13.12.2016, 15:04
Сказал спасибо: 456
Сказали Спасибо 47,137 раз(а) в 3,118 сообщении(ях)
Re: Книги
Несущие конструкции радиоэлектронной аппаратуры. Овсищер П.И., Голованов Ю.В., Ковешников В.П., Орчинский А.К., Пименов А.И., Фридрих В.Л. Под ред. Овсищера П.И. 1988
11.8 MB, DjVu, OCR
https://yadi.sk/i/drIXr1ST33N7Wc
http://depositfiles.com/files/oeoavzbux
Scan: AAW, DjVuing: pohorsky
Владимир
Эти 11 пользователя(ей) сказали Спасибо AversT за это сообщение:
beebeep (14.12.2016), Drex (20.12.2016), kipiaxxx (13.12.2016), mcu51 (13.12.2016), Nikolay-starikov (18.12.2016), safoso (14.12.2016), scenter (13.12.2016), seanta (16.02.2017), sntch1950 (03.01.2017), valesyk (14.12.2016), vasilenko_pit (13.12.2016) |
14.12.2016, 01:55
Сказал спасибо: 337
Сказали Спасибо 30,207 раз(а) в 6,808 сообщении(ях)
Re: Книги
Arduino Led Cube Projects
Название: Arduino Led Cube Projects
Автор: Robert J Davis II
Издательство: CreateSpace Independent Publishing Platform
Год: 2015
Страниц: 56
ISBN: 1512227110, 978-1512227116
Формат: PDF, EPUB
Язык: English
The first book of LED projects started with individual LED’s and ended with LED signs. Since then I have discovered the fun of making LED cubes. There are so many variations of LED cubes that there almost could be a book written that is just dedicated to how to make the many varieties of LED cubes.
As always the reader or builder takes all responsibility for the safe construction and operation of these devices. If you are not familiar with building complex projects it is highly recommended that you start off with the first book of “Arduino LED Projects”.
These projects are fairly complex. I have tried to make them look like they are easy to build. Every design in this book has an explanation, a schematic diagram, a picture of the assembled project, and the code to make it work. This is written to get you started, adding more layers, or customizing the code can make this a lot more fun.
Most of the parts to build these projects will need to be ordered from China via eBay or one of the mail order parts vendors like MCM Electronics. Some of the parts are available at your local Radio Shack. Some of the parts were just lying around because they were left over from previous projects.
На всякий Гугол свой Йобибайт найдется!
14.12.2016, 12:27
Сказал спасибо: 456
Re: Книги
Конструирование приборов и устройств радиоэлектронной аппаратуры. Поляков К.П. 1982
5.1 MB, DjVu
https://yadi.sk/i/pZQODJep33TTMP
http://depositfiles.com/files/w55pbh57x
Владимир
Эти 15 пользователя(ей) сказали Спасибо AversT за это сообщение:
Ba_sandr2 (17.12.2016), beebeep (14.12.2016), Drex (20.12.2016), giv2 (19.12.2016), kipiaxxx (14.12.2016), mcu51 (14.12.2016), nckvrb (30.12.2016), Nikolay-starikov (18.12.2016), safoso (14.12.2016), scenter (14.12.2016), seanta (16.02.2017), sntch1950 (03.01.2017), valesyk (15.12.2016), vasilenko_pit (15.12.2016), vlnikb (16.12.2016) |
14.12.2016, 15:23
Сказал спасибо: 337
Re: Книги
Androids: Build Your Own Lifelike Robots
Название: Androids: Build Your Own Lifelike Robots
Автор: Bryan Bergeron, Thomas Talbot
Издательство: McGraw-Hill
Год: 2014
Страниц: 336
ISBN: 0071814043, 978-0071814041
Формат: EPUB
Язык: English
Create the next generation of autonomous Androids!
Construct self-governing 'droids that display physiologically correct behaviors. Co-written by experts in the fields of robotics, artificial intelligence, and medicine, Androids: Build Your Own Lifelike Robots features low-cost DIY projects that translate human physiology into cybernetics. Teach your creations to maneuver with an arsenal of behaviors, respond to stimuli, talk, and listen. This practical, inventive guide even shows how to realistically simulate emotion and aging in your robots.
Understand cybernetic and robotics principles
Work with programmable microcontrollers
Choose and wire sensors, actuators, and servos
Program dazzling reflex arcs and behavior loops
Enable your automatons to speak and hear
Build beating hearts and limbs with flowing veins
Create breathing patterns that respond to triggers
Mimic humanoid feelings and facial expressions
Use prototyping kits and testing devices
15.12.2016, 04:19
Сказал спасибо: 337
Re: Книги
Raspberry Pi Lcd Projects
Название: Raspberry Pi Lcd Projects
Год: 2016
Страниц: 122
ISBN: 1537167510, 978-1537167510
Формат: PDF, DJVU
Язык: English
How to interface several LCD's to a Raspberry Pi using only Python.
Table of Contents
1. Raspberry Pi Setup
Setting up NOOBS 1.8
Raspberry Pi Model 2
Raspberry Pi Zero
Enabling SPI
2. Things to Make
Making a GPIO extension
Making a Logic Probe
3. Adding Analog Inputs
MCP3008 ADC
Control Panel
Alternate MCP2008
4. Character based LCD’s
1602 (16x2) and 2004 (20x4)
5. Nokia Graphics 64x128
PCD8544 Controller
6. Mono Graphics 128x64
ST7920 Controller
7. 1.8 inch TFT SPI 128x160
ST7735 Controller
8. 2.8 inch TFT SPI 240x320
ILI9341 Controller
9. 2.4 inch TFT Parallel 240x320
ILI9325 Controller
10. 3.2 inch TFT Parallel 240x320
SSD1289 Controller
Bibliography
Сказали "Спасибо" mihail62
15.12.2016, 08:57
Сказал спасибо: 337
Re: Книги
Raspberry Pi Projects For Dummies
Название: Raspberry Pi Projects For Dummies
Автор: Mike Cook, Jonathan Evans, Brock Craft
Издательство: Wiley
Год: 2015
Страниц: 504
ISBN: 1118766695
Формат: EPUB
Язык: English
Join the Raspberry revolution with these fun and easy Pi projects. The Raspberry Pi has opened up a whole new world of innovation for everyone from hardware hackers and programmers to students, hobbyists, engineers, and beyond. Featuring a variety of hands–on projects, this easy–to–understand guide walks you through every step of the design process and will have you creating like a Raspberry Pi pro in no time. You ll learn how to prepare your workspace, assemble the necessary tools, work with test equipment, and find your way around the Raspberry Pi before moving on to a series of fun, lively projects that brings some power to your plain ol Pi.
Introduces Raspberry Pi basics and gives you a solid understanding of all the essentials you ll need to take on your first project
Includes an array of fun and useful projects that show you how to do everything from creating a magic light wand to enhancing your designs with Lego sensors, installing and writing games for the RISC OS, building a transistor tester, and more
Provides an easy, hands–on approach to learning more about electronics, programming, and interaction design for Makers and innovators of all ages
Bring the power of Pi to your next cool creation with Raspberry Pi Projects For Dummies!
15.12.2016, 23:49
Сказал спасибо: 337
Re: Книги
Oscilloscope Applications For The Qrp Enthusiast
Название: Oscilloscope Applications For The Qrp Enthusiast
Автор: James McClanahan
Издательство: Amazon Media EU S.a r.l.
Год: 2015
Страниц: 50
Формат: PDF, DJVU
Язык: English
QRP continues to be one of the more active segments of the amateur radio hobby. Different people are drawn to QRP for different reasons but, for many, part of the fun is in building and learning. The oscilloscope is an affordable and useful tool to helping learn more about how (or if) your QRP transmitter is working. Because of that, the questions, "Should I buy an oscilloscope?" or, even more often, "I just bought an oscilloscope, what can I use it for?" frequently come up.
This short book shows how to use the Rigol DS1102E an oscilloscope to measure and characterize the popular Tuna Tin 2 QRP transmitter. The approach and examples are applicable to virtually any modern oscilloscope and QRP transmitter.
If you are a QRP enthusiast who has just purchased an oscilloscope or is thinking about the purchase of one, this book will show you the basics of using a scope to measure output power and efficiency along with evaluating the keying waveform and harmonic suppression of your latest transmitter project.
A QRP transmitter, an oscilloscope, the ability to build a few simple test accessories, and a desire to peal back a layer of the onion and gain a deeper understand of how your transmitter works are all that is needed to start the journey!
16.12.2016, 07:16
Сказал спасибо: 337
Re: Книги
Implementing of an Arduino based Temperature controller with PID algorithm
Название: Implementing of an Arduino based Temperature controller with PID algorithm
Автор: Seyedreza Fattahzadeh
Издательство: Amazon Digital Services LLC
Год: 2015
Страниц: 105
Формат: PDF, EPUB
Язык: English
The role of the temperature controller is to measure the value on the thermometer, compare it to the set point and calculate the amount of time the hot water solenoid valve should remain switched on to maintain a constant temperature. How accurately we need to control the temperature will also determine the type of temperature controller we have to use.
The manual is laid into four chapters, three of which emphasize on the code and hardware of a relay can be turned on and off to control the temperature of a small water filled container using a typical ATmega8 Microcontroller. The last chapter explains how, by applying two SSR's, the temperature of the same container with a PID control can be managed using an Arduino ATmega2560 development board.
The main control program solutions are prepared in C language using CodevisionAVR and Arduino software. In addition, the schematic of all the hardware used in these projects are available in the text. You will find details on the creation of code for an ATmega8 Microcontroller and Arduino development board that controls a temperature process. This book has been prepared for those who are already familiar with basic instructions related to any brand of Microcontroller and may have already developed some microcontroller-based programs for different purposes.
Эти 7 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
16.12.2016, 08:02
Сказал спасибо: 337
Re: Книги
Build Your Own Transistor Radios
Название: Build Your Own Transistor Radios: A Hobbyist's Guide to High-Performance and Low-Powered Radio Circuits
Автор: Ronald Quan
Год: 2013
Страниц: 550
ISBN: 0071799702, 978-0071799706
Формат: PDF
Язык: Englich
A DIY guide to designing and building transistor radios
Create sophisticated transistor radios that are inexpensive yet highly efficient. Build Your Own Transistor Radios: A Hobbyist’s Guide to High-Performance and Low-Powered Radio Circuits offers complete projects with detailed schematics and insights on how the radios were designed. Learn how to choose components, construct the different types of radios, and troubleshoot your work. Digging deeper, this practical resource shows you how to engineer innovative devices by experimenting with and radically improving existing designs.
Build Your Own Transistor Radios covers:
Calibration tools and test generators
TRF, regenerative, and reflex radios
Basic and advanced superheterodyne radios
Coil-less and software-defined radios
Transistor and differential-pair oscillators
Filter and amplifier design techniques
Sampling theory and sampling mixers
In-phase, quadrature, and AM broadcast signals
Resonant, detector, and AVC circuits
Image rejection and noise analysis methods
This is the perfect guide for electronics hobbyists and students who want to delve deeper into the topic of radio. Make Great Stuff! TAB, an imprint of McGraw-Hill Professional, is a leading publisher of DIY technology books for makers, hackers, and electronics hobbyists.
Эти 4 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
16.12.2016, 11:50
Сказал спасибо: 456
Re: Книги
Основы теории цепей. Матвиенко В.А. 2016
10.4 MB, PDF
https://yadi.sk/i/9Qwycxh-33gdZQ
Владимир
Эти 21 пользователя(ей) сказали Спасибо AversT за это сообщение:
agnnik (18.12.2016), AYuM (17.12.2016), beebeep (16.12.2016), Drex (20.12.2016), dryupitz (17.12.2016), floppyboy (16.12.2016), gladun5 (30.12.2016), kipiaxxx (17.12.2016), mcu51 (22.12.2016), nckvrb (30.12.2016), Nikolay-starikov (18.12.2016), safoso (16.12.2016), scenter (16.12.2016), sdeg (20.12.2016), seanta (16.02.2017), sntch1950 (03.01.2017), stiv_fil (23.12.2016), valesyk (17.12.2016), vasilenko_pit (16.12.2016), vassy13 (03.02.2017), vlnikb (16.12.2016) |
Часовой пояс GMT +4, время: 17:28.
