24.07.2009, 21:57
#191
Сказал спасибо: 1,463
Сказали Спасибо 6,181 раз(а) в 1,468 сообщении(ях)
"Atmel AVR Microcontroller Primer: Programming and Interfacing"
Описание:
The copy I received from Amazon (publisher says from Amazon's print-on-demand at order time service) was very poor print quality, and a large number of pages, example code, tables, diagrams were competely unreadable. The publisher sent me a replacement copy at their expense from their own printer, which is very good print quality.
This book serves as a decent introduction to microcontrollers and the AVR in particular, giving descriptions of what things such as EEPROM, TWI, PWM, ADC, USART, etc. are and do, and how to talk to them in C code. Talks about interrupt theory and how to use them in C code, looks liek a good bit od discussion and example about timer interrupt and timing things. Advanced users will likely skip over some things such as descriptions of different kinds of switches (momentary pushbutton, DIPs). I was hopin gfor a bit more about controlling DC motors than I see here.
If you already have experience with micros, this may be a bit elementary for you. If you're new to micros, their features, peripherals, and controlling things, this looks like a good introduction.
Скачать: http://uploading.com/files/J48SKBXS/...acing.pdf.html
‹center›
[img]nuke/users_images/24072009/9896750.jpg[/img]‹/center›
24.07.2009, 22:14
#192
"Basic for PIC Microcontrollers"
Описание:
Learn how to write your own program, debug it, and use it to start the microcontroller. We have provided plenty of practical examples with necessary connection schemes: temperature sensors, AD and DA converters, LCD and LED displays, relays, communications, and the book is constantly being updated with fresh examples.
Скачать: http://uploading.com/files/BDR3VKYG/...llers.PDF.html
![](https://kazus.ru/nuke/users_images/24072009/817027.jpg)
24.07.2009, 22:17
#193
"Algorithms for Programmers"
Описание:
Important remarks about this document
The copyright and license are given in appendix A on page 921.
This is a draft of a book about selected algorithms. The audience in mind are programmers who are
interested in the treated algorithms and actually want to create and understand working and reasonably
optimized code.
The style varies somewhat which I do not consider bad per se: While some topics (as fast Fourier
transforms) need a clear and explicit introduction others (like the bit wizardry chapter) seem to be best presented by basically showing the code with just a few comments.
The pseudo language Sprache is used when I see a clear advantage to do so, mainly when the corresponding C++ does not appear to be self-explanatory. Larger pieces of code are presented in C++. C programmers
do not need to be shocked by the `++' as only a rather minimal set of the C++ features is used. Some
of the code, especially in part 3 (Arithmetical algorithms), is given in the pari/gp language as the use of other languages would likely bury the idea in technicalities.
The electronic version of this book is identical to the printed version. It will always stay online for free anonymous download. The referenced sources are online as part of FXT (fast transforms and low level
routines [19]) and hfloat (high precision
oating point algorithms [20]).
The reader is welcome to criticize and suggest improvements. Please name the draft version (date) with your feedback! This version is of 2009-March-05. Note that you can copy and paste from the PDF and DVI versions. Thanks go to those1 who helped to improve this document so far!
In case you want to cite this document, please avoid referencing individual chapters or sections as their
numbers (and titles) may change.
Enjoy reading!
Скачать: http://uploading.com/files/C6EJHFFB/...mmers.pdf.html
‹center›
[img]nuke/users_images/24072009/8122950.jpg[/img]‹/center›
24.07.2009, 22:21
#194
"Analog Interfacing to Embedded Microprocessor Systems, Second Edition"
Описание:
I keep this book on my office bookshelf. With its coverage of all manner of I/O devices from sensors and actuators to timer/counters to stepper motors, it's come in handy a few times. Think of it as your reference to interfacing to the real world in which your system operates.
Скачать: http://uploading.com/files/A8V8BAHI/Analog%20Interfacing%20to%20Embedded%20Microproces sors%20Systems%20(S.R.Ball,%202004).pdf.html
‹center›
[img]nuke/users_images/24072009/394580.jpg[/img]‹/center›
25.07.2009, 13:00
#195
"Зиновьев Г. С. Основы силовой электроники"
Скачать: http://uploading.com/files/F019FB6F/...D0%B2.zip.html
![](https://kazus.ru/nuke/users_images/25072009/3369064.jpg)
25.07.2009, 13:08
#196
"Современный тюнер своими руками. УКВ стерео + микроконтроллер"
Описание:
В последние годы широкое распространение получило высококачественное стереофоническое вещание в УКВ диапазоне. Тем не менее, сегодня все еще крайне сложно найти схему приемника, пригодную для повторения в домашней радиолюбительской лаборатории. Цель этойкниги заключается в желании автора помочь радиолюбителю освоить стереофонический УКВ радиоприем, сконструировать приемник для дома, работы, садового участка. Но что самое главное — создать современный УКВ радиоприемник с цифровой настройкой и управлениемна базе несложного отечественного однокристального программируемого микроконтроллера. Книга будет полезна радиолюбителям, специалистам-ремонтникам, студентам вузов, обучающимся по специальности `конструирование радиоэлектронной аппаратуры`, и всем интересующимся вопросами радиоприемной техники.
Скачать: http://uploading.com/files/EICQ493U/...B5...djvu.html
![](https://kazus.ru/nuke/users_images/25072009/500377.jpg)
Эти 2 пользователя(ей) сказали Спасибо SwanSwan за это сообщение:
25.07.2009, 13:12
#197
"Системы на микроконтроллерах и БИС программируемой логики"
Описание:
Рассматривается технология проектирования микроэлектронных систем на основе микроконтроллеров и БИС программируемой логики (ПЛИС). Описаны `ядра` MCS-51 и AVR современных микроконтроллеров, микроконвертер ADuC812 фирмы Analog Devices, семейства ПЛИС на примере изделий фирмы Altera. Рассмотрено проектирование цифровых устройств на основе ПЛИС с использованием языка AHDL. Описаны различные средства программирования и отладки микропроцессорных контролеров. Книга включает многочисленные примеры схем и фрагменты программ, которые могут быть использованы в практической работе.
Одновременно с вопросами проектирования обсуждаются проблемы обучения студентов и повышения квалификации специалистов, возникающие в связи с быстрым изменением элементной базы. В книге описаны учебные практикумы, построенные по принципу `делай как я` и позволяющие быстро передать практические навыки разработки систем на основе рассматриваемых микроконтроллеров и ПЛИС. Особенностью продемонстрированного подхода к обучению является использование только профессиональных инструментальных средств и методов, что исключает необходимость дальнейшего переучивания.
Книга для широкого круга специалистов в области проектирования микроэлектронных систем, аппаратуры и программного обеспечения. Материал соответствует ряду учебных курсов, необходим преподавателям и студентам.
Скачать: http://uploading.com/files/HW75Q963/...BD...djvu.html
![](https://kazus.ru/nuke/users_images/25072009/3003027.jpg)
25.07.2009, 13:16
#198
"Современные микроконтроллеры и микропроцессоры Motorola. Справочник"
Описание:
Книга знакомит читателей с архитектурой, функционированием и областями применения большой номенклатуры современных микроконтроллеров и микропроцессоров, выпускаемых компанией Motorola (с апреля 2004 года выпуск этих изделий производится компанией Freescale Semiconductor). В книге рассмотрены восьмиразрядные микроконтроллеры семейств 68НС05, 68НС08, 68НС11; шестнадцатиразрядные микроконтроллеры семейств 68НС12, 68НС16; тридцатидвухразрядные микроконтроллеры и микропроцессоры семейств 683хх, 680x0; тридцатидвухразрядные RISC- микропроцессоры и RISC-микроконтроллеры семейств PowerPC (МРС60х, МРС7хх, МРС5хх) и ColdFire (MCF5xxx); коммуникационные контроллеры МС68360, МС8302, МРС860, МРС823, МРС8260, широко используемые в современных системах телекоммуникации. Дан обзор программных и аппаратных средств для проектирования, программирования и отладки систем на базе микропроцессоров и микроконтроллеров фирмы Motorola.
Для широкого круга специалистов, интересующихся современной микропроцессорной техникой, разрабатывающих и применяющих различные виды систем и устройств на базе микропроцессоров и микроконтроллеров.
Скачать: http://uploading.com/files/HB2EGPQZ/...BD...djvu.html
![](https://kazus.ru/nuke/users_images/25072009/6118355.jpg)
25.07.2009, 13:19
#199
"Современные микропроцессоры"
Описание:
В книге рассмотрены основные типы микропроцессоров, используемых при построении персональных компьютеров, рабочих станций, вычислительных и телекоммуникационных систем, массово параллельных суперЭВМ и средств автоматизации технологических процессов. Проанализированы архитектурно-структурные приемы достижения высокой производительности. Представлены основные идеи построения суперскалярных микропроцессоров, микропроцессоров с длинным командным словом, а также перспективных мультитредовых микропроцессоров и однокристальных вычислительных систем. Приведены описания универсальных микропроцессоров ведущих зарубежных компаний. Рассмотрены семейства сигнальных микропроцессоров компаний Motorola, Texas Instruments, Analog Devices. Представлено новое направление средств обработки сигналов - медийные микропроцессоры. Рассмотрены основы транспьютерной технологии и существующие семейства транспьютеров. Представлены нейросетевые алгоритмы и нейропроцессоры для их интерпретации. Материал книги существенно переработан и дополнен по сравнению с предыдущими изданиями и дает представление о круге архитектурно-структурных идей, положенных в основу современных средств обработки информации. Приводятся конкретные примеры существующих микропроцессоров. Книга предназначена для студентов и аспирантов, изучающих информатику и компьютерные науки, а также всех интересующихся современной вычислительной техникой.
Скачать: http://uploading.com/files/YU6WRAQB/%D0%A1%D0%BE%D0%B2%D1%80%D0%B5%D0%BC%D0%B5%D0%BD%D 0%BD%D1%8B%D0%B5%20%D0%BC%D0%B8%D0%BA%D1%80%D0%BE% D0%BF%D1%80%D0%BE%D1%86%D0%B5%D1%81%D1%81%D0%BE%D1 %80%D1%8B%20(%D0%92.%D0%90%D0%BD%D0%B4%D1%80%D0%B5 %D0%B5%D0%B2,%20%D0%90.%D0%9A%EF%BF%BD...djvu.html
![](https://kazus.ru/nuke/users_images/25072009/6202634.jpg)
25.07.2009, 13:25
#200
"Руководство по микроконтроллерам. Том I"
Описание:
Описаны архитектура и функционирование микроконтроллеров семейств Intel MCS51, Motorola68HC05, Microchip PIC, Atmel AVR, Basic Stamp, система команд и способы адресации, реализация прерываний, тестирования и отладки, примеры использования для выполнения типовых функций.
Для пользователей и разработчиков современных цифровых систем.
Скачать: http://uploading.com/files/1IC7ZHRD/%D0%A0%D1%83%D0%BA%D0%BE%D0%B2%D0%BE%D0%B4%D1%81%D 1%82%D0%B2%D0%BE%20%D0%BF%D0%BE%20%D0%BC%D0%B8%D0% BA%D1%80%D0%BE%D0%BA%D0%BE%D0%BD%D1%82%D1%80%D0%BE %D0%BB%D0%BB%D0%B5%D1%80%D0%B0%D0%BC,%20%D1%821%20 (%D0%9C.%D0%9F%D1%80%D0%B5%D0%B4...djvu.html
![](https://kazus.ru/nuke/users_images/25072009/5969967.jpg)
Часовой пояс GMT +4, время: 05:28.
