Поставил все с нуля почистил реестр русик не ставил в С пропали вопросы но компилить в хекс не хотит вот что пишет
File name: C:\123\Flowcode1.c
Generated by: Flowcode v4.0.0.53
Date: Sunday, June 21, 2009 23:47:08
Licence:
Registered to: Admin
NOT FOR COMMERCIAL USE
http://www.matrixmultimedia.com
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F84A "Flowcode1.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
Multimedia\Flowcode
Starting preprocessor: "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\pp.exe" C:\123\Multimedia\Flowcode -i "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\include" -d _PIC16F84A -la -c2 -o C:\123\Multimedia\Flowcode.pp -v -d _BOOSTC -d _PIC16
FATAL: Unable to open input file: C:\123\Multimedia\Flowcode
Error: preprocessing error
Starting preprocessor: "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\pp.exe" C:\123\V4\BoostC\boostc.pic16.flowcode.exe -i "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\include" -d _PIC16F84A -la -c2 -o C:\123\V4\BoostC\boostc.pic16.flowcode.pp -v -d _BOOSTC -d _PIC16
FATAL: Unable to open input file: C:\123\V4\BoostC\boostc.pic16.flowcode.exe
Flowcode1.c
Starting preprocessor: "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\pp.exe" C:\123\Flowcode1.c -i "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\include" -d _PIC16F84A -la -c2 -o C:\123\Flowcode1.pp -v -d _BOOSTC -d _PIC16
Flowcode1.c success
failure
Return code = 1
Flowcode was unable to compile the flowchart's C code due to the following errors:
If your flowchart contains C code, please review this carefully. If your flowchart contains no C-code or you have thoroughly reviewed the code, contact Technical Support.
FINISHED
вот только думаю откуда он этот путь взял? C:\123\V4\BoostC\boostc.pic16.flowcode.exe -i папка всего 123 и в ней проэкт и все
в настройках все пути в норме
Прикрепленный файл:
3619732.rar
