25.10.2013, 09:43
#6981
Сказал спасибо: 337
Сказали Спасибо 30,207 раз(а) в 6,808 сообщении(ях)
Re: Книги
The Makerspace Workbench: Tools, Technologies, and Techniques for Making
Название: The Makerspace Workbench: Tools, Technologies, and Techniques for Making
Автор: Kemp Adam
Издательство: Maker Media
Год: 2013
Страниц:
ISBN: 978-1-449-35567-8
Формат: PDF
Язык: English
Create a dynamic space for designing and building DIY electronic hardware, programming, and manufacturing projects. With this illustrated guide, you’ll learn the benefits of having a Makerspace—a shared space with a set of shared tools—that attracts fellow makers and gives you more resources to work with. You’ll find clear explanations of the tools, software, materials, and layout you need to get started—everything from basic electronics to rapid prototyping technology and inexpensive 3D printers.
A Makerspace is the perfect solution for many makers today. While you can get a lot done in a fully-decked out shop, you’ll always have trouble making space for the next great tool you need. And the one thing you really miss out on in a personal shop is the collaboration with other makers. A Makerspace provides you with the best of both worlds.
Perfect for any maker, educator, or community, this book shows you how to organize your environment to provide a safe and fun workflow, and demonstrates how you can use that space to educate others.
Последний раз редактировалось mihail62; 17.12.2016 в 11:30.
Эти 3 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
25.10.2013, 18:53
#6982
Сказал спасибо: 337
Re: Книги
Modern Power Electronics and AC Driver
Название: Modern Power Electronics and AC Driver
Автор: Boze Bimal K.
Издательство: Prentige Hall PTR
Год: 2002
Страниц: 738
ISBN: 0-13-016743-6
Формат: PDF
Язык: английский
Современная силовая электроника и преобразователи переменного тока.
Книга является настольной книгой инженера-приводчика. Программа Matlab/Simulink ссылается на эту книгу как на источник. В книге содержатся описания железа, а также принципов управления преобразователями переменного тока.
Оглавление
Описание силовых полупроводниковых приборов таких как диоды, тиристоры (GTO, MCT, IGCT), симисторы, транзисторы (BPT, BJT, SIT, IGBT, Mosfet).
Машины переменного тока.
Асинхронные, синхронные, индукционные.
Выпрямители диодные, тиристорные.
Управление, проблемы электромагнитной совместимости и др.
Преобразователи частоты - тиристорные, матричные, транзисторные.
Автономный инвертор напряжения (АИН).
Разновидности принципы управления - скалярное векторное и др.
Автономный инвертор тока (АИТ).
Преобразователи для индукционных машин.
Преобразователи для синхронных машин.
Экспертные системы.
Фаззи логика.
Нейронные сети.
Последний раз редактировалось mihail62; 17.12.2016 в 17:32.
Эти 6 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
25.10.2013, 20:23
#6983
Сказал спасибо: 4,294,967,295
Сказали Спасибо 257 раз(а) в 55 сообщении(ях)
Re: Книги
Е. В. Фурсова, Антенны (2009) Е. В. Фурсова, Антенны.pdf 2,35 Мб
Эти 11 пользователя(ей) сказали Спасибо Timofejj за это сообщение:
25.10.2013, 23:08
#6984
Сказал спасибо: 337
Re: Книги
Электропривод
Автор: Кисаримов Р.А.
Издательство: ИП РадиоСофт
Год: 2008
Страниц: 353
ISBN: 978-5-93037-116-5
Формат: PDF
Язык: русский
В справочнике приведены основные понятия об электроприводе с асинхронным двигателем и о его регулировании, характеристиках асинхронного двигателя и его выборе.
Описано устройство электрических аппаратов управления и защиты, даны понятия об элементах и устройствах, применяемых в системах управления электропривода - полупроводниковых приборах и интегральных системах, в том числе устройствах цифровой и аналоговой техники. Приведены электрические схемы взаимодействия элементов и устройств электропривода.
Книга предназначена для электриков, работа которых связана с монтажом, наладкой и обслуживанием электропривода, для учащихся и для всех интересующихся данным предметом.
Последний раз редактировалось mihail62; 02.10.2016 в 20:46.
Эти 4 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
26.10.2013, 12:35
#6985
Сказал спасибо: 409
Сказали Спасибо 9,601 раз(а) в 1,030 сообщении(ях)
Re: Книги
Название: Serial Port Complete: COM Ports, USB Virtual COM Ports, and Ports for Embedded Systems
Автор: Jan Axelson
Год: 2007
Страниц: 400
Формат: PDF
Язык: Английский
Качество: Оригинал
PC COM ports, USB virtual COM ports, and ports in embedded systems are all addressed in this updated guide to programming, interfacing, and using serial ports. Topics include using .NET’s SerialPort class for COM-port communications on PCs; upgrading existing RS-232 designs to USB or wireless networks; and creating serial networks of embedded systems and PCs. Example circuits and code provide a quick start to projects. Installation and maintenance staff will also find tips for ensuring reliable operation and problem tracking.
Скачать с depositfiles.com
Скачать с turbobit.net
Эти 7 пользователя(ей) сказали Спасибо jtp за это сообщение:
26.10.2013, 20:06
#6986
Сказал спасибо: 316
Сказали Спасибо 1,603 раз(а) в 283 сообщении(ях)
Re: Книги
Реестр Windows 7
Автор: Кокорева О.
Формат: pdf
Язык: русский
Год издания: 2010
Страниц: 704
Книга посвящена реестру операционной системы Windows 7, настройка и функционирование которой существенно зависит от него. Основное внимание уделено изменениям, внесенным в Windows 7, поскольку многие старые советы касательно редактирования реестра более ранних версий Windows в Windows 7 работать не будут.
Эти 10 пользователя(ей) сказали Спасибо -Serge- за это сообщение:
26.10.2013, 21:10
#6987
Сказал спасибо: 337
Re: Книги
Промышленные приборы и средства автоматизации: Справочник
Название: Промышленные приборы и средства автоматизации: Справочник
Автор: Черенков В.В.(ред.)
Издательство: Машиностроение
Год: 1987
Страниц: 847
Формат: DJVU
Язык: русский
В справочнике описаны широко применяемые в народном хозяйстве автоматические приборы, средства регулирования, централизованного контроля и управления, информационно-вычислительные комплексы, устройства телемеханики. Рассмотрены приборы для измерения, контроля и регулирования температуры, давления, расхода, уровня, химического состава газов и жидкостей. Приведены рекомендации по выбору и эксплуатации средств автоматизации.
Справочник предназначен для инженерно-технических работников, занимающихся проектированием, монтажом, наладкой и эксплуатацией систем автоматики.
27.10.2013, 09:12
#6988
Сказал спасибо: 337
Re: Книги
Эксплуатация и ремонт электрооборудования и средств автоматизации
Название: Эксплуатация и ремонт электрооборудования и средств автоматизации
Автор: Пястолов А.А.(ред.)
Издательство: Колос
Год: 1993
Страниц: 350
ISBN: 5-10-001173-4
Формат: DJVU
Язык: русский
Рассмотрены вопросы технической эксплуатации электрооборудования, используемого в агропромышленном производстве. В третье издание дополнительно включены сведения об испытаниях, эксплуатации и ремонте средств автоматизации, организации службы эксплуатации в АПК.
Второе издание (1984 г.) вышло под заглавием «Эксплуатация и ремонт электроустановок».
Для учащихся средних специальных учебных заведений по специальности «Электрификация и автоматизация сельского хозяйства».
Сказали "Спасибо" mihail62
27.10.2013, 13:39
#6989
Сказал спасибо: 337
Re: Книги
Преобразовательная техника
Автор: Гельман М.В., Дудкин М.М., Преображенский К.А.
Издательство: ЮУрГУ
Год: 2009
Страниц: 427
Формат: PDF
Язык: русский
В учебном пособии рассмотрены элементы силовой электроники и приведены схемы выпрямителей, преобразователей постоянного и переменного напряжений, ведомых и автономных инверторов, обратимых преобразователей напряжения, преобразователей частоты и других устройств преьбразовательной техники. Выполнен анализ процессов, приведены элементы расчета и характеристики схем. Большое внимание уделено энергетическим показателям.
27.10.2013, 15:24
#6990
Сказал спасибо: 337
Re: Книги
Устройство, техническое обслуживание и ремонт лифтов
Название: Устройство, техническое обслуживание и ремонт лифтов
Автор: Манухин С.Б., Нелидов И.К.
Издательство: Академия
Год: 2004
Страниц: 336
ISBN: 5-7695-1406-X
Формат: DJVU
Язык: русский
Рассмотрены устройство, принцип действия и способы регулировки механического и электрического оборудования лифтов. Предложены правила чтения электрических схем наиболее распространенных моделей лифтов с релейно-контакторными низковольтными комплектными устройствами. Освещены вопросы организации надзора, технического обслуживания, ремонта и эксплуатации лифтов и др.
Для учащихся учреждений начального профессионального образования.
Часовой пояс GMT +4, время: 23:52.
