Закрытая тема
Непрочитано 11.07.2007, 22:25   #1
spasbyspas
spasbyspas на пути к лучшему
По умолчанию Протеус 7.1sp4
Здавствуйте!
Как "KAZIMUGUR" сообшил вам ест в нете версия 7.1 SP4 на Proteus.
https://kazus.ru/forum/topic_7503-0-asc-170.html
http://rapidshare.com/files/41610138...crack.zip.html
http://www.4shared.com/file/19550318/8563ded1/PR3.html
А вот и инструкция по инсталяции.
Complete license professional Proteus 7.1 service is pack 4 + the key
Installation:
1 - if Proteus is already established remove its
2 - run licence.exe, remove the established keys and you will establish new
3 - run setup71.0400.exe, you will establish Proteus delight in!
А вот що то новово.
Added:
- PIC18K series.
- PIC16F91X models
- PICDEM MC (mechatronics) virtual evaluation board
- ATTiny 13 model
- AT2FXXXX and M45PEXX serial flash memories.
- INA117 high common mode voltage differance amp.
- LM134/234/334 adjustable current sources
- IR2101/IR2102 high and low side mosfet drivers.
- TL783 regulator.
- LM34/LM35/LM45/LM50 temperature sensors.
- AD693 sensor transmitter.
- Improved hit-testing logic for labels, wires and pin ends in ISIS.
- Improved DC and transient convergence and convergence diagnostics in PROSPICE.
- Clipboard commands (cut/copy/paste) to the edit menu in ARES.
- Display of component rotation on status bar in ARES.
- Universal LCD Panel model + specific 3 1/2 and 4 digit displays
- LT1030 and LT1030-5 regulator models
Fixed:
- Rotate whilst place/drag can move pins/pads off grid (ISIS/ARES)
- Graphs not printing in colour (ISIS)
- Print preview not updated when colour checkbox is clicked (ISIS/ARES).
- Problem in translation of SPICE2 POLY sources where coefficents are zero (PROSPICE).
- Data corruption where components with embedded tracks are copied through the clipboard. (ARES)
- Polygon merge problems and crashes where there are coincident points in the groundplane boundary. (ARES)
- Erratic behaviour when clicking right - second click is sometimes missed - (ARES)
- DRC is regenerated when disabled after undo (ARES).
- Deleting manually entered ratsnest lines produces corrupt net names (ARES).
- Orientation bar restricts angle to orthogonal only (ARES).
- UAE when selecting padstack mode after re-loading layout (ARES).
- Various issues related to keyboard mapping.
- Problem with DOUT in MAX7219 model
- Oscillscope and Logic analyser cause graph based simulation to fail.
- UAE when writing CNEN2 register of PIC24.
- Zero SRAM size in ATMEGA 64.
- Wrong part description of 74141.
- Installer hangs on some X64 systems.
- UAEs with keyboard short-cuts in the MPLAB viewer.
- Various deadlocks between ISIS and the MPLAB resulting in 'server busy' dialog.
- Strange behaviour with the mouse focus when closing graph windows and/or the 3D viewer.
- Licencing issue with DVCO.DLL
Ето из "sonsivri" форуме!
spasbyspas вне форума
Непрочитано 14.07.2007, 01:09   #2
avr123-nm-ru
Сказал спасибо: 76
avr123-nm-ru на пути к лучшему
По умолчанию
ATTiny13 - попробовал - шустро работает.
avr123-nm-ru вне форума
Непрочитано 14.07.2007, 02:45   #3
shihaidong
shihaidong на пути к лучшему
По умолчанию full crack!!!
http://rapidshare.com/files/42647079...PDATE.rar.html
8051 ok!
shihaidong вне форума
Непрочитано 14.07.2007, 13:46   #4
avr123-nm-ru
Сказал спасибо: 76
По умолчанию
Кто может перекинте библы на slil.ru или
easy-share.com
Непрочитано 14.07.2007, 15:43   #5
urry
Аватар для urry
Сказали Спасибо 106 раз(а) в 66 сообщении(ях)
urry на пути к лучшему
По умолчанию
Сообщение от avr123-nm-ru
Шустро - это как ? Меня интересует, если память МК забита больше, чем наполовину - нет этих раздражающих сообщений с частотой 1000 штук в секунду ?
urry вне форума
Непрочитано 14.07.2007, 15:53   #6
dimonbest
Аватар для dimonbest
Сказал спасибо: 5
Сказали Спасибо 18 раз(а) в 14 сообщении(ях)
dimonbest на пути к лучшему
По умолчанию
Сообщение от urry
Как же без этого, конечноже есть сообщения... Правда это если coff загружать, а если hex то все вроде как нормально...
dimonbest вне форума
Непрочитано 14.07.2007, 17:13   #7
Self_
Self_ на пути к лучшему
По умолчанию
Выложите, пожалуйста, где не будь сами ключи или крек, а то влом качать ради крека 40мб.
Self_ вне форума
Непрочитано 14.07.2007, 17:20   #8
dimonbest
Сказал спасибо: 5
По умолчанию
Сообщение от Self_
Вот файл лицензии...
Прикрепленный файл: 1797435.rar
Непрочитано 14.07.2007, 17:26   #9
dimonbest
Сказал спасибо: 5
По умолчанию
Кто подскажет что такое ELECTRA?
Непрочитано 14.07.2007, 17:27   #10
Self_
По умолчанию
dimonbest огромное спасибо за помощь
Self_ вне форума
Закрытая тема
Программы Протеус shapranpetr Микроконтроллеры, АЦП, память и т.д 0 11.08.2009 13:29
Proteus 7.1sp4 и АТмега8 ARM7TDMI Микроконтроллеры, АЦП, память и т.д 1 26.03.2008 16:52
Протеус 220в a-l-e-x Proteus 5 25.09.2007 20:16
Протеус 7.1sp2 haishen Proteus 528 22.09.2007 22:46
Протеус 6.96 !!! haishen Proteus 3 11.04.2007 20:48
Часовой пояс GMT +4, время: 22:34.
