12.11.2010, 19:49
#81
Re: Библиотека SSD1289
А какой текущий такт? Встроенный RC или PLL с кварцем?
12.11.2010, 20:19
#82
Сказал спасибо: 470
Сообщение от kison
Сейчас встроенный RC!
Кстати вот нашел процедуру работы с моим дисплеем!
PHP код:
void WriData(uint ch)
LCD_RS_1;
LCD_WR_1;
LCD_CS_0;
LCD_DATA(ch);
LCD_WR_0;
LCD_CS_1;
void WriCom(uint ch)
LCD_RS_0;
LCD_WR_1;
LCD_CS_0;
LCD_DATA(ch);
LCD_WR_0;
LCD_CS_1;
void write_com(uint address,uint num)
WriCom(address);
WriData(num);
void TftInit(void)
LCD_RESET_0; //µНµзЖЅёґО»
DelayMs(10);
LCD_RESET_1;
write_com(0x0000,0x0001); DelayMs(10); //ґтїЄѕ§Хс
write_com(0x0003,0xA8A4); DelayMs(10); //0xA8A4
write_com(0x000C,0x0000); DelayMs(10);
write_com(0x000D,0x080C); DelayMs(10);
write_com(0x000E,0x2B00); DelayMs(10);
write_com(0x001E,0x00B0); DelayMs(10);
write_com(0x0001,0x2B3F); DelayMs(10); //Зэ¶ЇКдіцїШЦЖ320*240 0x6B3F
write_com(0x0002,0x0600); DelayMs(10);
write_com(0x0010,0x0000); DelayMs(10);
write_com(0x0011,0x6070); DelayMs(10); //0x4030 //¶ЁТеКэѕЭёсКЅ 16О»Й«
write_com(0x0005,0x0000); DelayMs(10);
write_com(0x0006,0x0000); DelayMs(10);
write_com(0x0016,0xEF1C); DelayMs(10);
write_com(0x0017,0x0003); DelayMs(10);
write_com(0x0007,0x0233); DelayMs(10); //0x0233
write_com(0x000B,0x0000); DelayMs(10);
write_com(0x000F,0x0000); DelayMs(10); //ЙЁГиїЄКјµШЦ·
write_com(0x0041,0x0000); DelayMs(10);
write_com(0x0042,0x0000); DelayMs(10);
write_com(0x0048,0x0000); DelayMs(10);
write_com(0x0049,0x013F); DelayMs(10);
write_com(0x004A,0x0000); DelayMs(10);
write_com(0x004B,0x0000); DelayMs(10);
write_com(0x0044,0xEF00); DelayMs(10);
write_com(0x0045,0x0000); DelayMs(10);
write_com(0x0046,0x013F); DelayMs(10);
write_com(0x0030,0x0707); DelayMs(10);
write_com(0x0031,0x0204); DelayMs(10);
write_com(0x0032,0x0204); DelayMs(10);
write_com(0x0033,0x0502); DelayMs(10);
write_com(0x0034,0x0507); DelayMs(10);
write_com(0x0035,0x0204); DelayMs(10);
write_com(0x0036,0x0204); DelayMs(10);
write_com(0x0037,0x0502); DelayMs(10);
write_com(0x003A,0x0302); DelayMs(10);
write_com(0x003B,0x0302); DelayMs(10);
write_com(0x0023,0x0000); DelayMs(10);
write_com(0x0024,0x0000); DelayMs(10);
write_com(0x0025,0x8000); DelayMs(10);
write_com(0x004f,0); //РРКЧЦ·0
write_com(0x004e,0); //БРКЧЦ·0
DelayMs(20);
12.11.2010, 21:59
#83
Сообщение от Uragan90
И что - завелось?
13.11.2010, 17:10
#84
Сказал спасибо: 470
kison, Попытка №128 прошла не удачно! Может дисплей "раненый" попался, или надо точно узнать на каком контроллере да с нуля по даташиту писать процедуры инициализации и т.д. Спасибо всем кто пытался помочь!!!
14.11.2010, 02:17
#85
Сказал спасибо: 12
Сказали Спасибо 67 раз(а) в 61 сообщении(ях)
Так он вообще завёлся или нет ?
14.11.2010, 13:10
#86
Сказал спасибо: 470
МК работает как заказывал, а дисплей даже и не признается!
14.11.2010, 19:22
#87
Сказал спасибо: 470
Чет не выходит ничего Может есть способ какой узнать навернека, живой дисплей или нет? Просто убедится!!! А то время потратиш, а он трупом все это время был МК уже настроил на работу от 72мгц, работает, на линиях дисплея изменяются уровни что видно осциллом, и хоть бы что
14.11.2010, 19:28
#88
Сказал спасибо: 12
Я занимался подобным дисплеем. Попробую откопать свой инит. Он на другом винте, который слегка посыпался. Так что на 100% гарантировать не могу.
P.S. Инит с vtrp мне тоже не подошел
Сказали "Спасибо" Cybermaker
15.11.2010, 11:48
#89
Сказал спасибо: 12
Нашел с трудом так как проет тестовый. Инит в функции lcd_show().
15.11.2010, 11:53
#90
Сказал спасибо: 12
Что именно происходит в ините сказать не могу. Кусок был передран из pdf'ки в которой были описаны иниты для контроллера под разные lcd. Первоисточник на моих компах искать уже бесполезно. Добавлю что в ините чуть сдвинуто начало видопамяти. Но индикатор при этом всё равно заводился.
Обнаружил строчку в комменте:
if (lcd_read_reg(0) != 0x9320) while (1); // stall if no LCD connected
Думаю её можно применить для теста работоспособности lcd как такового
Последний раз редактировалось Cybermaker; 15.11.2010 в 11:57.
Часовой пояс GMT +4, время: 19:11.
