24.12.2013, 02:28
Сказал спасибо: 89
Сказали Спасибо 735 раз(а) в 149 сообщении(ях)
Re: Книги
Последний раз редактировалось zöner; 24.12.2013 в 16:37.
Эти 10 пользователя(ей) сказали Спасибо zöner за это сообщение:
24.12.2013, 06:17
Сказал спасибо: 337
Сказали Спасибо 30,207 раз(а) в 6,808 сообщении(ях)
Re: Книги
Beginning Sensor Networks with Arduino and Raspberry Pi
Название: Beginning Sensor Networks with Arduino and Raspberry Pi
Автор: Charles Bell
Издательство: Apress
Год: 2013
Страниц: 407
ISBN: 978-1-4302-5824-7, 1-4302-5824-1
Формат: PDF, EPUB
Язык: english
Beginning Sensor Networks with Arduino and Raspberry Pi teaches you how to build sensor networks with Arduino, Raspberry Pi, and XBee radio modules, and even shows you how to turn your Raspberry Pi into a MySQL database server to store your sensor data!
First you'll learn about the different types of sensors and sensor networks, including how to build a simple XBee network. Then you'll walk through building an Arduino-based temperature sensor and data collector, followed by building a Raspberry Pi-based sensor node.
Next you'll learn different ways to store sensor data, including writing to an SD card, sending data to the cloud, and setting up a Raspberry Pi MySQL server to host your data. You even learn how to connect to and interact with a MySQL database server directly from an Arduino! Finally you'll learn how to put it all together by connecting your Arduino sensor node to your new Raspberry Pi database server.
If you want to see how well Arduino and Raspberry Pi can get along, especially to create a sensor network, then Beginning Sensor Networks with Arduino and Raspberry Pi is just the book you need.
What you’ll learn
•How to build sensor nodes with both Arduino and Raspberry Pi!
•What is XBee?
•What methods you have for storing sensor data
•How you can host your data on the Raspberry Pi
•How to get started with the MySQL database connector for Arduino
•How to build database enabled sensor networks
Who this book is for
Electronics enthusiasts, Arduino and Raspberry Pi fans, and anyone who wants hands-on experience seeing how these two amazing platforms, Arduino and Raspberry Pi, can work together with MySQL.
Эти 4 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
24.12.2013, 08:34
Сказал спасибо: 337
Re: Книги
Introduction to Programming in Java: An Interdisciplinary Approach
Название: Introduction to Programming in Java: An Interdisciplinary Approach
Автор: Robert Sedgewick, Kevin Wayne
Издательство: Addison-Wesley
Год: 2007
Страниц: 735
ISBN: 978-0-321-49805-2, 0-321-49805-4
Формат: PDF
Язык: english
By emphasizing the application of computer programming not only in success stories in the software industry but also in familiar scenarios in physical and biological science, engineering, and applied mathematics, Introduction to Programming in Java takes an interdisciplinary approach to teaching programming with the Java programming language.
Elements of Programming: Your First Program; Built-in Types of Data; Conditionals and Loops; Arrays; Input and Output. Functions and Modules: Static Methods; Libraries and Clients; Recursion. Object-Oriented Programming: Data Types; Creating Data Types; Designing Data Types. Algorithms and Data Structures: Performance; Sorting and Searching; Stacks and Queues; Symbol Tables.
For all readers interested in introductory programming courses using the Java programming language.
Эти 2 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
24.12.2013, 09:37
Сказал спасибо: 337
Re: Книги
Building Valve Amplifiers
Название: Building Valve Amplifiers
Автор: Morgan Jones
Издательство: Newnes
Год: 2014
Страниц: 647
ISBN: 978-0-08-096638-0
Формат: PDF
Язык: english
Building Valve Amplifiers is a unique hands-on guide for anyone working with tube audio equipment--as an electronics hobbyist, audiophile or audio engineer. This 2nd Edition builds on the success of the first with technology and technique revisions throughout and, significantly, a major new self-build project, worked through step-by-step, which puts into practice the principles and techniques introduced throughout the book.
Particular attention has been paid to answering questions commonly asked by newcomers to the world of the valve, whether audio enthusiasts tackling their first build or more experienced amplifier designers seeking to learn about the design principles and trade-offs of "glass audio." Safety considerations are always to the fore, and the practical side of this book is reinforced by numerous clear illustrations throughout.
- The only hands-on approach to building valve and tube amps--classic and modern--with a minimum of theory
- Design, construction, fault-finding, and testing are all illustrated by step-by-step examples, enabling readers to clearly understand the content and succeed in their own projects
- Includes a complete self-build amplifier project, putting into practice the key techniques introduced throughout the book
Эти 3 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
24.12.2013, 11:01
Сказал спасибо: 337
Re: Книги
Switchmode RF and Microwave Power Amplifiers
Название: Switchmode RF and Microwave Power Amplifiers
Автор: Grebennikov A., Sokal N.O., Franco M.J.
Издательство: Academic Press
Год: 2012
Страниц: 686
ISBN: 978-0-12-415907-5
Формат: PDF
Язык: english
Power amplifiers guzzle power. At a time when there is considerable pressure to be more green and to reduce the costs of a system by developing technologies that are energy efficient, this book is particularly relevant because it focuses on energy efficient amplifiers, namely, switch mode amplifiers.
These amplifiers are at the heart of cellular/wireless communications systems, being used for the transmitter but are also widely used for satellite and radar communications. This book gives engineers all they need to know to use RF and microwave power amplifiers, balancing theory with practical examples of implementation, enabling them to understand design issues and trade-offs and improve their future designs.
*Unique focus on switchmode RF and microwave power amplifiers that are widely used in cellular/wireless, satellite and radar communication systems and which offer major power consumption savings
*Complete coverage of the new Doherty architecture which offers major efficiencies and savings on power consumption
*Balances theory with practical implementatation, avoiding a cookbook approach, enabling engineers to develop better designs
*Trusted content from leading figures in the field with a Foreword of endorsement by Zoya Popovic
Contents
Power Amplifier Design Principles
Class-D Power Amplifiers
Class-F Power Amplifiers
Inverse Class-F
Class-E with Shunt Capacitance
Class-E with Finite DC-FEed Inductance
Class-E with Quartewave Transsmition Line
Broadband Class-E
Alternative ans Mixed-Mode High-Efficiency Power Amplifiers
High-Efficiency Doherty Power Amplifier
Predistortion Linearization Techniques
Computer-Aided Design of Switchmode Power Amplifiers
25.12.2013, 23:33
Сказал спасибо: 456
Сказали Спасибо 47,137 раз(а) в 3,118 сообщении(ях)
Re: Книги
Основы оптоэлектроники Я. Суэмацу и др. 1988
DjVu, 8,3 MB
http://yadi.sk/d/yElOyVFQEwfL4
Владимир
Эти 7 пользователя(ей) сказали Спасибо AversT за это сообщение:
26.12.2013, 08:05
Сказал спасибо: 337
Re: Книги
Basic Electrical Installation Work
Название: Basic Electrical Installation Work
Автор: Trevor Linsley
Год: 2008
Страниц: 400
ISBN: 978-0-7506-8751-5
Формат: PDF
Язык: english
Trevor Linsley's textbooks have helped thousands of students to gain their electrical installation qualifications. In a concise and practical way, Basic Electrical Installation Work supports the City & Guilds 2330 Level 2 Certificate in Electrotechnical Technology.
Units covered:
- Unit 1 Working effectively and safely in the electrotechnical environment
- Unit 2 Principles of electrotechnology
- Unit 3 Application of health and safety and electrical principles
- Unit 4 Installation (Buildings & Structures)
The fifth edition has been updated in line with the 17th Edition Wiring Regulations so that students can be sure to work to the latest regulations. The structure of the book has been overhauled and it now covers each learning outcome in a dedicated chapter. Learning features, such as key facts, definitions, safety tips and end of chapter questions with answers help students to check their understanding and revise for the exams. The text is highly illustrated and the book is now in full colour.
Сказали "Спасибо" mihail62
26.12.2013, 12:19
Сказал спасибо: 337
Re: Книги
8051 Microcontrollers: An Applications Based Introduction
Название: 8051 Microcontrollers: An Applications Based Introduction
Автор: David Calcutt, Frederick Cowan, Hassan Parchizadeh
Год: 2004
Страниц: 417
ISBN: 0-7506-5759-6
Формат: PDF
Язык: english
The 8051 architecture developed by Intel has proved to be the most popular and enduring type of microcontroller, available from many manufacturers and widely used for industrial applications and embedded systems as well as being a versatile and economical option for design prototyping, educational use and other project work.
In this book the authors introduce the fundamentals and capabilities of the 8051, then put them to use through practical exercises and project work. The result is a highly practical learning experience that will help a wide range of engineers and students to get through the steepest part of the learning curve and become proficient and productive designing with the 8051. The text is also supported by practical examples, summaries and knowledge-check questions.
The latest developments in the 8051 family are also covered in this book, with chapters covering flash memory devices and 16-bit microcontrollers.
Contents:
Preface
- Microcontroller architecture
- Development board design
- Programming using assembly language
- Programming using C
- Simulation and development
- Flash microcontrollers
- Switches, motors, data converters and displays
- Serial data transmission
- PROM microcontrollers
- 16-bit microcontrollers
- Project applications
- Appendices
- Index.
Эти 5 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
26.12.2013, 22:05
Сказал спасибо: 337
Re: Книги
Windows Vista For Dummies
Название: Windows Vista For Dummies
Автор: Andy Rathbone
Издательство: Wiley
Год: 2006
Страниц: 435
ISBN: 978-0-471-75421-3, 0-471-75421-8
Формат: PDF
Язык: english
This book’s popularity probably boils down to this simple fact: Some people want to be Windows whizzes. They love interacting with dialog boxes. Some randomly press keys in the hope of discovering hidden, undocumented features. A few memorize long strings of computer commands while washing their hair.
And you? Well, you’re no dummy, that’s for sure. But when it comes to Windows and computers, the fascination just isn’t there. You want to get your work done, stop, and move on to something more important. You have no intention of changing, and there’s nothing wrong with that.
That’s where this book comes in handy. Instead of making you a whiz at Windows, it merely dishes out chunks of useful computing information when you need them. Instead of becoming a Windows Vista expert, you’ll know just enough to get by quickly, cleanly, and with a minimum of pain so that you can move on to the more pleasant things in life.
This Book Contains More About :
Part I: Windows Vista Stuff Everybody
Part II: Working with Programs and Files
Part III: Getting Things Done on the Internet
Part IV: Customizing and Upgrading Windows Vista
Part V: Music, Movies, Memories (and Photos, Too)
Part VI: Help!
Part VII: The Part of Tens
Appendix: Upgrading to Windows Vista
27.12.2013, 03:24
Сказал спасибо: 337
Re: Книги
Java for Programmers
Название: Java for Programmers
Автор: Paul J. Deitel, Harvey M. Deitel
Издательство: Pearson Education
Год: 2011
Страниц: 1168
ISBN: 978-0-13282154-4, 0-13-282154-0
Формат: PDF
Язык: english
The professional programmer’s Deitel guide to Java development and the powerful Java platform.
Written for programmers with a background in high-level language programming, this book applies the Deitel signature live-code approach to teaching programming and explores the Java language and Java APIs in depth. The book presents concepts in the context of fully tested programs, complete with syntax shading, code highlighting, line-by-line code walkthroughs and program outputs. The book features 200+ complete Java programs with 18,000+ lines of proven Java code, and hundreds of tips that will help you build robust applications.
Start with an introduction to Java using an early classes and objects approach, then rapidly move on to more advanced topics, including GUI, graphics, exception handling, generics, collections, JDBC™, web-application development with JavaServer™ Faces, web services and more. You’ll enjoy the Deitels’ classic treatment of object-oriented programming and the OOD/UML® ATM case study, including a complete Java implementation. When you’re finished, you’ll have everything you need to build object-oriented Java applications.
Practical, example-rich coverage of:
Java SE 7
Classes, Objects, Encapsulation, Inheritance, Polymorphism, Interfaces
Integrated OOP Case Studies
Industrial-Strength, 95-Page OOD/UML® ATM Case Study
JavaServer™ Faces 2.0, Ajax-Enabled Web Apps, Web Services, Networking
JDBC™, SQL, Java DB, MySQL®
Threads and the Concurrency APIs
I/O, Types, Control Statements, Methods
Arrays, Generics, Collections
Exception Handling, Files
GUI, Graphics, GroupLayout, JDIC
Using the Debugger and the API Docs
Online, Three-Chapter Introduction to Android™ App Development
Часовой пояс GMT +4, время: 22:38.
