Здавствуйте!
Как "KAZIMUGUR" сообшил вам ест в нете версия 7.1 SP4 на Proteus.
https://kazus.ru/forum/topic_7503-0-asc-170.html
http://rapidshare.com/files/41610138...crack.zip.html
http://www.4shared.com/file/19550318/8563ded1/PR3.html
А вот и инструкция по инсталяции.
Complete license professional Proteus 7.1 service is pack 4 + the key
Installation:
1 - if Proteus is already established remove its
2 - run licence.exe, remove the established keys and you will establish new
3 - run setup71.0400.exe, you will establish Proteus delight in!
А вот що то новово.
Added:
- PIC18K series.
- PIC16F91X models
- PICDEM MC (mechatronics) virtual evaluation board
- ATTiny 13 model
- AT2FXXXX and M45PEXX serial flash memories.
- INA117 high common mode voltage differance amp.
- LM134/234/334 adjustable current sources
- IR2101/IR2102 high and low side mosfet drivers.
- TL783 regulator.
- LM34/LM35/LM45/LM50 temperature sensors.
- AD693 sensor transmitter.
- Improved hit-testing logic for labels, wires and pin ends in ISIS.
- Improved DC and transient convergence and convergence diagnostics in PROSPICE.
- Clipboard commands (cut/copy/paste) to the edit menu in ARES.
- Display of component rotation on status bar in ARES.
- Universal LCD Panel model + specific 3 1/2 and 4 digit displays
- LT1030 and LT1030-5 regulator models
Fixed:
- Rotate whilst place/drag can move pins/pads off grid (ISIS/ARES)
- Graphs not printing in colour (ISIS)
- Print preview not updated when colour checkbox is clicked (ISIS/ARES).
- Problem in translation of SPICE2 POLY sources where coefficents are zero (PROSPICE).
- Data corruption where components with embedded tracks are copied through the clipboard. (ARES)
- Polygon merge problems and crashes where there are coincident points in the groundplane boundary. (ARES)
- Erratic behaviour when clicking right - second click is sometimes missed - (ARES)
- DRC is regenerated when disabled after undo (ARES).
- Deleting manually entered ratsnest lines produces corrupt net names (ARES).
- Orientation bar restricts angle to orthogonal only (ARES).
- UAE when selecting padstack mode after re-loading layout (ARES).
- Various issues related to keyboard mapping.
- Problem with DOUT in MAX7219 model
- Oscillscope and Logic analyser cause graph based simulation to fail.
- UAE when writing CNEN2 register of PIC24.
- Zero SRAM size in ATMEGA 64.
- Wrong part description of 74141.
- Installer hangs on some X64 systems.
- UAEs with keyboard short-cuts in the MPLAB viewer.
- Various deadlocks between ISIS and the MPLAB resulting in 'server busy' dialog.
- Strange behaviour with the mouse focus when closing graph windows and/or the 3D viewer.
- Licencing issue with DVCO.DLL
Ето из "sonsivri" форуме!
