08.08.2009, 21:55
Сказал спасибо: 1,463
Сказали Спасибо 6,183 раз(а) в 1,468 сообщении(ях)
"Digital signal processing system-level design using LabVIEW"
Kehtarnavaz N., Kim N., 2005
Описание:
LabVIEW (Laboratory Virtual Instrumentation Engineering Workbench) developed by National Instruments is a graphical programming environment. Its ease of use allows engineers and students to streamline the creation of code visually, leaving time traditionally spent on debugging for true comprehension of DSP.
This book is perfect for practicing engineers, as well as hardware and software technical managers who are familiar with DSP and are involved in system-level design. With this text, authors Kehtarnavaz and Kim have also provided a valuable resource for students in conventional engineering courses. The integrated lab exercise create an interactive experience which supports development of the hands-on skills essential for learning to navigate the LabVIEW program.
Digital Signal Processing System-Level Design Using LabVIEW is a comprehensive tool that will greatly accelerate the DSP learning process. Its thorough examination of LabVIEW learnes no question unanswered. LabVIEW is the program that will demystify DSP and this is the book that will show you how to master it. A graphical programming approach (LabVIEW) to DSP system-level design.
Скачать: http://uploading.com/files/WZNWJ7UL/...vaz...pdf.html
![](https://kazus.ru/nuke/users_images/08082009/7728988.jpg)
08.08.2009, 22:01
"LabVIEW digital signal processing and digital communications"
Cory Clark, 2005
Описание:
I went through couple of chapters of the book and was amazed what a great job the author had done to explain some of the application using labview as well as dsp/digital communication theory. Especially some of examples and solutions he put together helped me understand some stuff which seem too hard to grasp. I recommend this book not only because it shows how to use labview in dsp and digital communication application, but also its elegant writing.
Скачать: http://uploading.com/files/68JHOSKG/...Clark.pdf.html
![](https://kazus.ru/nuke/users_images/08082009/3919738.jpg)
08.08.2009, 22:09
"LabVIEW 8.5. Вводный курс"
Описание:
Данное руководство можно использовать в качестве учебного пособия для знакомства со средой графического программирования LabVIEW, а также некоторыми базовыми функциями для создания приложений сбора данных и управления приборами.
Руководство содержит набор упражнений помогающих изучить процесс разработки приложений в LabVIEW.
Выполнение упражнений не займет много времени, зато позволит Вам начать программировать в LabVIEW.
В конце каждой главы приводятся краткие выводы о рассмотренных аспектах программирования, которые можно использовать для повторения изученного материала.
Скачать: http://uploading.com/files/VWS9FDDQ/...D1%81.pdf.html
![](https://kazus.ru/nuke/users_images/08082009/14738.jpg)
08.08.2009, 22:19
"LabVIEW Руководство пользователя"
Описание:
В данном руководстве описана среда графического программирования LabVIEW и техника создания в ней таких приложений, как тестирование и измерение, сбор данных, управление приборами, регистрация данных, анализ измерений и генерация отчетов.
Руководство пользователя можно использовать для изучения возможностей программирования в LabVIEW, включая пользовательский интерфейс и рабочее пространство, а также палитры и инструменты LabVIEW. В него не вошла специфическая информация
относительно каждой палитры, инструмента, меню, диалогового окна, элемента управления и встроенных ВП и функций. Для получения дополнительной информации об этом, а также для детальных
пошаговых инструкций об использовании возможностей LabVIEW и построения специальных приложений, следует пользоваться встроенной справочной системой LabVIEW (LabVIEW Help). Более подробно о пользовании справочной системой см. раздел Источники документации LabVIEW в Главе 1 Введение в LabVIEW.
Скачать: http://uploading.com/files/ER1CRXR1/...D1%8F.pdf.html
![](https://kazus.ru/nuke/users_images/08082009/5585422.jpg)
08.08.2009, 22:25
"LabVIEW для радиоинженера. От виртуальной модели до реального прибора"
Ю. К. Евдокимов, В. Р. Линдваль, Г. И. Щербаков, 2007
Описание:
В данной книге возможности LabVIEW как среды программирования демонстрируются на примерах в области цифровой обработки сигналов, радиоэлектроники, компьютерных измерений и автоматизации эксперимента, электродинамики и распространения радиоволн. Большая часть примеров в книге строится по принципу "от простого к сложному", показавшему свою эффективность на курсах изучения LabVIEW.
К книге прилагается компакт-диск, на котором размещены виртуальные лабораторные работы, а также демонстрационная версия LabVIEW.
Книга рекомендуется для студентов радиотехнических и телекоммуникационных специальностей вузов, а также может быть полезна инженерам и научным работникам.
Скачать:
Часть 1: http://uploading.com/files/1K0IGXHQ/...part1.rar.html
Часть 2: http://uploading.com/files/0D8B37JX/...part2.rar.html
Часть 3: http://uploading.com/files/YLOOXAI7/...part3.rar.html
Часть 4: http://uploading.com/files/ULR401B3/...part4.rar.html
![](https://kazus.ru/nuke/users_images/08082009/2872598.jpg)
09.08.2009, 09:44
"Основы графического программирования в среде LabVIEW"
Климентьев К.Е., 2002
Описание:
Приведена информация об организации и правилах графического программирования в SCADA-системе LabVIEW.
Скачать: http://uploading.com/files/K7OVY6O1/...%B5...pdf.html
![](https://kazus.ru/nuke/users_images/09082009/3730132.jpg)
09.08.2009, 13:16
"Разработка прикладного программного обеспечения в среде LabVIEW"
Виноградова Н.А., Листратов Я.И., Свиридов Е.В., 2005
Скачать: http://uploading.com/files/0RISDXH1/...%BD...pdf.html
![](https://kazus.ru/nuke/users_images/09082009/4931880.jpg)
09.08.2009, 13:20
"Автоматизация физических исследований и эксперимента. Компьютерные измерения и виртуальные приборы на основе LabVIEW 7"
Бутырин П.А., Васьковская Т.А., Каратаева В.В., Материкин С.В., 2005
Описание:
Книга состоит из 30 глав, названных лекциями. Эти главы содержат как информацию о тех или иных возможностях LabVIEW, так и практические задания, выполнение которых необходимо для овладения этим прикладным инструментом исследования физических процессов и управления ими. Материал каждой главы рассчитан на одно занятие за компьютером и может быть использован как при обучении группы студентов преподавателем, так и при самообучении студента. Для большей доступности курса большинство практических заданий ограничивается исследованием чисто виртуальных объектов, что не требует приобретения специальной материальной части (аналогово-цифровых преобразователей и т.д.).
Издание предназначено для инженеров и студентов технических вузов.
Скачать: http://uploading.com/files/BVK8EKI5/...%EF%BF%BD.html
![](https://kazus.ru/nuke/users_images/09082009/4300099.jpg)
09.08.2009, 13:24
"LabVIEW: практикум по основам измерительных технологий"
В. К. Батоврин, А. С. Бессонов, В. В. Мошкин, В. Ф. Папуловский, 2005
Описание:
Данная книга содержит практикум по основам измерительных технологий. Работы охватывают основы метрологии и измерительной техники, вопросы обработки и представления результатов измерений и методы и средства электрических измерений. Выбор этих разделов обусловлен тем, что с ними чаще всего приходится сталкиваться в учебной и производственной практике. Основой представленного в настоящем издании практикума является комплекс прикладных программ, созданный в инструментальной среде разработки приложений LabVIEW. Программное обеспечение является оригинальной разработкой авторов учебного пособия и представлено на компакт-диске, поставляемым с книгой.
Издание предназначено для студентов технических вузов, обучающихся по специальностям "Приборостроение", "Информационно-измерительная техника и технологии", "Методы и средства измерений", а также для студентов других направлений подготовки, изучающих смежные дисциплины.
Скачать: http://uploading.com/files/CC2M1GH8/...%85...zip.html
![](https://kazus.ru/nuke/users_images/09082009/2118278.jpg)
11.08.2009, 14:11
Сказал спасибо: 936
Re: Книги
Сообщение от dosikus
Левые посты удаляю без предупреждения!
Осторожно , злой кот
Часовой пояс GMT +4, время: 05:07.
