06.12.2014, 01:05
Сказал спасибо: 337
Сказали Спасибо 30,207 раз(а) в 6,808 сообщении(ях)
Re: Книги (не радиотехнической тематики)
И мне стало по барабану. Здоровье дороже. Целенаправленные поиски прекратил, не вижу смысла. А это так, по дороге подвернулось.
06.12.2014, 16:32
Сказал спасибо: 337
Hard Disk Drive: Mechatronics and Control
Название: Hard Disk Drive: Mechatronics and Control
Автор: Abdullah Al Mamun, GuoXiao Guo, Chao Bi
Издательство: CRC Press
Год: 2006
Страниц: 398
ISBN: 9780849372537, 0849372534
Формат: PDF
Язык: English
The hard disk drive is one of the finest examples of the precision control of mechatronics, with tolerances less than one micrometer achieved while operating at high speed. Increasing demand for higher data density as well as disturbance-prone operating environments continue to test designers' mettle.
Explore the challenges presented by modern hard disk drives and learn how to overcome them with Hard Disk Drive: Mechatronics and Control. Beginning with an overview of hard disk drive history, components, operating principles, and industry trends, the authors thoroughly examine the design and manufacturing challenges. They start with the head positioning servomechanism followed by the design of the actuator servo controller, the critical aspects of spindle motor control, and finally, the servo track writer, a critical technology in hard disk drive manufacturing. By comparing various design approaches for both single- and dual-stage servomechanisms, the book shows the relative pros and cons of each approach. Numerous examples and figures clarify and illustrate the discussion. Exploring practical issues such as models for plants, noise reduction, disturbances, and common problems with spindle motors, Hard Disk Drive: Mechatronics and Control avoids heavy theory in favor of providing hands-on insight into real issues facing designers every day.
http://borncash.org/load/0006007399
http://turbobit.net/ra8ffe5g60jg.html
http://startfiles.org/load/0006007399
06.12.2014, 17:31
Сказал спасибо: 337
Микропроцессоры и их применение в системах передачи и обработки сигналов
Название: Микропроцессоры и их применение в системах передачи и обработки сигналов
Автор: Калабеков Б.А.
Издательство: Радио и связь
Год: 1988
Страниц: 368
Формат: DJVU
Язык: русский
Излагаются различные подходы к проектированию процессорных устройств: со специализированным операционным устройством и управляющим устройством, синтезированным на основе схемной и программируемой логики. Рассматриваются устройства на микропроцессорных комплектах БИС серий КР580, К589, КР1804, КР1810, а также приемы программирования на языках различных уровней.
Для студентов радиотехнических специальностей, полезна специалистам, связанным с разработкой микропроцессорных устройств.
http://borncash.org/load/0006007402
http://turbobit.net/rry02cfbf7r6.html
http://startfiles.org/load/0006007402
Сказали "Спасибо" mihail62
06.12.2014, 19:58
Сказал спасибо: 337
Электрические линии задержки и фазовращатели
Название: Электрические линии задержки и фазовращатели
Автор: Авраменко В.Л., Галямичев Ю.П., Ланнэ А.А.
Издательство: Связь
Год: 1973
Страниц: 112
Формат: PDF
Язык: русский
В книге рассмотрены вопросы синтеза электрических линий задержки и широкополосных фазовращателей, составленных из сосредоточенных элементов. Материал книги базируется на методах оптимального синтеза линейных электрических цепей. Для инженерно-технических работников.
Оглавление
Предисловие 4
Глава 1. Характеристики электрических линий задержки 5
1. Общие сведения 5
2. Основные определения и параметры линий задержки 6
Глава 2. Схемы и расчет фазовых контуров 12
2.1. Общие свойства фазовых контуров 12
2.2. LC-фазовые контуры 14
2.3. RLC-фазовые контуры 22
2.4. Активные RС-фазовые контуры 24
Глава 3. Расчет линий задержки 38
3.1. Введение 38
3.2. Линии задержки с максимально плоскими характеристиками группового времени задержки 39
3.3. Линии задержки с чебышевскими характеристиками группового времени задержки 46
3.4. Линии задержки, составленные из однотипных звеньев 64
3.5. Полосовые линии задержки 69
3.6. Линии задержки с отводами 77
3.7. Дисперсионные линии задержки 79
Глава 4. Широкополосные фазоразностные цепи 87
4.1. Частотные характеристики фазоразностных цепей 87
4.2. Расчет передаточных функций фазовых контуров фазовращателей 88
4.3. Реализация фазовращателей на фазовых контурах LC и RLC 99
4.4. Реализация фазовращателей типа RC 101
4.5. Типовые схемы фазовращетелей 106
Список литературы 111
http://borncash.org/load/0006007404
http://turbobit.net/lpk72ye8gb46.html
http://startfiles.org/load/0006007404
Эти 3 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
06.12.2014, 23:28
Сказал спасибо: 337
Компрессионный мотор Ф-10
Название: Компрессионный мотор Ф-10
Автор: Микиртумов Э.Б.(ред.)
Издательство: ДОСАРМ
Год: 1949
Страниц: 36
Формат: PDF
Язык: русский
Серия: Библиотека юного конструктора
В брошюре дано подробное описание авиамодельного мотора Ф-10, который относится к группе компрессионных двигателей. Авиамодельные компрессионные двигатели имеют ряд преимуществ перед обычными бензиновыми моторами: у них отсутствуют такие капризные, даже при правильной эксплуатации, агрегаты, как прерыватель, свеча, бобина, конденсатор, батарея и электропроводка, причиняющие моделисту немало хлопот. Отсутствие их у компрессионных моторов уменьшает вес модели, а отсутствие электрозажигания облегчает эксплуатацию радиоуправляемых моделей, так как в этом случае не бывает электрических помех.
Изготовление компрессионного двигателя почти вдвое дешевле, чем постройка обычного бензинового моторчика с электрозажиганием. Монтаж его на модели значительно проще. Наконец, при одном и том же объеме цилиндра он развивает большую мощность. Правда, из-за этого повышается расход горючего, но этот недостаток вполне окупается рядом преимуществ.
http://borncash.org/load/0006007406
http://turbobit.net/532b2ixwmuoq.html
http://startfiles.org/load/0006007406
07.12.2014, 01:44
Сказал спасибо: 337
Python Projects
Автор: Laura Cassell, Alan Gauld
Издательство: Wrox
Год: 2014
Страниц: 384
ISBN: 111890866X, 9781118908662
Формат: PDF
Язык: English
A guide to completing Python projects for those ready to take their skills to the next level Python Projects is the ultimate resource for the Python programmer with basic skills who is ready to move beyond tutorials and start building projects.
The preeminent guide to bridge the gap between learning and doing, this book walks readers through the "where" and "how" of real-world Python programming with practical, actionable instruction. With a focus on real-world functionality, Python Projects details the ways that Python can be used to complete daily tasks and bring efficiency to businesses and individuals alike. Python Projects is written specifically for those who know the Python syntax and lay of the land, but may still be intimidated by larger, more complex projects. The book provides a walk-through of the basic set-up for an application and the building and packaging for a library, and explains in detail the functionalities related to the projects.
http://borncash.org/load/0006007409
http://turbobit.net/pt45g45f7b12.html
http://startfiles.org/load/0006007409
07.12.2014, 04:56
Сказал спасибо: 913
Сказали Спасибо 2,329 раз(а) в 514 сообщении(ях)
50 самых полезных программ для вашего компьютера
В этой книге собраны краткие описания пятидесяти самых полезных в повседневной жизни программ, с помощью которых вы сможете слушать и смотреть любые мультимедийные файлы, записывать диски, работать с Интернетом и электронной почтой, полноценно обслуживать ваш компьютер и защищаться от разнообразных информационных угроз. И, конечно, полезные мелочи, без которых невозможно себе представить домашний ПК, – от электронных словарей до архиваторов и программ по ведению семейной бухгалтерии[cutline]...
Название: 50 самых полезных программ для вашего компьютера
Серия: Компьютер на 100%
Автор: Лоянич А.
Издательство: Эксмо
Год издания: 2010
Качество: Отличное
Страниц: 312
Формат: PDF
Язык: Русский
Скачать с TurboBit
Скачать с BornCash
Скачать с Uploaded
Скачать с StartFiles
Эти 4 пользователя(ей) сказали Спасибо nik_by за это сообщение:
07.12.2014, 09:01
Сказал спасибо: 337
Электроника шаг за шагом. Практическая энциклопедия юного радиолюбителя
Название: Электроника шаг за шагом. Практическая энциклопедия юного радиолюбителя
Автор: Сворень Р.А.
Издательство: Детская литература
Год: 1986
Страниц: 431
Формат: DJVU
Язык: русский
В практическую энциклопедию радиолюбителя входят популярные рассказы об основах электротехники, электроники и радиотехники, о звукозаписи, телевидении, радиоприеме, электронной музыке, об автоматике и вычислительной технике. В книге много практических схем и описаний конструкций для самостоятельного изготовления. Большую помощь радиолюбителю в его практической работе окажет имеющийся в книге справочный материал.
http://borncash.org/load/0006007414
http://turbobit.net/uy2tmzby649e.html
http://startfiles.org/load/0006007414
07.12.2014, 14:46
Сказал спасибо: 337
Технология керамических диэлектриков
Название: Технология керамических диэлектриков
Автор: Окадзаки К.
Издательство: Энергия
Год: 1976
Страниц: 327
Формат: DJVU
Язык: русский
В книге подробно описывается технология приготовления керамических диэлектриков: сегнетоэлектриков, пироэлектриков, сегнетомагнетиков и др.
Отсутствуют стр. 2-5, 319, 328-330
http://borncash.org/load/0006007417
http://turbobit.net/e6rj3ktdx51c.html
http://startfiles.org/load/0006007417
07.12.2014, 17:11
Сказал спасибо: 456
Сказали Спасибо 47,137 раз(а) в 3,118 сообщении(ях)
Механизмы. Кожевников С.Н., Есипенко Я.И., Раскин Я.М. 1965
28.9 MB, DjVu
https://yadi.sk/d/fDoG41i2dCu6w
Владимир
Эти 4 пользователя(ей) сказали Спасибо AversT за это сообщение:
Часовой пояс GMT +4, время: 18:33.
