15.02.2013, 14:41
Сказал спасибо: 936
Re: Дешевый компактный микроконтроллер?
Сообщение от ut1wpr
Вообще не понял. Тупой я.
Не горячись.
Например STM32F050F4, STM32F050F6
TSSOP 20
Core: ARM 32-bit Cortex™-M0 CPU, frequency up to 48 MHz
Memories
16 to 32 Kbytes of Flash memory
4 Kbytes of SRAM with HW parity checking
CRC calculation unit
Reset and supply management
Voltage range: 2.0 V to 3.6 V
Power-on/Power-down reset (POR/PDR)
Programmable voltage detector (PVD)
Low power modes: Sleep, Stop and Standby
VBATsupply for RTC and backup registers
Clock management
4 to 32 MHz crystal oscillator
32 kHz oscillator for RTC with calibration
Internal 8 MHz RC with x6 PLL option
Internal 40 kHz RC oscillator
Up to 39 fast I/Os
All mappable on external interrupt vectors
Up to 25 I/Os with 5 V tolerant capability
5-channel DMA controller
1 × 12-bit, 1.0 μs ADC (up to 10 channels)
Conversion range: 0 to 3.6V
Separate analog supply from 2.4 up to 3.6 V
Up to 9 timers
1 x 16-bit 7-channel advanced-control timer for 6 channels PWM output, with deadtime generation and emergency stop
1 x 32-bit and 1 x 16-bit timer, with up to 4 IC/OC, usable for IR control decoding
1 x 16-bit timer, with 2 IC/OC, 1 OCN, deadtime generation and emergency stop
1 x 16-bit timer, with IC/OC and OCN, deadtime generation, emergency stop and modulator gate for IR control
1 x 16-bit timer with 1 IC/OC
Independent and system watchdog timers
SysTick timer: 24-bit downcounter
Calendar RTC with alarm and periodic wakeup from Stop/Standby
Communication interfaces
1 x I2C interface; supporting Fast Mode Plus (1 Mbit/s) with 20 mA current sink, SMBus/PMBus, and wakeup from STOP
1 x USART supporting master synchronous SPI and modem control; one with ISO7816 interface, LIN, IrDA capability auto baud rate detection and wakeup feature
1 x SPI (18 Mbit/s) with 4 to 16 programmable bit frames, with I2S interface multiplexed
Serial wire debug (SWD)
96-bit unique ID
Extended temperature range: -40 to +105°C
Осторожно , злой кот
Эти 2 пользователя(ей) сказали Спасибо dosikus за это сообщение:
15.02.2013, 14:49
Сказал спасибо: 65
С уважением,
Vic / ut1wpr
15.02.2013, 16:07
Сказал спасибо: 936
Сообщение от mlit
если разработают функциональный аналог на AVR в короткие сроки
Это свершилось и давно. Что сопли то жевать ?
Вам выше дан аналог мощнее и дешевле .
Я не был никогда против AVR .
Вот только среди сидящих на них полно полных ламеров, намного больше чем на том же Pic.
AVR более терпим к быдло_коду похоже.
15.02.2013, 17:39
Сказал спасибо: 12
Сказали Спасибо 55 раз(а) в 21 сообщении(ях)
Фу, какой грубый кот. Сутки простоя линии - 2 млн.руб. упущенной выгоды, глюки в работе нервотрепка для персонала и большие потери. На х... мне нужен грузовик МАН (хоть у него и большие возможности), если и газель с этой работой справится. Это я об экономике принимаемых решений. А атмеловские вещи действитель очень терпимые к безобразиям - один раз довелось попасть под 220В через одну из ног (пробило развязывающий транс) - меня тряхануло, а он сволочь жив. Никаких призывов, я заткнулся...
Последний раз редактировалось mlit; 15.02.2013 в 18:06.
Причина: добавление
15.02.2013, 17:42
Сказал спасибо: 65
Сообщение от mlit
Как-то все это абстрактно. Звучит, как приглашение к полемике. Бесполезной. Точки зрения сторон уже раскрыты.
С уважением,
Vic / ut1wpr
15.02.2013, 17:44
Сказал спасибо: 65
Сообщение от dosikus
Это не ламеры! Это продукт все тех же визардов и вижнов. Они затаились. Ждут, когда же наступит эра новых свавров для остальных камней, без курения маналов и прочей ерунды. Книпку нажал - спина вспотела! Вот ужо развернутся!
С уважением,
Vic / ut1wpr
15.02.2013, 17:51
Сказал спасибо: 2,443
А, если их продукт работает и пользуется спросом,так ли это плохо?
Клиенту совершенно все равно,как это сделано,людям кусочек хлеба.А может и повод потом посерьезнее заняться.
15.02.2013, 17:59
Сказал спасибо: 103
Сказали Спасибо 50 раз(а) в 40 сообщении(ях)
Сообщение от mlit
В такой ситуации не спрашивают, какой контроллер можно найти за 30 центов, а берут что-то готвое и хорошо знакомое и БЫСТРО латают дырку. Потом можно сделаоть что-то поаккуратнее и поставить вместо заплаты. Но опять же, о цене вопрос не стоит. Вопрос "Сколько стоит?" встает только когда счет идет на сотни-тысячи изделий.
Сообщение от mlit
Больше половины неисправностей контроллеров, с которыми сталкивался, выглядели как "изделие исправно, но какая-то функция глючит". При проверке выяснялось, что контроллер жив за исключением какого-то модуля. Так что выживший Атмел не факт что выжил.
15.02.2013, 18:40
Сказал спасибо: 15
Сказали Спасибо 105 раз(а) в 42 сообщении(ях)
Сообщение от ut1wpr
Вот Вам еще точка зрения. Экономическая.
Зависли у меня на складе с незапамятных времен около 150 штук 51-ых от Atmel.
Ждут подходящего заказа и дождутся. Важно согласовать правильное ТЗ.
15.02.2013, 18:43
Сказал спасибо: 348
Смотрю на тему и вижу первое слово - дешевый, так в чем проблема?
Идете в несколько интернет магазинов и смотрите цены, выбираете микроконтроллер, лезете на сайт производителя смотрите, что предлагается для разработки, бибилиотечки там, компиляторы и т.д. Не подходит? Возвращаетесь к началу, но вычеркиваете из списка уже просмотренное. Дешевый контроллер, его еще нужно достать, без провалов в поставке, в вашем случае мы о партии в 1000 штук не говорим, так?
Просите посоветовать какой, вам уже основных производителей(доставабельных и распространенных) посоветовали, выбор за вами.
Часовой пояс GMT +4, время: 02:44.
