02.04.2010, 22:48
Сказал спасибо: 522
Re: Книги
Сообщение от SwanSwan
Переносные стрелочные комбинированные приборы. Выпуск 1
А существует ли 2-й выпуск?
03.04.2010, 10:42
Сказал спасибо: 1,463
Сказали Спасибо 6,181 раз(а) в 1,468 сообщении(ях)
Re: Книги
Basic Electrical Installation Work
Hull, 2005
Basic Electrical Installation Work has helped thousands of students to gain their first qualification in electrical installation. Now in its fourth edition, this book has been completely restructured to provide a specific match to the requirements of the Installation route of the 2330 Level 2 Certificate in Electrotechnical Technology from City & Guilds, and will also prove an essential purchase for students of the Level 2 NVQ in Installing Electrotechnical Systems (2356).
Скачать:
http://uploading.com/files/69648me7/...tion_Work.rar/
http://shareflare.net/download/8189...._Work.rar.html
03.04.2010, 11:18
Re: Книги
Digital Systems Design with FPGAs and Cplds
Ian Grout, 2009
This is the eBook version of the printed book. If the print book includes a CD-ROM, this content is not included within the eBook version. The Definitive, Up-to-Date Guide to Digital Design with SystemVerilog: Concepts, Techniques, and Code To design state-of-the-art digital hardware, engineers first specify functionality in a high-level Hardware Description Language (HDL)--and today's most powerful, useful HDL is SystemVerilog, now an IEEE standard. Digital System Design with SystemVerilog is the first comprehensive introduction to both SystemVerilog and the contemporary digital hardware design techniques used with it. Building on the proven approach of his bestselling Digital System Design with VHDL, Mark Zwolinski covers everything engineers need to know to automate the entire design process with SystemVerilog--from modeling through functional simulation, synthesis, timing simulation, and verification. Zwolinski teaches through about a hundred and fifty practical examples, each with carefully detailed syntax and enough in-depth information to enable rapid hardware design and verification.Coverage includesUsing electronic design automation tools with programmable logic and ASIC technologiesEssential principles of Boolean algebra and combinational logic design, with discussions of timing and hazardsCore modeling techniques: combinational building blocks, buffers, decoders, encoders, multiplexers, adders, and parity checkersSequential building blocks: latches, flip- flops, registers, counters, memory, and sequential multipliersDesigning finite state machines: from ASM chart to D flip-flops, next state, and output logicModeling interfaces and packages with SystemVerilogDesigning testbenches: architecture, constrained random test generation, and assertion-based verificationDescribing RTL and FPGA synthesis modelsUnderstanding and implementing Design-for-TestExploring anomalous behavior in asynchronous sequential circuitsPerforming Verilog-AMS and mixed-signal modelingWhatever your experience with digital design, older versions of Verilog, or VHDL, this book will help you discover SystemVerilog's full power and use it to the fullest.
Скачать:
http://uploading.com/files/f54cd9ab/DigSysDesFPGA.rar/
http://shareflare.net/download/7941....sFPGA.rar.html
03.04.2010, 14:40
Re: Книги
Диоды и тиристоры
А.А.Чернышев, 1976
В справочнике в табличной форме приводятся сведения о важнейших электрических параметрах, режимах измерения, предельно допустимых режимах работы полупроводниковых диодов и тиристоров, выпускаемых отечественной промышленностью. Даются краткие сведения о технологии, габаритные чертежи и цоколевка приборов.
Справочник рассчитан на широкий круг радиолюбителей и специалистов, занимающихся конструированием и эксплуатацией радиоэлектронной аппаратуры.
Скачать:
http://uploading.com/files/c8a72a11/...tiristory.rar/
http://shareflare.net/download/0663....story.rar.html
Эти 2 пользователя(ей) сказали Спасибо SwanSwan за это сообщение:
03.04.2010, 20:21
Сказал спасибо: 1,966
Сказали Спасибо 183 раз(а) в 61 сообщении(ях)
Re: Книги
Electronic Circuit Design: From Concept to Implementation
Nihal Kularatna, 2008
With growing consumer demand for portability and miniaturization in electronics, design engineers must concentrate on many additional aspects in their core design. The plethora of components that must be considered requires that engineers have a concise understanding of each aspect of the design process in order to prevent bug-laden prototypes. A Electronic Circuit Design allows engineers to understand the total design process and develop prototypes which require little to no debugging before release. It providesstep-by-step instruction featuring modern components, such as analog and mixed signal blocks, in each chapter. The book details every aspect of the design process from conceptualization and specification to final implementation and release. The text also demonstrates how to utilize device data sheet information and associated application notes to design an electronic system. The hybrid nature of electronic system design poses a great challenge to engineers. This book equips electronics designers with the practical knowledge and tools needed to develop problem free prototypes that are ready for release.
Скачать:
http://uploading.com/files/86cdeadc/0849376173.zip/
http://shareflare.net/download/7352....76173.zip.html
500 схем для радиолюбителей. Усилители мощности любительских радиостанций
В. А. Кляровский, 2008
В данной книге представлены схемные решения усилителей мощности любительских радиостанций.
Многие радиолюбители занимаются самостоятельным изготовлением линейных усилителей мощности. Это вызвано, с одной стороны, высокой стоимостью фирменной аппаратуры, а с другой - желанием собрать конструкцию согласно индивидуальным требованиям.
При разработке усилителя автором была поставлена задача создать конструкцию, соответствующую фирменному уровню, но достаточно простую для повторения. В книге подробно описан усилитель в универсальном корпусе, который позволяет применять любые радиолампы от ГУ-50 до ГУ-81М и ГУ-78Б. Рассмотрена схемотехника и работа всех его узлов, наиболее важные схемные и конструктивные решения фирменной аппаратуры. Эти решения можно успешно использовать и для модернизации аппаратуры.
Впервые подробно изложены вопросы охлаждения металлокерамических ламп, защита их по току, порядок настройки всех узлов усилителя.
Книга будет полезна радиолюбителям как при эксплуатации и ремонте, так и в случае приобретения готового усилителя.
Скачать:
По ссылкам - одна и та же книга
Дело панически боялось Мастера.
Пользуюсь с 1992 года
Последний раз редактировалось achertkov; 03.04.2010 в 20:29.
03.04.2010, 20:29
Re: Книги
Аналоги отечественных и зарубежных диодов и тиристоров
В. П. Черепанов, А. К. Хрулев, Ю. Н. Савельев, 1997
Справочник построен в виде таблицы, в которой приведены типономиналы отечественных диодов и тиристоров в соответствии с действующим рубрикатором на полупроводниковые приборы и их зарубежные аналоги с указанием различных фирм-изготовителей США, Японии и Западной Европы. Для удобства работы книга разделена на две части. В первой части приведены зарубежные аналоги отечественных диодов и тиристоров, которые выстроены в алфавитно-цифровой последовательности. Во второй части приводятся отечественные аналоги зарубежных диодов и тиристоров, которые, в свою очередь, также выстроены в алфавитно-цифровой последовательности. Издание рассчитано на специалистов, занимающихся разработкой, эксплуатацией и ремонтом радиоэлектронной аппаратуры, а также на широкий круг радиолюбителей.
Скачать:
http://uploading.com/files/a352a9ef/...Tiristory.rar/
http://shareflare.net/download/7839....story.rar.html
Эти 7 пользователя(ей) сказали Спасибо SwanSwan за это сообщение:
03.04.2010, 22:23
Re: Книги
Scaddan, 2002
This well-known textbook is written for all electrical trainees who want to understand not only how, but why electrical installations are designed, installed and tested in particular ways. Brian Scaddan's approach encourages independent learning with end fo chapter self-assessment questions provided. The material is arranged into logical topic sections rather than following a particular syllabus. This makes the book a handy reference even after the course. However, the book meets the requirements of both Level 2 and 3 of the City & Guilds 2330 Certificate and the Level 3 2356 NVQ and a mapping grid to the learning outcomes is included. The new edition is fully in line with the 17th IEE Edition Wiring Regulations. In addition, the new full colur page design will help make learning easier for students of all abilities. Brian Scaddan, I Eng, MIET, is a consultant for and Honorary Member of City & Guilds. He has over 35 years' experience in Further Education and training. He is Director of Brian Scaddan Associates Ltd, an approved City & Guilds and NICEIC training centre offering courses on all aspects of Electrical Installation Contracting including the C&G 2382, 2391, 2392, 2377 series and NICEIC DISQ courses. He is also a leading author of books on electrical installation. * Fully up-to-date with the 17th Edition IEE Wiring Regulations* Tried and trusted content now with improved page design and in full colour * Covers both Level 2 and 3 in one volume
Скачать:
http://uploading.com/files/e2edm6m3/...tion_Work.rar/
http://shareflare.net/download/2923...._Work.rar.html
03.04.2010, 22:50
Re: Книги
Сообщение от XoDoK11
Транзисторы и их зарубежные аналоги. Том 4 Название Биполярные транзисторы средней и большой мощности сверхвысокочастотные и их зарубежные аналоги. Справочник. Том 4 Автор Петухов В.М. Издательство КУбК-а Год 1997 Страниц 544 Формат djvu Размер 5 МБ ISBN 5-85554-157-6 В четвертом томе четырехтомного справочного издания приводятся электрические и эксплуатационные характеристики полупроводниковых приборов - биполярных транзисторов средней и большой мощности СВЧ.
К сожалению, по указанной ссылке файл скачать неудалось
04.04.2010, 00:08
Сказали Спасибо 1,010 раз(а) в 149 сообщении(ях)
Re: Книги
Сообщение от achertkov
Попробуйте с моего сайтика скачать
Если хотите, чтобы жизнь улыбалась вам, подарите ей своё хорошее настроение
Сказали "Спасибо" svetlana-06-89
Часовой пояс GMT +4, время: 22:11.
