_listen_portaddr_hash hash table entries: 128 (order: 0, 5120 bytes)
[    1.633809] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    1.641178] TCP bind hash table entries: 1024 (order: 3, 36864 bytes)
[    1.648121] TCP: Hash tables configured (established 1024 bind 1024)
[    1.655918] UDP hash table entries: 256 (order: 2, 20480 bytes)
[    1.662480] UDP-Lite hash table entries: 256 (order: 2, 20480 bytes)
[    1.670487] NET: Registered protocol family 1
[    1.681940] RPC: Registered named UNIX socket transport module.
[    1.688200] RPC: Registered udp transport module.
[    1.693245] RPC: Registered tcp transport module.
[    1.698043] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.720658] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[    1.820081] NFS: Registering the id_resolver key type
[    1.826489] Key type id_resolver registered
[    1.831271] Key type id_legacy registered
[    1.835916] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    1.869904] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    1.877710] io scheduler noop registered (default)
[    1.882860] io scheduler mq-deadline registered
[    1.887494] io scheduler kyber registered
[    1.902266] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    1.912945] pwm-backlight backlight: Linked as a consumer to regulator.0
[    1.929978] 8006a000.serial: ttyAPP0 at MMIO 0x8006a000 (irq = 234, base_baud = 1500000) is a 8006a000.serial
[    1.942400] mxs-auart 8006a000.serial: Found APPUART 3.1.0
[    1.950701] 80070000.serial: ttyAPP3 at MMIO 0x80070000 (irq = 235, base_baud = 1500000) is a 80070000.serial
[    1.963224] mxs-auart 80070000.serial: Found APPUART 3.1.0
[    1.974895] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.981869] [drm] No driver support for vblank timestamp query.
[    1.989627] mxsfb 80030000.lcdif: Failed to create outputs
[    2.050202] random: fast init done
[    2.093833] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
[    2.100492] nand: Micron MT29F2G08ABAEAWP
[    2.104593] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[    2.119894] Scanning device for bad blocks
[    3.398205] gpmi-nand 8000c000.gpmi-nand: driver registered.
[    3.429786] m25p80 spi1.0: unrecognized JEDEC id bytes: ff, ff, ff
[    3.441575] libphy: Fixed MDIO Bus: probed
[    3.458075] fec 800f0000.ethernet: Linked as a consumer to regulator.3
[    3.610478] libphy: fec_enet_mii_bus: probed
[    3.621575] fec 800f4000.ethernet: 800f4000.ethernet supply phy not found, using dummy regulator
[    3.631481] fec 800f4000.ethernet: Linked as a consumer to regulator.0
[    3.645630] usbcore: registered new interface driver asix
[    3.651841] usbcore: registered new interface driver ax88179_178a
[    3.658406] usbcore: registered new interface driver cdc_ether
[    3.665110] usbcore: registered new interface driver smsc95xx
[    3.671639] usbcore: registered new interface driver net1080
[    3.677789] usbcore: registered new interface driver cdc_subset
[    3.684418] usbcore: registered new interface driver zaurus
[    3.690894] usbcore: registered new interface driver cdc_ncm
[    3.696653] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.704040] usbcore: registered new interface driver usb-storage
[    3.717505] imx_usb 80080000.usb: Linked as a consumer to regulator.4
[    3.744314] imx_usb 80090000.usb: Linked as a consumer to regulator.5
[    3.756538] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    3.762819] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[    3.799046] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    3.820801] hub 1-0:1.0: USB hub found
[    3.825408] hub 1-0:1.0: 1 port detected
[    3.845856] input: mxs-lradc-ts as /devices/soc0/80000000.apb/80040000.apbx/80050000.lradc/mxs-lradc-ts/input/input0
[    3.867310] stmp3xxx-rtc 80056000.rtc: rtc core: registered 80056000.rtc as rtc0
[    3.877186] i2c /dev entries driver
[    3.892216] stmp3xxx_rtc_wdt stmp3xxx_rtc_wdt: initialized watchdog with heartbeat 19s
[    3.905911] mxs-mmc 80010000.ssp: Linked as a consumer to regulator.2
[    3.944177] mxs-mmc 80010000.ssp: initialized
[    3.971931] mxs-dcp 80028000.dcp: Failed to register sha1 hash!
[    3.981017] mxs-dcp: probe of 80028000.dcp failed with error -22
[    3.997843] mmc0: host does not support reading read-only switch, assuming write-enable
[    4.007802] usbcore: registered new interface driver usbhid
[    4.013710] usbhid: USB HID core driver
[    4.020437] mmc0: new high speed SDHC card at address 0007
[    4.045453] mmcblk0: mmc0:0007 SL16G 14.5 GiB
[    4.086491] sgtl5000 0-000a: Linked as a consumer to regulator.1
[    4.093329]  mmcblk0: p1 p2 p3
[    4.131697] mxs-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
[    4.140555] NET: Registered protocol family 17
[    4.146432] Key type dns_resolver registered
[    4.158579] registered taskstats version 1
[    4.249913] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.256852] [drm] No driver support for vblank timestamp query.
[    4.264152] mxsfb 80030000.lcdif: Failed to create outputs
[    4.279144] sgtl5000 0-000a: Error reading chip id -6
[    4.290012] mxs-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
[    4.301089] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.307810] [drm] No driver support for vblank timestamp query.
[    4.314793] mxsfb 80030000.lcdif: Failed to create outputs
[    4.323312] mxs-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
[    4.333058] stmp3xxx-rtc 80056000.rtc: setting system clock to 1970-01-01 00:00:09 UTC (9)
[    4.343318] usb0_vbus: disabling
[    4.347031] lcd-3v3: disabling
[    4.350443] can-3v3: disabling
[    4.353606] lcd-5v: disabling
[    4.356707] ALSA device list:
[    4.359954]   No soundcards found.
[    4.369186] uart-pl011 80074000.serial: no DMA platform data
[    4.388417] EXT4-fs (mmcblk0p3): mounting ext2 file system using the ext4 subsystem
[    4.432318] EXT4-fs (mmcblk0p3): warning: mounting unchecked fs, running e2fsck is recommended
[    4.480116] EXT4-fs (mmcblk0p3): mounted filesystem without journal. Opts: (null)
[    4.488087] VFS: Mounted root (ext2 filesystem) on device 179:3.
[    4.531310] devtmpfs: mounted
[    4.536936] Freeing unused kernel memory: 308K
[    4.541729] This architecture does not have kernel memory protection.
[    4.548260] Run /sbin/init as init process
[    4.617788] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[    4.617788]
[    4.627033] CPU: 0 PID: 1 Comm: init Not tainted 4.19.0 #2
[    4.632584] Hardware name: Freescale MXS (Device Tree)
[    4.637852] [‹c00112b0›] (unwind_backtrace) from [‹c000ed4c›] (show_stack+0x10/0x14)
[    4.645695] [‹c000ed4c›] (show_stack) from [‹c001b3f4›] (panic+0xcc/0x258)
[    4.652660] [‹c001b3f4›] (panic) from [‹c001da7c›] (do_exit+0x9ec/0xa3c)
[    4.659447] [‹c001da7c›] (do_exit) from [‹c001ed0c›] (do_group_exit+0x38/0xbc)
[    4.666758] [‹c001ed0c›] (do_group_exit) from [‹c002a848›] (get_signal+0x204/0x79c)
[    4.674502] [‹c002a848›] (get_signal) from [‹c000e058›] (do_signal+0x1dc/0x4b0)
[    4.681907] [‹c000e058›] (do_signal) from [‹c000e518›] (do_work_pending+0xdc/0x110)
[    4.689651] [‹c000e518›] (do_work_pending) from [‹c0009034›] (slow_work_pending+0xc/0x20)
[    4.697893] Exception stack(0xc7485fb0 to 0xc7485ff8)
[    4.703016] 5fa0:                                     bec2bf10 00000000 00000000 00000000
[    4.711266] 5fc0: 00000940 00000000 00000000 00000000 00000000 00000000 000275e4 00000000
[    4.719514] 5fe0: 00000000 bec2bf10 b6f2eb53 b6f2f000 00000030 ffffffff
[    4.726247] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[    4.726247]  ]---
Почему так не знаю.
Последний раз редактировалось Alex_golubev; 02.06.2019 в 13:02.
Alex_golubev вне форума
Непрочитано 02.06.2019, 18:51
mike-y-k
Сказал спасибо: 11,170
mike-y-k на пути к лучшему
По умолчанию Re: imx287 ошибка загрузки линукса
Alex_golubev, таки такие длинные файлы сильно оптимальнее с добавлением расширения .txt вставлять через управление вложениями. Тут и объём сообщения великоват и спойлеры не у всех отрабатывают, и потери содержимого вполне возможны…
Для нормального анализа неплохо бы конфигурацию для uboot и для начала листинг /etc со всеми поддиректориями…
mike-y-k вне форума
Непрочитано 25.07.2019, 23:07
ass20
Сказали Спасибо 23 раз(а) в 21 сообщении(ях)
ass20 на пути к лучшему
Может вам использовать готовую виртуальную машину для этого камня??
Ее можно взять на zao-zeo.ru я думаю найдете ее там)) и ещё можете глянуть на otladka.com.ua
ass20 вне форума
Ускорить компьютер 7Fantomas7 Ремонт оргтехники 111 08.08.2018 05:27
ошибка при чтении списка цепей Витя19 KiCAD 2 10.04.2017 14:35
в Canon PC780 после копирования высвечивается ошибка Е007 Anton_uz Ремонт оргтехники 1 16.04.2011 13:03
Кода сбоя загрузки мат. платы AV8 George-sun Ремонт оргтехники 0 27.02.2009 14:07
Часовой пояс GMT +4, время: 15:37.
