15.03.2009, 15:26
Сказал спасибо: 3,207
Сказали Спасибо 3,010 раз(а) в 686 сообщении(ях)
Многие книги, из тех что спрашивали есть там:
http://www.radioscanner.ru/files/electronics/
Прямо с сервера, с возможностью докачки.
Эти 2 пользователя(ей) сказали Спасибо lsa за это сообщение:
16.04.2009, 12:08
Сказал спасибо: 43
Сказали Спасибо 15 раз(а) в 15 сообщении(ях)
16.04.2009, 20:18
Сказал спасибо: 1,463
Сказали Спасибо 6,183 раз(а) в 1,468 сообщении(ях)
Книги от SwanSwan
Уговорили, продолжаем.
На счет аннотации - могу на английском, а то я так год буду перекачивать. На English пойдет?
Intelligent Sensor Design Using the Microchip dsPIC (Embedded Technology)
http://letitbit.net/download/5656dbc...ology.pdf.html
Описание:
This is an introductory text on making sensors "intelligent". It meets that need well.
This book is not a text on DSP. If you need a text book on DSP, get a DSP text book.
This is not a text on PIC microcontrollers. There are several from introductory to advanced in print.
Описание взято с Amazon.com
18.04.2009, 00:32
Embedded Systems (World Class Designs)
http://letitbit.net/download/d2e2f85...igns_.pdf.html
Описание: Newnes has worked with Robert Pease, a leader in the field of analog design to select the very best design-specific material that we have to offer. The Newnes portfolio has always been know for its practical no nonsense approach and our design content is in keeping with that tradition. This material has been chosen based on its timeliness and timelessness. Designers will find inspiration between these covers highlighting basic design concepts that can be adapted to today's hottest technology as well as design material specific to what is happening in the field today. As an added bonus the editor of this reference tells you why this is important material to have on hand at all times. A library must for any design engineers in these fields.
‹center›
[img]nuke/users_images/18042009/4494029.jpg[/img]‹/center›
18.04.2009, 01:18
PIC Basic Projects 30 Projects using PIC BASIC and PIC BASIC PRO
http://letitbit.net/download/0c11072...C_PRO.pdf.html
Описание: I had never done any sort of programming before and I was also totally unfamiliar with BASIC. This book helped to introduce the basics in an easy to understand way. I recommend this book to anyone just getting started like me who knows nothing about the PIC and BASIC programming. After reading the book I feel like I can tackle my own simple projects!
18.04.2009, 12:59
Аппаратные хитрости использования PIC-контроллеров
http://letitbit.net/download/129f34b..._____.pdf.html
18.04.2009, 13:30
Product selection guide- Microprocessor - PICxxx range
http://letitbit.net/download/0d923d7...chip_.pdf.html
18.04.2009, 14:14
DSP Applications Using C and the TMS320C6x DSK
http://letitbit.net/download/b75f08f...x_DSK.pdf.html
Описание: This book is a requirement for a DSP class that I am taking. However, I feel that this book is not meant as a learning guide on DSP but more as a hands-on type lab manual. Any professors out there looking to use this book as a staple to the "classroom" side of a Digital Signal Processing should reconsider and think about using it for the "lab" portion of the class.
The instructions for going through each example, step-by-step is rather cumbersome because of the lack of structure (i.e. Step 1, Step 2, but rather in paragraph form). Additionally, each example builds on the last which makes it very cumbersome in adding all of the programs. For instance, in Chapter 2, Example 2.4 requires that you use the same support files as in Example 2.3. Example 2.3 refers you to use the same support files as in Example 2.2. Example 2.2 refers you to Example 2.1 and 1.1 which also refers you to other files. You will spend nearly a half hour trying to figure out which programs to you use. The layout and format of this book make it quite inefficient, but once you learn to decipher it, it is a decent "lab" style book.
18.04.2009, 14:28
C++ in 12 days
http://letitbit.net/download/26bce8b..._days.pdf.html
Описание: Visual C++™ in 12 Easy Lessons
18.04.2009, 15:31
AVR animated tutorials
http://letitbit.net/download/993b46d...rials.zip.html
Описание Анимированный учебник по ассемблеру AVR для 2313, выполненный на Flash
Часовой пояс GMT +4, время: 02:37.
