08.04.2007, 16:56
Сказали Спасибо 17 раз(а) в 4 сообщении(ях)
нужен исходник на Си
Доюрый день!
Помогите кто чем сможет.
нужна программа на Си для измерения частоты
PIC контроллером. Диапазон от 0 до 10 кГц
08.04.2007, 17:56
Сказал спасибо: 936
Код:
//// EX_FREQC.C ////
//// Counts the 'zero' crossings of an input signal for 1 second, ////
//// therefore counting the frequency of the signal. The input ////
//// signal's frequency is then displayed over the serial port. ////
//// The 1s delay is created by generating a perfect 5,000,000 ////
//// cycles (it takes 0.2us for one cycle at 20Mhz). The trick is ////
//// that conditional statements have different values of cycles ////
//// depending on a TRUE or FALSE jump. ////
//// The input signal is to be supplied to pin C0 ////
//// This example will work with the PCM compiler. The ////
//// following conditional compilation lines are used to include a ////
//// valid device for each compiler. Change the device and clock ////
//// for your hardware if needed. ////
//// (C) Copyright 1996,2003 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. ////
#include ‹16F877.h›
#fuses HS,NOWDT,NOLVP
#use delay(clock=20000000) //one instruction=0.2us
#use rs232(baud=9600, xmit=PIN_c6, rcv=PIN_c7)
#bit t1_overflow=0x0C.0
// #bit t1_overflow=0xF9E.0 (PIC18, Reminder)
void main() {
int cycles8, cycles;
int32 freq;
long freqc_high;
long freqc_low;
while (TRUE) {
cycles8=0;
cycles=0;
freqc_high=0;
t1_overflow=0;
set_timer1(0);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
/* ___ wait one second ___ */
while (cycles!=0xFF) { //true=3, false=4
cycles8=0; //1 cycle
//start inner loop
while (cycles8!=0xFF) { //true=3, false=4
if (t1_overflow)//true=2,false=3 //----|
{t1_overflow=0;freqc_high++;}//6 cycles // |
else // |-- 8 cycles
{delay_cycles(5);} //----|
delay_cycles(62); //x
cycles8++; //1
///2 cycles to jump to top
//math: end inner loop
//math: total inner loop=((3+8+x+1+2)*255 + 4)*255
//math: if x=62.87781 then inner loops takes 5mil instructions
//math: if x=62 then inner loop takes 4942920, have to fill 57080 cycles
delay_cycles(216); //y
cycles++; ///1 cycle
///2 cylces to jump to top
//math: outer=(3+1+y+1+2)*255+4=57080
//math: y=(57080-4)/255)-(3+1+0+0+1+2)
//math: if y=216.827450980392156862745098039216 then outer loop cylces is 57080
//math: if y=216 then outer loop cycles is off by 211 cycles. z=211
delay_cycles(211); //z
/* ___ end waiting 1 second ___ */
setup_timer_1(T1_DISABLED); //turn of counter to prevent corruption while grabbing value
if (t1_overflow) //check one last time for overflow
freqc_high++;
freqc_low=get_timer1(); //get timer1 value as the least sign. 16bits of freq counter
freq=make32(freqc_high,freqc_low); //use new make32 function to join lsb and msb
printf("%LU Hz\r\n",freq); //and print frequency
08.04.2007, 17:58
Сказал спасибо: 936
Извини до 10 кгц не нашлось есть на 50 мгц
Выдрал из примеров CCS...
EX_FREQC.C
A 50 mhz frequency counter
08.04.2007, 18:26
фика себе задача поставлена... А дискретизация (точность ?)Скока разрядов ? Какая частота кварца ? Какой контроллер ? На когда надо ?
У докусика 32 разряда и 20 мегагерц, в общем, хватит наверняка...
08.04.2007, 18:47
Благодарю, Dosikus
на асме несколько вариантов видел,
а на Си этот первый!
попробую перелепить под свои нужды
08.04.2007, 18:55
Сказал спасибо: 936
Не забудь , что писано для CCS PICC .
08.04.2007, 19:00
для urry
PIC16F84
кварц-4МГц
точность- 5 разрядов
работа факультативная на общественных началах,
поэтому сроки не оговариваются
08.04.2007, 19:12
Сказал спасибо: 936
Как всегда видишь-не надо,как понадобиться хрен найдешь.
Роюсь по нету и ничего на С не нахожу....
08.04.2007, 19:40
под 16ф84 прога не прокатит. Если не ошибаюсь (давно не программировал на 84) там таймера 1 в принципе нет, там таймер 0 и он 8-разрядный, а не 16 - как в проге. Хотя, если честно... не помню... в последнее время возился с пик 12 ...Короче, проще написать самостоятельно.Счас на работе мучаюсь с биллингом, только в среду вечером смогу написать и отладить. Если устраивает, дайте ответ. Работы немного...
08.04.2007, 20:09
Сказал спасибо: 936
Можно переделать на 628...
Но заявка была (см шапку) на PIC вообще...
Часовой пояс GMT +4, время: 08:55.
