Сообщение от alexey-b
...Вас что ? Моя просьба обидела ? ... Мне просто хотелось узнать диапазон перекрытия по частоте.
Просьба не обидела, просто не знаю как менять "Performance".
В справке по 9 версии написано "Performance function properties
A performance function at its core is a search. The set of data points of the target expression is searched for the criteria specified by the performance function and its parameters.
Performance functions all share certain basic characteristics:
Performance function find the N'th instance: Every performance function has a parameter N which specifies which instance of the function to return. The only exceptions are the High and Low functions for which, by definition, there is a maximum of one instance.
Each performance function call increments the N parameter: Every time a performance function is called in the Go To Performance cursor function, N is incremented after the function is called. The next call automatically finds the next instance and moves the cursor(s) to subsequent instances. For example, each call to the Peak function locates a new peak to the right of the old peak. When the end of the waveform is reached, the function rolls over to the beginning of the waveform. N is not, of course, incremented when a performance function is used in optimization or 3D plotting.
Only waveforms plotted during the run can be used: Performance functions operate on waveform data sets after the run, so only waveforms plotted during the run are available for analysis by a performance function.
Boolean expression must be TRUE: Candidate data points are included only if the Boolean expression is true for the data point. The Boolean expression is provided to let the user include only the desired parts of the curve or waveform in the performance function search.
At least PERFORM_M neighboring points must qualify: If a data point is selected, the neighboring data points must be consistent with the search criteria or the point is rejected. For example, in the peak function, a data point is considered a peak if at least PERFORM_M data points on both sides have a lower Y expression value. PERFORM_M is a Global Settings value and defaults to 2. Use 3 or even 4 if the waveform is particularly choppy or has any trapezoidal ringing in it."
Перевод от Google : "Свойства функции производительности
Производительность по своей сути - это поиск. В наборе точек данных целевого выражения выполняется поиск критериев, указанных в функции производительности, и ее параметров.
Все исполнительные функции имеют определенные основные характеристики:
Функция производительности находит N-й экземпляр: каждая функция производительности имеет параметр N, который указывает, какой экземпляр функции необходимо вернуть. Единственными исключениями являются функции High и Low, для которых, по определению, существует максимум один экземпляр.
Каждый вызов функции исполнения увеличивает параметр N: каждый раз, когда функция вызова вызывается в функции курсора «Перейти к исполнению», N увеличивается после вызова функции. Следующий вызов автоматически находит следующий экземпляр и перемещает курсор (и) к последующим экземплярам. Например, при каждом вызове функции пика новый пик находится справа от старого пика. Когда достигается конец сигнала, функция переходит к началу сигнала. Конечно, N не увеличивается, когда функция оптимизации используется при оптимизации или построении 3D-графиков.
Можно использовать только сигналы, построенные во время цикла: функции производительности работают с наборами данных сигналов после цикла, поэтому для анализа с помощью функции производительности доступны только сигналы, построенные во время цикла.
Булево выражение должно быть ИСТИНА: Точки данных-кандидаты включаются, только если логическое выражение истинно для точки данных. Логическое выражение предоставлено, чтобы позволить пользователю включать только требуемые части кривой или формы волны в поиск функции производительности.
Как минимум, PERFORM_M соседние точки должны соответствовать: если выбрана точка данных, соседние точки данных должны соответствовать критериям поиска, иначе точка будет отклонена. Например, в функции пика точка данных считается пиком, если по крайней мере точки данных PERFORM_M с обеих сторон имеют более низкое значение выражения Y. PERFORM_M является значением глобальных настроек и по умолчанию равно 2. Используйте 3 или даже 4, если форма сигнала является особенно изменчивой или имеет какие-либо трапециевидные звуки в нем."
Вы лучше покажите какой параметр менять, мне не трудно запустить симуляцию несколько раз.
