24.09.2014, 00:27
Сказал спасибо: 337
Сказали Спасибо 30,207 раз(а) в 6,808 сообщении(ях)
Re: Книги
Build Your Own Quadcopter: Power Up Your Designs with the Parallax Elev-8
Название: Build Your Own Quadcopter: Power Up Your Designs with the Parallax Elev-8
Автор: Donald Norris
Издательство: McGraw-Hill/TAB Electronics
Год: 2014
Страниц: 364
ISBN: 0071822283, 9780071822282
Формат: PDF
Язык: English
Build and customize radio-controlled quadcopters that take off, land, hover, and soar. Build Your Own Quadcopter: Power Up Your Designs with theParallax Elev-8 features step-by-step assembly plans and experiments that will have you launching fully functioning quadcopters in no time. Discover how to connect Elev-8 components, program the microcontroller, use GPS, and safely fly your quadcopter.
This fun, do-it-yourself guide fuels your creativity with ideas for radical enhancements, including return-to-home functionality, formation flying, and even artificial intelligence!
Understand the principles that govern how quadcopters fly
Explore the parts included in your Parallax Elev-8 kit
Follow illustrated instructions and assemble a basic 'copter
Connect the Parallax chip to a PC and write Spin and C programs
Build radio-controlled systems that minimize interference
Add GPS and track your aircraft through Google Earth
Beam flight information to smartphones with WiFi and XBee technology
Mount cameras and stream real-time video back to the ground
Train to safely operate a quadcopter using flight simulation software
http://borncash.org/load/0006006686
http://turbobit.net/duvfhfh6b469.html
http://startfiles.org/load/0006006686
Эти 2 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
24.09.2014, 01:35
Сказал спасибо: 337
Re: Книги
Краткий справочник по радиолампам
Название: Краткий справочник по радиолампам
Автор: Федоров С.П.
Издательство: Воениздат
Год: 1949
Страниц: 220
Формат: DJVU
Язык: русский
В справочнике приведены электрические режимы, параметры, цоколевки и габариты приемно-усилительных, генераторных, выпрямительных и специальных ламп, применяемых в радиоаппаратуре. Подробно изложен материал по приемно-усилительным и генераторным лампам отечественного производства с приведением основных статических характеристик.
Основные данные о новых приемно-усилительных лампах, выпускаемых нашей промышленностью, приведены в отдельной таблице. В сводных таблицах приведены основные данные о радиолампах иностранного производства.
http://borncash.org/load/0006006687
http://file-space.org/files/get/3FFt...-1949.rar.html
http://turbobit.net/wt4isky6e9nb.html
http://startfiles.org/load/0006006687
Эти 6 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
24.09.2014, 02:05
Сказал спасибо: 337
Re: Книги
Hacking Electronics: An Illustrated DIY Guide for Makers and Hobbyists
Название: Hacking Electronics: An Illustrated DIY Guide for Makers and Hobbyists
Автор: Simon Monk
Издательство: Tab Books, McGrawHill
Год: 2013
Страниц: 304
ISBN: 0071802363, 9780071802369
Формат: PDF
Язык: English
Bring your electronic inventions to life!
"This full-color book is impressive...there are some really fun projects!"
Who needs an electrical engineering degree? This intuitive guide shows how to wire, disassemble, tweak, and re-purpose everyday devices quickly and easily. Packed with full-color illustrations, photos, and diagrams, Hacking Electronics teaches by doing--each topic features fun, easy-to-follow projects. Discover how to hack sensors, accelerometers, remote controllers, ultrasonic rangefinders, motors, stereo equipment, microphones, and FM transmitters.
The final chapter contains useful information on getting the most out of cheap or free bench and software tools.
• Safely solder, join wires, and connect switches
• Identify components and read schematic diagrams
• Understand the how and why of electronics theory
• Work with transistors, LEDs, and laser diode modules
• Power your devices with a/c supplies, batteries, or solar panels
• Get up and running on Arduino boards and pre-made modules
• Use sensors to detect everything from noxious gas to acceleration
• Build and modify audio amps, microphones, and transmitters
• Fix gadgets and scavenge useful parts from dead equipment
http://turbobit.net/qzxxrux9fq69.html
Последний раз редактировалось mihail62; 01.10.2017 в 14:32.
Эти 7 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
24.09.2014, 20:14
Сказал спасибо: 337
Re: Книги
Генератор с шунтирующим диодом
Название: Генератор с шунтирующим диодом
Автор: Момот Е.Г.
Издательство: Госэнергоиздат
Год: 1959
Страниц: 156
Формат: PDF
Язык: русский
В книге рассматриваются возможности весьма простыми средствами заранее и с высокой точностью задавать амплитуду колебаний генератора с самовозбуждением. Наряду с общим представлением о генераторе с шунтирующим диодом, даются основные схемы и приближенные методы расчета этих схем. Излагается методика технического расчета генератора с шунтирующим диодом и указываются его практические применения.
Книга предназначена для инженеров-электриков, работающих в радиотехнической промышленности и в соответствующих научно-исследовательских и проектных организациях.
http://borncash.org/load/0006006691
http://turbobit.net/zendvgwk5h5p.html
http://startfiles.org/load/0006006691
24.09.2014, 21:05
Сказал спасибо: 456
Сказали Спасибо 47,137 раз(а) в 3,118 сообщении(ях)
Re: Книги
Приборы автоматического контроля и регулирования. Жарковский Б.И. 1989
6 MB, DjVu
https://yadi.sk/d/-YJKvNrvbeEfS
Скан: AAW, DjVuing: pohorsky
Владимир
Эти 12 пользователя(ей) сказали Спасибо AversT за это сообщение:
13qq (25.09.2014), kipiaxxx (25.09.2014), kreking (25.09.2014), mcu51 (25.09.2014), nckvrb (24.09.2014), Novol (26.09.2014), Palagin-07 (30.09.2014), scenter (24.09.2014), sdeg (13.10.2014), seanta (25.09.2014), stiv_fil (25.09.2014), V1770 (25.09.2014) |
25.09.2014, 00:52
Сказал спасибо: 337
Re: Книги
Электрические машины. Машины переменного тока
Название: Электрические машины. Машины переменного тока
Автор: Вольдек А.И., Попов В.В.
Издательство: Питер
Год: 2007
Страниц: 350
ISBN: 978-5-469-01381-5
Формат: PDF
Язык: русский
В книге рассматриваются физические и теоретические основы электромеханического преобразования энергии в электрических машинах, излагаются конструктивные схемы различных типов электрических машин и методологические основы их исследования, анализируются их потребительские и эксплуатационные характеристики и качества, а также принципы управления электрическими машинами.
Учебник предназначен для студентов технических университетов, обучающихся по программам подготовки бакалавров и магистров по направлению 551300 "Электротехника, электромеханика и электротехнологии".
Последний раз редактировалось mihail62; 25.03.2017 в 15:05.
25.09.2014, 09:31
Сказал спасибо: 337
Re: Книги
Транзисторные аппараты защиты и коммутации для авиационных систем распределения электроэнергии
Название: Транзисторные аппараты защиты и коммутации для авиационных систем распределения электроэнергии
Автор: Машуков Е.В., Шевцов Д.А., Ульященко Г.М.
Издательство: МАИ
Год: 2009
Страниц: 180
ISBN: 978-5-7035-02091-8
Формат: PDF
Язык: русский
Изложены принципы построения, методы проектирования и средства технической реализации транзисторных аппаратов защиты и коммутации (АЗК), предназначенных для дистанционного управления потребителями электроэнергии в бортовых системах электроснабжения, а также для защиты распределительных сетей от аварийных перегрузок по току.
Рассмотрены вопросы создания бесконтактных центров управления электрическими нагрузками (ЦУН), объединяющих многоканальные АЗК и микропроцессорные средства их управления и контроля.
Приведены технические характеристики АЗК и ЦУН на современной элементной базе.
Книга рассчитана на инженерно-технических работников, проектирующих силовые транзисторные устройства, а также может быть полезна студентам старших курсов технических вузов, обучающихся по специальностям "Электрооборудование ЛА" и "Электрические и электронные аппараты".
http://borncash.org/load/0006006696
http://turbobit.net/uh92l813kszs.html
http://startfiles.org/load/0006006696
25.09.2014, 15:34
Сказал спасибо: 798
Сказали Спасибо 1,357 раз(а) в 448 сообщении(ях)
Re: Книги
Сообщение от mihail62
![](http://s020.radikal.ru/i720/1409/87/dc5399fd0e71.jpg)
В книге рассматриваются возможности ...
А воровать нехорошо. ![Дьявольски зол](images/smilies/icon_twisted.gif) Я уже здесь писАл, что мои книги, выложенные на retrolib.narod.ru воруют, переделывают и выдают за свои, не ссылаясь на источник скачивания. Тем более, зарабатывая на этом деньги. Оригинал этой же книги в формате djvu и с тем же качеством (я тогда только начинал сканировать и ещё не было опыта обработки, да и сканер был не очень...). Выкладываю УКРАДЕННЫЙ у меня оригинал на бесплатном облачном диске. И говорю своё ФЭ. Желающие могут сравнить.
Ссылка на скачивание с облака mail.ru (как говорила Сава, без-воз-мезд-но).
https://cloud.mail.ru/public/a63fbcd...%BE%D0%BC.djvu
Ну и заодно того же автора (пока не украли и не выдали за своё)
1965. Момот. Вопросы избирательности радиоприёмников.
https://cloud.mail.ru/public/ed8a223...%BE%D0%B2.djvu
![](signaturepics/sigpic454335_3.gif) Мой адрес - Советский Союз!
Эти 10 пользователя(ей) сказали Спасибо 00-00 за это сообщение:
25.09.2014, 16:23
Сказал спасибо: 456
Re: Книги
Конденсаторы. Горячева Г.А. 1984
2MB, DjVu
https://yadi.sk/d/VmwI3itAbf3iD
Владимир
Эти 21 пользователя(ей) сказали Спасибо AversT за это сообщение:
Chedex (26.09.2014), dron2200 (26.09.2014), giv2 (26.09.2014), John_p (14.02.2015), kipiaxxx (26.09.2014), kreking (25.09.2014), leoblp (25.09.2014), mcu51 (26.09.2014), nckvrb (27.09.2014), next sound (09.10.2014), Palagin-07 (30.09.2014), pepek (26.09.2014), scenter (25.09.2014), sdeg (13.10.2014), seanta (07.10.2014), serg_42 (04.10.2014), stiv_fil (25.09.2014), V1770 (25.09.2014), valesyk (25.09.2014), vasilenko_pit (25.09.2014), vrt90 (07.10.2014) |
25.09.2014, 20:41
Сказал спасибо: 337
Re: Книги
Сообщение от 00-00
Если ваша фамилия Момот Е.Г., я удаляю свои ссылки без разговоров.
Часовой пояс GMT +4, время: 02:23.
