31.01.2014, 13:39
Сказал спасибо: 337
Сказали Спасибо 30,207 раз(а) в 6,808 сообщении(ях)
Re: Книги
Analog Integrated Circuit Design
Название: Analog Integrated Circuit Design
Автор: Kenneth W. Martin, David Johns, Kenneth Martin, Tony Chan Carusone
Издательство: Wiley
Год: 2012
Страниц: 822
ISBN: 978-0-470-77010-8
Формат: PDF
Язык: English
The 2nd Edition of Analog Integrated Circuit Design focuses on more coverage about several types of circuits that have increased in importance in the past decade. Furthermore, the text is enhanced with material on CMOS IC device modeling, updated processing layout and expanded coverage to reflect technical innovations. CMOS devices and circuits have more influence in this edition as well as a reduced amount of text on BiCMOS and bipolar information. New chapters include topics on frequency response of analog ICs and basic theory of feedback amplifiers.
Эти 4 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
31.01.2014, 19:19
Сказал спасибо: 337
Re: Книги
Atmospheric Monitoring With Arduino: Building Simple Devices to Collect Data About the Environment
Название: Atmospheric Monitoring With Arduino: Building Simple Devices to Collect Data About the Environment
Автор: Patrick DiJusto, Emily Gertz
Издательство: O’Reilly
Год: 2012
Страниц: 90
ISBN: 978-1-449-33814-5
Формат: PDF, EPUB
Язык: english
Makers around the globe are building low-cost devices to monitor the environment, and with this hands-on guide, so can you. Through succinct tutorials, illustrations, and clear step-by-step instructions, you’ll learn how to create gadgets for examining the quality of our atmosphere, using Arduino and several inexpensive sensors.
Detect harmful gases, dust particles such as smoke and smog, and upper atmospheric haze—substances and conditions that are often invisible to your senses. You’ll also discover how to use the scientific method to help you learn even more from your atmospheric tests.
Get up to speed on Arduino with a quick electronics primer
Build a tropospheric gas sensor to detect carbon monoxide, LPG, butane, methane, benzene, and many other gases
Create an LED Photometer to measure how much of the sun’s blue, green, and red light waves are penetrating the atmosphere
Build an LED sensitivity detector—and discover which light wavelengths each LED in your Photometer is receptive to
Learn how measuring light wavelengths lets you determine the amount of water vapor, ozone, and other substances in the atmosphere
Upload your data to Cosm and share it with others via the Internet
31.01.2014, 19:44
Сказал спасибо: 456
Сказали Спасибо 47,137 раз(а) в 3,118 сообщении(ях)
Re: Книги
Радиоуправление моделями самолетов, кораблей и автомобилей Ю.М.Отряшенков 1959
5.2 MB, DjVu
http://yadi.sk/d/g6-z5tJLH5jWq
Владимир
Эти 8 пользователя(ей) сказали Спасибо AversT за это сообщение:
31.01.2014, 21:05
Сказал спасибо: 337
Re: Книги
Контрольно-измерительные приборы в теплотехнических измерениях
Название: Контрольно-измерительные приборы в теплотехнических измерениях
Автор: Нубарян С.М.
Издательство: ХНАГХ
Год: 2006
Страниц: 283
Формат: PDF
Язык: русский
Изложены основные сведения о методах измерения и приборах, предназначенных для контроля основных технологических параметров, используемых при контроле и управлении объектов энергетики и коммунального хозяйства.
Эти 5 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
31.01.2014, 22:53
Сказал спасибо: 337
Re: Книги
Excel 2010 For Dummies
Название: Excel 2010 For Dummies
Автор: Greg Harvey
Издательство: Wiley
Год: 2010
Страниц: 412
ISBN: 978-0-470-48953-6
Формат: PDF
Язык: english
Get up to speed on Excel 2010 and discover a whole new way to crunch numbers! Have you just discovered you need to use Excel for the first time? Or are you an Excel veteran who wants to understand the 2010 version in a hurry? Either way, this friendly book has everything you need to know about creating and editing worksheets, formatting cells, using formulas, adding hyperlinks, saving worksheets as Web pages, and more.
Эти 3 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
01.02.2014, 16:40
Сказал спасибо: 456
Re: Книги
Конструирование и расчет печатающих механизмов. Немкевич А. С., 1974
2.2 MB, DjVu
http://yadi.sk/d/aZ7UW7r6H7WEx
Владимир
Эти 7 пользователя(ей) сказали Спасибо AversT за это сообщение:
01.02.2014, 16:53
Сказал спасибо: 337
Re: Книги
Цифровые анализаторы спектра
Название: Цифровые анализаторы спектра
Автор: Плотников В.Н., Белинский А.В., Суханов В.А., Жигулевцев Ю.Н.
Издательство: Радио и связь,
Год: 1990
Страниц: 184
ISBN: 5-256-00462-Х.
Формат: PDF
Язык: русский
Излагаются основные вопросы, связанные с конструированием технических средств для цифрового динамического спектрального анализа сигналов в таких областях, как связь, акустика, радиолокация, оптика, техническая диагностика и контроль, распознавание образов и другие, где требуется обработка информации в реальном масштабе времени.
Для инженерно-технических работников, занимающихся разработкой и применением систем и устройств цифровой обработки сигналов. Может быть полезной для студентов приборостроительных, радиотехнических специальностей вузов.
01.02.2014, 17:05
Сказал спасибо: 456
Re: Книги
Измерение параметров оптических покрытий. Комраков Б. М., Шапочкин Б. А. 1986
3.1 MB, DjVu
http://yadi.sk/d/AcxoCDPkH7aKb
Владимир
Эти 6 пользователя(ей) сказали Спасибо AversT за это сообщение:
01.02.2014, 17:33
Сказал спасибо: 337
Re: Книги
1001 совет по обустройству компьютера
Название: 1001 совет по обустройству компьютера
Автор: Ревич Юрий
Издательство: БХВ-Петербург
ISBN: 978-5-9775-0731-8
Год: 2012
Страниц: 306
Формат: PDF
Язык: Русский
В книге собраны и обобщены советы по решению различных проблем, которые рано или поздно возникают при эксплуатации как экономичных нетбуков, так и современных настольных моделей. Все приведенные рецепты опробованы на практике и разбиты по темам: аппаратные средства персональных компьютеров, компьютерные сети и подключение к Интернету, установка, настройка и ремонт ОС Windows, работа в Интернете, защита от вирусов.
Рассмотрены не только готовые решения внезапно возникающих проблем, но и ответы на многие вопросы, которые возникают еще до покупки компьютера. Приведен необходимый минимум технических сведений, позволяющий принять осознанное решение. Компакт-диск прилагается только к печатному изданию книги.
Последний раз редактировалось mihail62; 01.02.2014 в 17:36.
Эти 6 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
01.02.2014, 23:04
Сказал спасибо: 337
Re: Книги
Монтаж электрических установок
Название: Монтаж электрических установок
Автор: Соколов Б.А., Соколов Н.Б.
Издательство: Энергоатомиздат
Год: 1991
Страниц: 592
ISBN: 5-283-00984-X
Формат: DJVU
Язык: русский
Изложены вопросы подготовки, организации и производства работ по монтажу различных электроустановок, электропроводок, кабельных и воздушных линий. Второе издание вышло в 1982 году. В третьем издании учтены вновь разработанные и пересмотренные нормативные документы (ПУЭ, СНиП и др).
Для широкого круга электротехников: инженеров, техников, мастеров, бригадиров и рабочих-электромонтажников.
Часовой пояс GMT +4, время: 18:54.
