19.01.2017, 03:37
Сказал спасибо: 41
Сказали Спасибо 39 раз(а) в 34 сообщении(ях)
Re: Книги
Сообщение от al13
Конечно, и при пайке "внахлест" проблем может не быть. Но лучше сразу учиться делать как положено
Привычка скручивать провода пропала после демонтажа таких соединений
Эти 2 пользователя(ей) сказали Спасибо tigorrr за это сообщение:
19.01.2017, 10:34
Сказал спасибо: 337
Сказали Спасибо 30,207 раз(а) в 6,808 сообщении(ях)
Re: Книги
Electric Circuits and Signals
Название: Electric Circuits and Signals
Автор: Nassir H. Sabah
Издательство: CRC Press
Год: 2007
Страниц: 898
ISBN: 978-1-4200-4592-5, 142004592X
Формат: PDF
Язык: English
Solving circuit problems is less a matter of knowing what steps to follow than why those steps are necessary. And knowing the why stems from an in-depth understanding of the underlying concepts and theoretical basis of electric circuits. Setting the benchmark for a modern approach to this fundamental topic, Nassir Sabah’s Electric Circuits and Signals supplies a comprehensive, intuitive, conceptual, and hands-on introduction with an emphasis on creative problem solving.
Ideal for electrical engineering majors as a first step, this phenomenal textbook also builds a core knowledge in the basic theory, concepts, and techniques of circuit analysis, behavior, and operation for students following tracks in such areas as computer engineering, communications engineering, electronics, mechatronics, electric power, and control systems. The author uses hundreds of case studies, examples, exercises, and homework problems to build a strong understanding of how to apply theory to problems in a variety of both familiar and unfamiliar contexts. Your students will be able to approach any problem with total confidence. Coverage ranges from the basics of dc and ac circuits to transients, energy storage elements, natural responses and convolution, two-port circuits, Laplace and Fourier transforms, signal processing, and operational amplifiers.
На всякий Гугол свой Йобибайт найдется!
Эти 2 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
19.01.2017, 11:06
Сказал спасибо: 456
Сказали Спасибо 47,137 раз(а) в 3,118 сообщении(ях)
Re: Книги
Транзисторы в микрорежиме. Игумнов Д.В., Николаевский И.Ф. 1978
3.3 MB, DjVu
https://yadi.sk/i/XDfeYZD139mTZm
http://depositfiles.com/files/hna3mau04
Scan: AAW, DjVuing: pohorsky
Владимир
Эти 17 пользователя(ей) сказали Спасибо AversT за это сообщение:
agnnik (19.01.2017), AYuM (19.01.2017), Ba_sandr2 (20.01.2017), beebeep (22.01.2017), Chedex (22.01.2017), mcu51 (19.01.2017), nckvrb (20.01.2017), Nikolay-starikov (22.01.2017), RA0WKC (24.01.2017), safoso (19.01.2017), scenter (19.01.2017), seanta (16.02.2017), stiv_fil (29.01.2017), valesyk (19.01.2017), vasilenko_pit (22.01.2017), vbhjy (19.01.2017), vrt90 (21.01.2017) |
19.01.2017, 13:43
Сказали Спасибо 15 раз(а) в 4 сообщении(ях)
Re: Книги
Если вас интересуют книги и журналы по электронике, то посетите сайт http://mirknig.su (бывший mirknig.ком). На сайте публикуют авторы многих сканов находящихся в этой ветке:
pohorsky, он же polyanskiy http://mirknig.su/user/polyanskiy/news/
Gena_Bukin http://mirknig.su/user/Gena_Bukin/news/
deposit_rumit http://mirknig.su/user/deposit_rumit/news/
и другие.
Скачав книги у этих людей вы "копейкой за скачивание" поблагодарите их за труд, придав стимул сканировать новые книги.
Так же на сайте большой выбор и журналов по электронике, как русскоязычных, так и англо!
Сказали "Спасибо" mirknig
20.01.2017, 11:57
Сказал спасибо: 305
Сказали Спасибо 76 раз(а) в 42 сообщении(ях)
Re: Книги
Сообщение от akegor
Кем, куда, зачем, когда?
Читать старинные рецепты, конечно, полезно, но не менее полезно при этом еще и мыслить. О чем? О разумной достаточности
Затрудняюсь сейчас назвать номер и дату документа, но такая инструкция была, в которой требовалось делать скрутки, а при монтаже компонентов на печатную плату ножки обрезать на расстоянии около 5 мм и загибать. Это распространялось на оборудование, которое должно было проходить военную приёмку.
20.01.2017, 15:31
Сказал спасибо: 456
Re: Книги
Потенциометрические и титрометрические приборы. Кантере В.М., Казаков А.В., Кулаков М.В. 1969
7.2 MB, DjVu
https://yadi.sk/i/uCckgB1p39yLTp
http://depositfiles.com/files/7ze2mvcur
Владимир
Эти 11 пользователя(ей) сказали Спасибо AversT за это сообщение:
agnnik (20.01.2017), beebeep (22.01.2017), gend (23.01.2017), mcu51 (21.01.2017), nckvrb (22.01.2017), Nikolay-starikov (22.01.2017), safoso (20.01.2017), scenter (20.01.2017), seanta (16.02.2017), valesyk (20.01.2017), vasilenko_pit (22.01.2017) |
20.01.2017, 15:35
Сказал спасибо: 456
Re: Книги
В помощь радиолюбителю. Выпуск 14. Сост. Васильев А.А. 1963
5.4 MB, DjVu, OCR https://yadi.sk/i/PovrSCIT39yMzc
7.2 MB, PDF https://yadi.sk/i/YNJqKZ4p39yNDJ
13.03 MB, PDF + DjVu http://dfiles.ru/files/khci1v211
Scan: Владислав_72 ( malshin), DjVuing: pohorsky
Владимир
Эти 16 пользователя(ей) сказали Спасибо AversT за это сообщение:
agnnik (20.01.2017), Ba_sandr2 (20.01.2017), beebeep (22.01.2017), Chedex (22.01.2017), mcu51 (21.01.2017), MonstR007 (27.01.2017), Nikolay-starikov (22.01.2017), pepek (22.01.2017), RA0WKC (24.01.2017), safoso (20.01.2017), scenter (20.01.2017), seanta (16.02.2017), Shtangel (20.01.2017), valesyk (20.01.2017), vasilenko_pit (22.01.2017), vlnikb (24.01.2017) |
20.01.2017, 22:21
Сказал спасибо: 456
Re: Книги
Импульсные схемы РЛС. Григорьянц В.Г. 1981
5.5 MB, DjVu
https://yadi.sk/i/qd7VtJ2v3A3nSi
http://depositfiles.com/files/spbxko7jz
Владимир
Эти 12 пользователя(ей) сказали Спасибо AversT за это сообщение:
agnnik (22.01.2017), beebeep (22.01.2017), genao (21.01.2017), gend (23.01.2017), mcu51 (21.01.2017), Nikolay-starikov (22.01.2017), scenter (21.01.2017), seanta (16.02.2017), stiv_fil (29.01.2017), valesyk (21.01.2017), vasilenko_pit (22.01.2017), vlnikb (24.01.2017) |
21.01.2017, 03:22
Сказал спасибо: 337
Re: Книги
BeagleBone Black Interfacing: hardware and software
Название: BeagleBone Black Interfacing: hardware and software
Автор: Yury Magda
Издательство: Independently published
Год: 2015
Страниц: 180
Формат: EPUB, PDF (conv)
Язык: English
The BeagleBone Black being an embedded Linux development board can be an excellent choice for building various measurement and control systems by developers and hobbyists. This book is thought as a highly practical guide which can help readers to design measurement and control systems driven by the BeagleBone Black. These systems can comprise external electronic circuits controlled by programs written in Python. Since many measurement systems process analog signals, the guide contains a brief theory and practical applications dedicated to use of popular high-resolution analog-to-digital converters. The guide covers processing small signals with instrumentation amplifiers and measuring frequencies of digital signals using high-precision PWM-To-Voltage converters.
The material of the book also covers digital signal synthesis with digital potentiometers and digital-to-analog converters. The readers will find practical designs of digitally programmable wide-band oscillators, signal amplifiers and PWM circuits. The guide describes practical aspects of interfacing and programming high-precision wide-band sinusoidal and rectangular waveform generators using a popular high-resolution Direct Digital Synthesizer AD9850.
A few projects are dedicated to designing network and distributed systems using the BeagleBone Black and Tiva C Series Connected LaunchPad. The guide also covers interfacing the BeagleBone Black with popular Arduino Uno and Arduino Due boards. A few measurement and control systems with Arduino boards are presented as well.
The BeagleBone Black can be easily fitted into wireless systems using the Wixel Programmable USB Wireless modules from Pololu Corp., so the readers can explore a couple of projects presented in this guide. A few projects illustrate using a Bluetooth protocol in simple wireless systems built around the BeagleBone Black, desktop PC and Arduino Due.
Each project is accompanied by a brief description which helps to make things clear. Most projects described in the book can be improved or modified if necessary. Each project includes a circuit diagram accompanied by the Python source code. The projects with Arduino Uno and Arduino Due also include the source code written in the Processing language. All projects were designed and tested on the BeaglBone Black Rev.C running Debian Linux.
21.01.2017, 12:09
Сказал спасибо: 337
Re: Книги
Схемотехника машинных команд
Название: Схемотехника машинных команд
Автор: Василишин И.И.
Издательство: Архангельск: АГТУ
Год: 2007
Страниц: 165
ISBN: 978-5-261-00354-0
Формат: PDF
Язык: русский
В пособии изложены как математические основы синтеза функциональных узлов схемотехники, так и приведены методики, позволяющие на основании необходимых требований получить минимальные уравнения для реализации принципиальных схем комбинационных и последовательностных устройств. Указаны основные требования для формирования системы машинных команд микропроцессора.
Рассмотренные методики синтеза логических и цифровых узлов схемотехники, совместно с требованиями к системе машинных команд, позволяют выполнить построение принципиальной схемы микропроцессора произвольной степени сложности.
Предназначено для студентов направления 230201 «Информационные системы и технологии», очной и заочной форм обучения. Может быть использовано техническими специалистами при синтезе вычислительных узлов.
Оглавление
Математические основы синтеза функциональных узлов
Основы булевой алгебры
Преобразование логических функций
Логические базисы
Комбинационные функциональные узлы
Логические элементы
Синтез комбинационных узлов
Стандартные комбинационные узлы
Триггеры
Стандартный элемент памяти
Основные структуры триггеров
Методика синтеза триггеров
Последовательностные
функциональные узлы
Генераторы кодов
Конечные автоматы
Регистры
Структура машинных команд
Характеристики машинных команд
Система машинных команд
Адресация машинных команд
Кодирование машинных команд
Язык микроопераций
Микрокомандное управление
Синтез микропроцессора
Функциональные блоки микропроцессора
Структурный синтез микропроцессора
Список рекомендуемой литературы
Эти 5 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
Часовой пояс GMT +4, время: 19:32.
