30.12.2016, 05:49
Сказал спасибо: 337
Сказали Спасибо 30,207 раз(а) в 6,808 сообщении(ях)
Re: Книги
Electronics from the Ground Up
Название: Electronics from the Ground Up: Learn by Hacking, Designing, and Inventing
Автор: Ronald Quan
Издательство: McGraw-Hill
Год: 2015
Страниц: 458
ISBN: 0071837280
Формат: PDF
Язык: English
Discover the inner-workings of electronics through innovative hands-on experiments. Are you fascinated by the power of even the smallest electronic device? Electronics from the Ground Up guides you through step-by-step experiments that reveal how electronic circuits function so you can advance your skills and design custom circuits. You’ll work with a range of circuits and signals related to optical emitters and receivers, audio, oscillators, and video.
This practical resource explains components, construction techniques, basic test equipment, circuit analysis, and troubleshooting. Photographs, schematics, equations, and graphs are included throughout. By the end of the book, you’ll be able to hack and modify existing circuits to create your own unique designs.
Do-it-yourself experiments cover:
Batteries, lamps, and flashlights
Light emitters and receivers
Diodes, rectifiers, and associated circuits
Transistors, FETs, and vacuum tubes
Amplifiers and feedback
Audio signals and circuits
Oscillators
AM and FM signals and circuits
Video basics, including video signals
Video circuits and systems
На всякий Гугол свой Йобибайт найдется!
Сказали "Спасибо" mihail62
30.12.2016, 07:57
Сказал спасибо: 337
Re: Книги
Arduino Servo Projects
Название: Arduino Servo Projects
Автор: Robert J Davis II
Издательство: CreateSpace Independent Publishing Platform
Год: 2015
Страниц: 103
ISBN: 1519291884
Формат: PDF, EPUB
Язык: English
This is essentially a continuation of my earlier book “Arduino Robotics Projects”. These are some more advanced robotics projects and they will use a lot of servos. Some readers have complained that the projects in the earlier book required specific toys in order to work. That was not the intention. Instead the book was meant to teach the basics for robotics and then to show some simple examples showing how to apply what you have learned. This book will repeat some of what was covered in that book in case you did not read it first.
Table of Contents
1. Working with Servos
How Servos Work
Typical Servos
Setting up the Servos
Working With More than 12 Servos
2. The Servo Building Blocks
The Various Parts
Parts Sources
Making a better Chest
3. Servo Controller Shield
How to Build Your Own
Battery Arrangements
4. IR Remote Control Setup
Reading Your Remote codes
5. Bluetooth Setup
6. Walking Humanoid Robot 9 DOF
Making your own Feet
7. Walking Humanoid Robot 13 DOF
Adding Knees and Hands
8. Walking Humanoid Robot 17 DOF
Improved Hips and Hands
9. Walking Dog Robot 14 DOF
10. Walking Dinosaur Robot 17 DOF
Adding the Tail
Bibliography
30.12.2016, 11:43
Сказал спасибо: 337
Re: Книги
Mouvement, lumière et son avec Arduino et Raspberry Pi
Название: Mouvement, lumière et son avec Arduino et Raspberry Pi
Автор: Simon Monk
Издательство: Eyrolles
Год: 2016
Страниц: 349
ISBN: 2212118074, 978-2212118070
Формат: PDF
Язык: французский
Cet ouvrage à vocation pratique explique comme créer et contrôler des mouvements, de la lumière et du son à l'aide d'un Arduino et d'un Raspberry Pi. Avec à l'appui 30 projets ludiques à réaliser, il détaille comment utiliser ces deux plates-formes pour contrôler des LED, des moteurs de divers types, des bobines, des dispositifs à courant alternatif, des pompes, ou encore des systèmes d'affichage ou de production de sons. Il se clôt par des projets permettant de contrôler des mécanismes et des systèmes avec Internet, faisant ainsi pénétrer le lecteur dans le monde des objets connectés. Le maker, qui aura déjà eu l'occasion d'utiliser un Arduino ou un Raspberry Pi pour mesurer le monde réel à l'aide de capteurs, passera ici à l'action en découvrant les bases de l'automatisation.
Эти 2 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
30.12.2016, 19:49
Сказал спасибо: 403
Сказали Спасибо 107 раз(а) в 44 сообщении(ях)
Re: Книги
Вот бы на древнемарсианском чего почитать. А лучше на языке племени Мумбо-Юмбо.
Эти 2 пользователя(ей) сказали Спасибо vbhjy за это сообщение:
31.12.2016, 03:33
Сказал спасибо: 337
Re: Книги
Getting Started with Sensors (+code)
Название: Getting Started with Sensors (+code)
Автор: Kimmo Karvinen, Tero Karvinen
Издательство: Maker Media, Inc.
Год: 2014
Страниц: 140
ISBN: 1449367089, 978-1449367084
Формат: PDF, DJVU
Язык: English
To build electronic projects that can sense the physical world, you need to build circuits based around sensors: electronic components that react to physical phenomena by sending an electrical signal. Even with only basic electronic components, you can build useful and educational sensor projects.
But if you incorporate Arduino or Raspberry Pi into your project, you can build much more sophisticated projects that can react in interesting ways and even connect to the Internet. This book starts by teaching you the basic electronic circuits to read and react to a sensor. It then goes on to show how to use Arduino to develop sensor systems, and wraps up by teaching you how to build sensor projects with the Linux-powered Raspberry Pi.
Contents
Preface vii
1/Sensors 1
Project 1: Photoresistor to Measure Light 3
2/Basic Sensors 9
Project 2: A Simple Switch 9
Project 3: Buzzer Volume Control 12
Project 4: Hall Effect 14
Project 5: Firefly 17
3/Sensors and Arduino 33
Project 6: Momentary Push-Button and Pull-Up Resistors 34
Project 7: Infrared Proximity to Detect Objects 40
Project 8: Rotation (Pot) 43
Project 9: Photoresistor to Measure Light 47
Project 10: FlexiForce to Measure Pressure 49
Project 11: Measuring Temperature (LM35) 52
Project 12: Ultrasonic Distance Measuring (HC-SR04) 56
4/Sensors and the Raspberry Pi 63
Project 13: Momentary Push Button 64
Project 14: Blink an LED with Python 69
Project 15: Adjustable Infrared Switch 73
Project 16: Potentiometer to Measure Rotation 77
Project 17: Photoresistor 82
Project 18: FlexiForce 85
Project 19: Temperature Measurements (LM35) 86
Project 20: Ultrasonic Distance 89
A/Troubleshooting Tactics 95
B/Arduino IDE Setup 97
C/ Setting Up Raspberry Pi 101
D/Bill of Materials 117
Index 123
Эти 3 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
31.12.2016, 04:20
Сказал спасибо: 913
Сказали Спасибо 2,329 раз(а) в 514 сообщении(ях)
Re: Книги
Основы наноэлектроники
Излагаются основные вопросы физики систем пониженной размерности, рассматриваются особенности энергетического спектра и переноса частиц в многослойных структурах с резкими потенциальными границами. В отличие от первого издания (2004 г., НТГУ) дополнительно освещаются вопросы энергетического спектра низкоразмерных систем с цилиндрической и сферической симметрией, вопросы влияния электрического поля на энергетический спектр квантовых точек и транспорт частиц в двухбарьерных структурах, дробного квантового эффекта Холла и особенностей поведения электронов в квазидвумерных системах.
Для студентов высших учебных заведений, получающих образование по направлению "Электроника и микроэлектроника" и специальностям "Микроэлектроника и твердотельная электроника" и "Микросистемная техника". Представляет интерес для ученых и специалистов в области физики полупроводников и полупроводниковых приборов, физических основ наноэлектроники.
Название: Основы наноэлектроники
Авторы: Драгунов В.П., Неизвестный И.Г., Гридчин В.А.
Издательство: Логос
Год издания: 2006
Страниц: 495
Формат: PDF
Язык: Русский
31.12.2016, 08:30
Сказал спасибо: 337
Re: Книги
Audio IC Circuits Manual
Название: Audio IC Circuits Manual
Автор: Marston R.M
Издательство: Newnes
Год: 1989
Страниц: 174
ISBN: 0434912107, 978-0-434-91210-0
Формат: PDF, DJVU
Язык: English
Audio IC Circuits Manual is a single-volume practical "user" information and circuitry guide to the most popular and useful of audio and audio-associated integrated circuits. This book deals with ICs such as low frequency linear amplifiers, dual pre-amplifiers, audio power amplifiers, charged-coupled device delay lines, bar-graph display drivers, and power supply regulators.
This book is divided into seven chapters that focus on the application of these devices in circuits ranging from simple signal conditioners and filters to complex graphic equalizers, stereo amplifier systems, and echo/reverb delay line systems. Chapters 1 to 4 deal with pure "audio" subjects, such as audio processing circuits, audio pre-amplifier circuits, and audio power amplifier circuits. Chapters 5 and 6 consider audio-associated subjects of light-emitting diode bar-graph displays, and CCD delay-line circuits. Chapter 7 deals with power supply circuits for use in audio systems.
This manual is intended primarily to design engineers, technicians, and electronic students.
Contents
Preface vii
1. Audio processing circuits 1
2. Audio pre-amplifier circuits 46
3. Audio power amplifier circuits 65
4. High-power audio amplifiers 91
5. LED bar-graph displays 112
6. CCD audio delay-line circuits 132
7. Power supply circuits 154
Index 166
Последний раз редактировалось mihail62; 31.12.2016 в 08:37.
Эти 5 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
31.12.2016, 11:57
Сказал спасибо: 106
Сказали Спасибо 275 раз(а) в 92 сообщении(ях)
Re: Книги
Сообщение от vbhjy
Не нравится французский?
Вот инфо от ливанского коллеги OD5SK:
Simon Monk, "Make: Action: Movement, Light, and Sound with Arduino and Raspberry Pi"
English | ISBN: 1457187795 | 2016 | PDF/EPUB/MOBI | 360 pages | 140 MB/140 MB/244 MB
Beginning with the basics and moving gradually to greater challenges, this book takes you step-by-step through experiments and projects that show you how to make your Arduino or Raspberry Pi create and control movement, light, and sound. In other words: action!
The Arduino is a simple microcontroller with an easy-to-learn programming environment, while the Raspberry Pi is a tiny Linux-based computer. This book clearly explains the differences between the Arduino and Raspberry Pi, when to use them, and to which purposes each are best suited.
Using these widely available and inexpensive platforms, you'll learn to control LEDs, motors of various types, solenoids, AC (alternating current) devices, heaters, coolers, displays, and sound. You'll even discover how to monitor and control these devices over the Internet. Working with solderless breadboards, you'll get up and running quickly, learning how to make projects that are as fun as they are informative. In Make: Action, you'll learn to:
Build a can crusher using a linear actuator with your Arduino
Have an Arduino water your plants
Build a personal traffic signal using LEDs
Make a random balloon popper with Arduino
Cool down your beverages with a thermostatic drink cooler you build yourself
Understand and use the PID control algorithm
Use Raspberry Pi to create a puppet dance party that moves to your tweets!
Nitroflare (PDF) ( http://nitroflare.com/view/5E9A271AC...1457187795.pdf)
Nitroflare (EPUB) ( http://nitroflare.com/view/14FA0046E...457187795.epub)
Nitroflare (MOBI) ( http://nitroflare.com/view/751E8C785...457187795.mobi)
31.12.2016, 13:00
Сказал спасибо: 337
Re: Книги
На английском эта книга на форуме с 30.05.2016:
Название: Make: Action: Movement, Light, and Sound with Arduino and Raspberry Pi
Автор: Simon Monk
Год: 2016
Страниц: 355
ISBN: 1457187795, 9781457187797
Формат: PDF
Язык: English
https://kazus.ru/forums/showpost.php...postcount=2212
Все ссылки рабочие.
Последний раз редактировалось mihail62; 31.12.2016 в 13:13.
31.12.2016, 14:00
Сказал спасибо: 7,352
Сказали Спасибо 556 раз(а) в 57 сообщении(ях)
Re: Книги
Миловзоров В.П._Электромагнитные устройства автоматики_4-е изд_1983
https://yadi.sk/i/vcd1VzBK367qwE
Эти 10 пользователя(ей) сказали Спасибо scenter за это сообщение:
Часовой пояс GMT +4, время: 04:04.
