15.09.2016, 15:42
Сказал спасибо: 337
Сказали Спасибо 30,207 раз(а) в 6,808 сообщении(ях)
Re: Книги (не радиотехнической тематики)
Tabletop Machining
Название: Tabletop Machining
Автор: Joe Martin
Издательство: Sherline Products Inc
Год: 1998
Страниц: 344
ISBN: 9780966543308
Формат: PDF
Язык: английский
Tabletop Machining gives the reader not just the "hows" but also the "whys" of machining practices using the lathe and milling machine for metalworking. Included are down-to-earth descriptions as well as detailed photos and drawings. In addition, a large selection of project photos illustrates the amazing work that has been produced by craftsmen using small but capable miniature machine tools. Though the tools used in the examples highlight the small end of the size scale in machining, the theories and practices can be applied to metal working on machines of any size.
Whether you're a newly graduated engineer or a beginning machinist, this book will help you gather some real, practical knowledge of how machines and machinists actually go about working with metal. This isn't theory, but rather it details "real world" practices and gives a good insight into the challenges faced by machinists. Too often, good craftsmen are stopped from venturing forth because the only information available shows just the technically perfect way to do things rather than the simple, practical methods everyone really uses. For those wishing to design and build their first metal parts, it is a perfect starting point, as it highlights the fun that comes from making small projects of precision and beauty.
На всякий Гугол свой Йобибайт найдется!
Сказали "Спасибо" mihail62
15.09.2016, 20:49
Сказал спасибо: 337
Практикум по высшей математике
Название: Практикум по высшей математике
Автор: Б.В. Соболь,
Н.Т. Мишняков, В.М. Поркшеян
Издательство: Ростов н/Д: Феникс
Год: 2007
Страниц: 640
ISBN: 978-5-222-12090-3
Формат: PDF
Язык: русский
По своему содержанию Практикум по высшей математике отвечает всем современным требованиям, предъявляемым к выпускникам широкого спектра специальностей высших учебных заведений России по этой дисциплине, и включает все разделы, указанные в соответствующих Государственных образовательных стандартах.
Материал Практикума предоставляет возможность студентам самостоятельно освоить основные положения курса высшей математики, приобрести и закрепить практические навыки решения задач. Особенно полезен Практикум может быть для студентов, обучающихся по заочной форме обучения, а также в активно развивающейся в последние годы системе дистанционного образования.
Оглавление
Предисловие ... 3
1. Векторная алгебра ... 5
2. Аналитическая геометрия ... 84
3. Линейная алгебра ... 186
4. Комплексные числа ... 237
5. Функции одной переменной ... 255
6. Функция одной переменной: интегральное исчисление ... 335
7. Функции нескольких переменных ... 415
8. Дифференциальные уравнения ... 549
9. Ряды ... 594
Литература ... 624
Эти 6 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
15.09.2016, 21:33
Сказал спасибо: 337
Шиноремонт
Автор: Доронкин В.Г.
Издательство: ИЦ "Академия"
Год: 2011
Страниц: 80
ISBN: 978-5-7695-6243-3
Формат: PDF
Язык: русский
Представлены обзор конструкций современных колес и шин автомобилей, описание оборудования и технологии шиноремонта. Отражено значение технического состояния колес, его проверки, влияния на безопасность и эксплуатационные характеристики автомобиля. Детально описаны технологии восстановительного ремонта камер и шин.
Учебное пособие может быть использовано при освоении МДК 01.02 "Устройство, техническое обслуживание и ремонт автомобиля" профессионального модуля ПМ.01 "Техническое обслуживание и ремонт автотравспорта" по профессии 190631.01 "Автомеханик".
Для подготовки, переподготовки и повышения квалификации рабочих по профессии "Слесарь по ремонту автомобилей".
Эти 3 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
15.09.2016, 21:59
Сказал спасибо: 337
Learn Raspberry Pi Programming with Python (+sources)
Название: Learn Raspberry Pi Programming with Python (+sources)
Автор: Wolfram Donat
Издательство: Apress
Год: 2014
Страниц: 244
ISBN: 978-1-4302-6424-8
Формат: PDF
Язык: English
Learn Raspberry Pi Programming with Python will show you how to program your nifty new $35 computer to make a web spider, a weather station, a media server, and more. You'll learn how to program in Python on your Raspberry Pi with hands-on examples and fun projects.
Even if you're completely new to programming in general, you'll figure out how to create a home security system, an underwater photography system, an RC plane with a camera, and even a near-space weather balloon with a camera.
You'll learn how to make a variety of fun and even useful projects, from a web bot to search and download files to a toy to drive your pets insane. You'll even learn how to use Pi with Arduino as well as Pi with Gertboard, an expansion board with an onboard ATmega microcontroller.
What you’ll learn:
Raspberry Pi and electronics basics;
Quick intro to Linux;
Python basics to get you started on a set of projects;
How to make a variety of Pi and Python projects, including servers and gadgets with cameras;
How to use Pi with Arduino and Gertboard.
Who this book is for:
Readers who want to learn Python on a fun platform like the Pi and pick up some electronics skills along the way. No programming or Linux skill required, but a little experience with Linux will be helpful.
16.09.2016, 10:40
Сказал спасибо: 337
Графы и алгоритмы. Структуры данных. Модели вычислений
Название: Графы и алгоритмы. Структуры данных. Модели вычислений
Автор: Алексеев В.Е., Таланов В.А.
Издательство: Интуит, Бином ЛЗ
Год: 2012
Страниц: 320
ISBN: 978-5-94774-543-6, 978-5-9556-0066-6
Формат: PDF
Язык: русский
Учебник состоит из трех частей, посвященных вопросам анализа и разработки алгоритмов: графы и алгоритмы, структуры данных, модели вычислений. Для понимания материала достаточно математической подготовки в объеме первого курса университета или технического вуза.
Предназначен для студентов, обучающихся по направлению 510200 - Прикладная математика и информатика и по специальности 010200 - Прикладная математика и информатика.
16.09.2016, 19:41
Сказали Спасибо 719 раз(а) в 252 сообщении(ях)
Название: Как устроен и работает дизель
Автор: Куров Б.А.
Издательство: Б.А.
Год: 1955
Страниц: 152
Формат: pdf
Качество: хорошее
Язык: русский
Настоящая брошюра имеет целью ознакомить водителей автомобилей и тракторов с особенностями устройства, работы и эксплуатации дизеля. В брошюре в популярной форме изложены основы рабочего процесса дизеля, описано назначение, конструкция, принцип действия основных механизмов дизеля и правила ухода за ними. Изложение иллюстрируется рисунками, схемами и описанием современных отечественных дизелей, устанавливаемых на автомобилях и тракторах.
Эти 5 пользователя(ей) сказали Спасибо gol8425 за это сообщение:
16.09.2016, 20:30
Сказал спасибо: 913
Сказали Спасибо 2,329 раз(а) в 514 сообщении(ях)
Работа в Интернете. Энциклопедия
С помощью этой книги вы освоите широкие возможности Интернета. Вы узнаете, что представляет собой Всемирная паутина, как к ней подключиться, оцените, каковы в работе различные программы для Интернета. Книга расскажет, как эффективно находить нужную информацию с помощью поисковых серверов и каталогов, пользоваться электронной почтой, общаться на форумах, в чатах и в «аське» и даже звонить через Интернет.
В энциклопедии вы найдете также эффективные приемы работы в Сети и неочевидные решения обыденных задач. Интернет-энциклопедия станет настольной книгой и для начинающих исследователей Сети, и для опытных серферов.
Краткое содержание:
§ Введение.
§ Глава 1 Подключение к Интернету.
§ Глава 2 Браузер - окно в Интернет.
§ Глава 3 Сетевая безопасность.
§ Глава 4 Администрирование и анонимность в Сети.
§ Глава 5 Поиск в Интернете.
§ Глава 6 Загрузка файлов из Интернета.
§ Глава 7 Электронная почта.
§ Глава 8 Общение в Интернете.
§ Глава 9 Бесплатные звонки через Интернет.
§ Глава 10 Заработок и развлечения в Интернете.
§ Глава 11 Создание собственного веб-сайта.
§ Приложение Хитрости эффективной работы в Интернете. Вопросы и ответы.
Название: Работа в Интернете. Энциклопедия
Автор: Ташков П.А.
Издательство: СПб.: Питер
Год издания: 2010
Качество: Отличное
Страниц: 390
Формат: PDF, DOCX
Язык: Русский
Эти 4 пользователя(ей) сказали Спасибо nik_by за это сообщение:
16.09.2016, 22:55
Сказал спасибо: 337
Курс физики
Автор: Трофимова Т.И.
Издательство: Академия
Год: 2006
Страниц: 560
ISBN: 5-7695-2629-7
Формат: PDF
Язык: русский
Учебное пособие написано в соответствии с действующей программой курса физики для инженерно-технических специальностей высших учебных заведений. Небольшой объем учебного пособия достигнут с помощью тщательного отбора и лаконичного изложения материала.
Книга состоит из семи частей. В первой части дано систематическое изложение физических основ классической механики, а также рассмотрены элементы специальной (частной) теории относительности. Вторая часть посвящена основам молекулярной физики и термодинамики. В третьей части представлены электростатика, постоянный электрический ток и электромагнетизм. В четвертой части, посвященной теории колебаний и волн, механические и электромагнитные колебания рассмотрены параллельно, указаны их сходства и различия и сопоставлены физические процессы, происходящие при соответствующих колебаниях. В пятой части изложены элементы геометрической и электронной оптики, волновая оптика и квантовая природа излучения. Шестая часть посвящена элементам квантовой физики атомов, молекул и твердых тел. В седьмой части рассмотрены элементы физики атомного ядра и элементарных частиц.
Изложение материала ведется без громоздких математических выкладок, особое внимание обращено на физическую суть явлений и описывающих их понятий и законов, а также на преемственность современной и классической физики. Приведены контрольные вопросы и задачи для самостоятельного решения.
Для студентов инженерно-технических специальностей высших учебных заведений.
Эти 5 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
17.09.2016, 00:34
Сказал спасибо: 337
Самоловы
Автор: Черенков С.Е., Матюнин М.М.
Издательство: АСТ, Астрель
Год: 2003
Страниц: 206
ISBN: 5-17-016605-2, 5-271-05251-6
Формат: PDF
Язык: русский
Предлагаемая книга посвящена самоловам - орудиям, предназначенным для добычи различных видов животных, без непосредственного участия человека.
Как наши предки, так и современные охотники успешно применяли и применяют самоловы для добычи самых разнообразных зверей и птиц. В зависимости от требований времени одни конструкции самоловов сменяют другие. Появляются современные ловушки из новых материалов, совершенствуются старые. Но при этом некоторые самоловы дошли до нашего времени, через тысячелетия, практически не изменившись. Они применяются охотниками и поныне, более того, по своей уловистости эти конструкции не только не уступают, но за частую и превосходят современные. Глядя на кустарные самоловы, поражаешься простоте и рациональности их устройства.
При составлении книги авторы постарались включить в нее многие описанные в литературе и известные из других источников реально работающие конструкции самоловов. Мы намеренно не акцентировали внимание на изготовлении запрещенных орудий лова, но посчитали необходимым привести описание их внешнего вида и общий принцип действия, так как они представляют несомненный интерес как неотъемлемая часть нашей богатой истории.
17.09.2016, 01:02
Сказал спасибо: 337
Принципы квантовой Вселенной
Название: Принципы квантовой Вселенной
Автор: Первушин В.Н., Павлов А.Е.
Издательство: Saarbrucken: LAP Lambert Academic Publishing
Год: 2013
Страниц: 420
ISBN: 978-3-659-41551-7
Формат: PDF
Язык: русский
Серия: Квантовая гравитация
Основная задача авторов - привлечь внимание читателей к интересной и интригующей задаче описания современных экспериментальных и наблюдательных данных в рамках идей и методов, разработанных еще до 1973-74 гг. основателями современной релятивистской классической и квантовой физики.
Отличие нашего подхода от стандартных подходов в том, что всюду, от горизонта Вселенной до кварков, мы будем использовать на классическом уровне масштабно-инвариантные версии современных теорий, с безразмерными константами связи, нарушая эту масштабную инвариантность только на квантовом уровне нормальным упорядочиванием произведений полевых операторов.
Метод классификации новых данных, полученных за последние пятнадцать лет в космологии и физике, существенно использует квантовые теории и представления. Отсюда происходит и название нашей книги "Принципы квантовой Вселенной".
Классификация представлена на основе принципов конформной и аффинной симметрий и постулата существования вакуума по аналогии с классификацией элементарных частиц по неприводимым представлениям группы Пуанкаре.
Часовой пояс GMT +4, время: 16:46.
