Непрочитано 06.04.2011, 10:03
MisterDi
Аватар для MisterDi
Сказал спасибо: 442
MisterDi на пути к лучшему
По умолчанию Re: Осваиваем USBee
C24 - variable capacitor which placed near BNC connector on top side;
C30 - decoupling capacitor for negative supply of AD8066
R67 - whith R68 makes gain +10 when pin 7 and pin 8 of J10 are connected.
C29 - high freqency correcting capacitor. SPICE requre that.
All 100n capacitors are placed on PCB, see attached image, they are marked as red
U40 key is placed in direction of USB connector
value of R70 is 510 Ohm
C26 is not need, you are right
R82 R83 used for limit current via LED's . They value is 1kOm - 3.3kOm use "152" RES for this.
"000" can be left.
Use single resistor of R73/R73 for select direction of manual beam movement. Don't forget about R65, they are connect digital and analog ground.
R66 is NOT need for you, they are use for AD9283 ADC.
Last version of schematic are attached too.
PS Use botton "Управление вложениями" in answer page to attach files.
Sorry, but i'm not correct value of U3 in schematic. It will be AD8066.
Миниатюры:
Тип файла: pdf AX_v3.pdf (46.8 Кб, 311 просмотров)
misterdi<@>i.ua
Последний раз редактировалось MisterDi; 06.04.2011 в 10:18.
MisterDi вне форума
Непрочитано 06.04.2011, 10:27
MisterDi
Аватар для MisterDi
Сказал спасибо: 442
Add my answer on other topic:
Some guides for assembling.
1. Mount Power section and USB connector (J3, U40 and it's peripherals resistor, capacitors e.t.c) check values of power: 3.3V -2.5V
2. Mount uC section (U1, U2).
3. Install CyConsole Software. Connect device to PC and check via control panel, that PC "view" device as "Cypress Missing EEPROM device"
4. Set VID/PID by CyConsole and check device "USBee AX pod" in Device Manager.
5. Mount Analig input section (U3, U4, J9, J10) Check negative power supply/ In some cases output voltage may be -1.8/-1.9. If this happend, add resistor 4.7Ohm parallel to R62. It will increase current via L2 and output voltage will still normal (-2.5V)
6. Mount Digital input section (U5, w/passive component)
VERY IMPORTANT!!!
After programming vid/pid via CY Console, connect pin 7 U2 to VCC (pin8 U2), for protecting of changes by last version of USBee Suite.
7. Install USBee Suite/USBee AX software.
misterdi<@>i.ua
Последний раз редактировалось MisterDi; 06.04.2011 в 16:23.
MisterDi вне форума
Непрочитано 06.04.2011, 15:25
ART_K
Сказали Спасибо 20 раз(а) в 13 сообщении(ях)
ART_K на пути к лучшему
в вашей плате PORTA наружу выведен?
у меня китайский клон(брал за $50), там стоит проц в корпусе 56-pin QFN и из PORTA используется только бит 0, для переключения каналов осциллографа. остальные биты не используются, но припаять к ножкам провода думаю будет не так просто..
ART_K вне форума
Непрочитано 06.04.2011, 15:38
ART_K
в USBee Suite могут ввести проверку на запись в еепром и в случае WP суета будет отказыватся работать..
ART_K вне форума
Непрочитано 06.04.2011, 15:51
picavr
Аватар для picavr
Сказал спасибо: 13
picavr на пути к лучшему
Сообщение от ART_K Посмотреть сообщение
Тоже 56, прибор а не Девелопер Боард.
Могут, но пока не додумались до этого
Они долго думали, пока вставили хоть такую защиту )))
А если додумаются, то можно будет повесить PIC10F200 и перепрошивать каждый раз при включении EEPROM ... на 1 миллион включений хватит одной EEPROM.
Так что всё энто фигня.. пока нет на плате какого либо чипа с защитой памяти )))))
да и это уже не спасёт, они уже стратили, это нужно было сразу думать... Уже всё содрано...
И что там такого нового написать в софте? что бы без него не обойтись?)))
Да и поддержка легальных пользователей которые уже купили приборы... не позволит в этом плане много придумывать...
Последний раз редактировалось picavr; 06.04.2011 в 15:56.
picavr вне форума
Сказали "Спасибо" picavr
EXILIM600 (09.08.2011)
Непрочитано 06.04.2011, 16:33
ART_K
могут использовать меняющийся код, типо как в иммо..
в конце концов привязка к железу компа)
но с такой кривой сюитой сомниваюсь чтото)
ART_K вне форума
Непрочитано 06.04.2011, 16:38
qwerky
Сказали Спасибо 149 раз(а) в 66 сообщении(ях)
qwerky на пути к лучшему
так есть же утилиты для прошивки
qwerky вне форума
Непрочитано 06.04.2011, 16:46
MisterDi
Аватар для MisterDi
Сказал спасибо: 442
Перепрошивать вручную после каждого запуска?! - я уже не героический комсомолец, который преодолевает самостоятельно созданные трудности
misterdi<@>i.ua
MisterDi вне форума
Непрочитано 06.04.2011, 17:11
qwerky
почему вручную ? можно создать bat-файл который сам все сделает
qwerky вне форума
Непрочитано 06.04.2011, 20:42
MisterDi
Аватар для MisterDi
Сказал спасибо: 442
Конечно можно, но если железо позволяет, то пусть оно само занимается своей защитой
misterdi<@>i.ua
MisterDi вне форума
Осваиваем микроконтроллеры AVR ctr-krl Микроконтроллеры, АЦП, память и т.д 11 17.07.2007 11:50
Часовой пояс GMT +4, время: 05:16.
