20.02.2017, 18:27
Сказал спасибо: 337
Сказали Спасибо 30,207 раз(а) в 6,808 сообщении(ях)
Re: Книги
Raspberry Pi Computer Architecture Essentials
Название: Raspberry Pi Computer Architecture Essentials
Автор: Dennis Andrew K.
Издательство: Packt Publishing
Год: 2016
Страниц: 233
ISBN: 1784397970, 978-1784397975
Формат: PDF, DJVU
Язык: English
With the release of the Raspberry Pi 2, a new series of the popular compact computer is available for you to build cheap, exciting projects and learn about programming. In this book, we explore Raspberry Pi 2's hardware through a number of projects in a variety of programming languages. We will start by exploring the various hardware components in detail, which will provide a base for the programming projects and guide you through setting up the tools for Assembler, C/C++, and Python.
We will then learn how to write multi-threaded applications and Raspberry Pi 2's multi-core processor. Moving on, you'll get hands on by expanding the storage options of the Raspberry Pi beyond the SD card and interacting with the graphics hardware. Furthermore, you will be introduced to the basics of sound programming while expanding upon your knowledge of Python to build a web server. Finally, you will learn to interact with the third-party microcontrollers.
From writing your first Assembly Language application to programming graphics, this title guides you through the essentials.
На всякий Гугол свой Йобибайт найдется!
Эти 3 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
20.02.2017, 18:39
Сказал спасибо: 456
Сказали Спасибо 47,137 раз(а) в 3,118 сообщении(ях)
Re: Книги
Терморезисторы. Шефтель И.Т. 1973
10.5 MB, DjVu, OCR
https://yadi.sk/i/0iKsiZy93EJXSZ
http://depositfiles.com/files/qhinjrt2h
Scan: AAW, DjVuing: pohorsky
Владимир
Эти 13 пользователя(ей) сказали Спасибо AversT за это сообщение:
agnnik (20.02.2017), beebeep (24.02.2017), Drex (01.03.2017), mcu51 (03.03.2017), nckvrb (29.03.2017), Nikolay-starikov (26.02.2017), safoso (21.02.2017), scenter (20.02.2017), seanta (24.02.2017), stiv_fil (24.02.2017), valesyk (20.02.2017), vasilenko_pit (24.02.2017), vrt90 (25.02.2017) |
20.02.2017, 20:05
Сказал спасибо: 456
Re: Книги
В помощь радиолюбителю. Выпуск 15. Сост. Васильев А.А. 1963
2.1 MB, DjVu, OCR https://yadi.sk/i/JUQkolse3EJics
3.9 MB, PDF https://yadi.sk/i/TdCN43SX3EJiiN
6.7 MB, PDF + DjVu http://depositfiles.com/files/5vtkpdapr
DjVuing: pohorsky
Владимир
Эти 14 пользователя(ей) сказали Спасибо AversT за это сообщение:
agnnik (20.02.2017), beebeep (24.02.2017), Chedex (24.02.2017), Drex (01.03.2017), kipiaxxx (21.02.2017), mcu51 (03.03.2017), MonstR007 (03.03.2017), Nikolay-starikov (26.02.2017), RA0WKC (09.03.2017), safoso (21.02.2017), scenter (20.02.2017), seanta (24.02.2017), valesyk (20.02.2017), vasilenko_pit (24.02.2017) |
20.02.2017, 21:00
Сказал спасибо: 456
Re: Книги
В помощь радиолюбителю. Выпуск 17. Сост. Васильев А.А. 1964
3.9 MB, DjVu, OCR https://yadi.sk/i/icS0u1Vn3EJqPM
10.2 MB, PDF https://yadi.sk/i/DClmxC-R3EJqTM
14.35 MB, PDF + DjVu http://dfiles.ru/files/uo9q03ebg
Scan: Владислав_72 ( malshin), DjVuing: pohorsky
Владимир
agnnik (20.02.2017), beebeep (24.02.2017), Chedex (24.02.2017), Drex (01.03.2017), kipiaxxx (21.02.2017), mcu51 (03.03.2017), Nikolay-starikov (26.02.2017), pepek (23.02.2017), RA0WKC (09.03.2017), safoso (21.02.2017), scenter (20.02.2017), seanta (24.02.2017), valesyk (20.02.2017), vasilenko_pit (24.02.2017) |
20.02.2017, 23:05
Сказал спасибо: 337
Re: Книги
How to Build a Robot
Название: How to Build a Robot
Автор: Parkyn J.
Издательство: Dennis Publishing Ltd.
Год: 2014
Страниц: 148
ISBN: 1-78106-313-3
Формат: PDF
Язык: English
Великолепно иллюстрированное практическое руководство по созданию вашего первого робота на базе платформы Ардуино.
The Practical Guide to building your very first bot. Arduino is a platform that many hobbyists and beginners use for their electronic projects. It’s based around a small credit card-sized computer, not unlike a Raspberry Pi, but even simpler to use. It doesn’t have (or need) an operating system, but you can write and upload programs to it and get it to do all kinds of things.
Arduino makes it incredibly easy to start building projects on your own. It comes with a simple software environment, complete with sample programs foryou to upload to the device. And it’s incredibly cheap, too. Arduinos can be bought for ?20 - even less if you shop around - and you can pick up a selection of electronic components to play with for only a few pounds.
But the really great thing about working with Arduino compared to other
computer projects is that you can see the results of your programming directly affecting or physically interacting with the world around you. Instead of making graphics appear on a screen, for exam pie, you can program areal light to switch itself on and off, oryour programs can receive and interpret information about the real world via a sensor.
Individually, these functions might not sound Earth-shattering. But when you
start combining them together and adding others-adistance sensor to interpret the environment, say, and some motors for autonomous motion - suddenly you’re starting to build a robot.
And that’s exactly what you’ll be doing if you follow the projects in this book. We’ll start by making simple projects and gradually build it all together until we’ve created a complete robot. You won’t need to learn anything massively complicated or use any unfamiliar equipment. And if you’re still feeling daunted, remember if the author of this book can go from knowing almost nothing to building his own robot, then anyone can.
Сказали "Спасибо" mihail62
21.02.2017, 00:08
Сказал спасибо: 337
Re: Книги
Управление электронно-лучевой сваркой
Название: Управление электронно-лучевой сваркой
Автор: Лаптенок В.Д., Мурыгин А.В., Серегин Ю.Н., Браверман В.Я.
Издательство: Красноярск: САА
Год: 2000
Страниц: 234
ISBN: 5-86433-121-Х
Формат: PDF
Язык: русский
В монографии систематизированы сведения о принципах контроля информации и системах управления процессом электронно-лучевой сварки (ЭЛС). Изложены физические основы ЭЛС, принципы позиционирования электронного пучка по стыку свариваемого соединения, контроля плотности распределения электронного пучка, управления глубиной проплавления. Проведен анализ помехозащищенности устройств управления ЭЛС, изложены вопросы их технической реализации с использованием микропроцессорной техники и микроЭВМ.
Работа предназначена для инженеров, студентов и научных работников, специализирующихся в области технологии и оборудования сварочного производства.
Эти 5 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
21.02.2017, 07:58
Сказал спасибо: 337
Re: Книги
Расчет трехмерных электромагнитных полей
Название: Расчет трехмерных электромагнитных полей
Автор: Тозони О.В., Маергойз И.Д.
Издательство: К.: Техніка
Год: 1974
Страниц: 352
Формат: DJVU
Язык: русский
В книге изложен метод расчета на ЭВМ статических и квазистационарных трехмерных полей в электромагнитных системах устройств электротехники и радиотехники. Этот метод позволяет автоматизировать проектирование новых конструкций электромагнитных систем и улучшить существующие. Сущность его заключается в замене поля в неоднородной среде эквивалентным в вакууме с помощью введения дополнительных вторичных источников в местах неоднородности среды. При этом расчет сводится к решению интегральных уравнений.
Книга рассчитана на инженерно-технических работников, которые занимаются автоматизацией проектирования электро- и радиотехнических устройств и расчетами статических и квазистационарных электромагнитных полей.
Эти 4 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
21.02.2017, 11:47
Сказал спасибо: 456
Re: Книги
Расчет апертурных корректоров. Хромой Б.П. 1965
3 MB, DjVu, OCR
https://yadi.sk/i/2SsBPJYY3EKorq
http://depositfiles.com/files/sjjzriico
DjVuing: pohorsky
Владимир
Эти 11 пользователя(ей) сказали Спасибо AversT за это сообщение:
AYuM (24.02.2017), beebeep (24.02.2017), Chedex (24.02.2017), kipiaxxx (23.02.2017), mcu51 (03.03.2017), Nikolay-starikov (26.02.2017), scenter (21.02.2017), seanta (24.02.2017), stiv_fil (24.02.2017), valesyk (21.02.2017), vasilenko_pit (24.02.2017) |
21.02.2017, 12:00
Сказал спасибо: 456
Re: Книги
Линейные усилители переменного сигнала. Старостин А.Н., Кобяк А.Т., Осипов А.М. 1982
2.3 MB, DjVu, OCR https://yadi.sk/i/JGz5YN8f3EKsZm
2.5 MB, PDF https://yadi.sk/i/xRF8F3D03EKsd3
5.3 MB, PDF + DjVu http://dfiles.ru/files/5l25w1lx4
DjVuing: pohorsky
Владимир
agnnik (22.02.2017), AYuM (24.02.2017), beebeep (24.02.2017), Chedex (24.02.2017), kipiaxxx (21.02.2017), mcu51 (03.03.2017), nckvrb (01.04.2017), Nikolay-starikov (26.02.2017), scenter (21.02.2017), seanta (24.02.2017), sfantom (26.02.2017), stiv_fil (24.02.2017), valesyk (21.02.2017), vasilenko_pit (24.02.2017) |
22.02.2017, 10:10
Сказал спасибо: 337
Re: Книги
Intelligent Network Video, Second Edition
Название: Intelligent Network Video, Second Edition
Автор: Fredrik Nilsson, Communications Axis
Издательство: CRC Press
Год: 2017
Страниц: 378
ISBN: 978-1-4665-5521-1, 146655521
Формат: PDF
Язык: English
Continuing in the tradition of the bestselling first edition, this book examines networked surveillance video solutions. It provides the latest details on industry hardware, software, and networking capabilities of the latest cameras and DVRs.
It addresses in full detail updated specifications on MPEG-4 and other digital video formats, resolution advantages of analog v. digital, intelligent video capabilities, frame rate control, and indoor/outdoor installations factors. New chapters include cloud computing, standards, and thermal cameras.
Content
1. The evolution of video surveillance systems
2. The components of network video
3. Network cameras
4. Camera technologies
5. Thermal cameras
6. Video compression technologies
7. Audio technologies
8. Video encoders
9. Wired networks
10. Wireless networks
11. Networking technologies
12. Servers and storage
13. Video management
14. Hosted video solutions
15. Intelligent video
16. Intelligent video applications
17. System design considerations
Эти 2 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
Часовой пояс GMT +4, время: 21:29.
