22.01.2017, 21:36
Сказал спасибо: 337
Сказали Спасибо 30,207 раз(а) в 6,808 сообщении(ях)
Re: Книги
Raspberry Pi Measurement Electronics: hardware and software
Название: Raspberry Pi Measurement Electronics: hardware and software
Автор: Magda Y.
Издательство: Independently published
Год: 2014
Страниц: 129
Формат: EPUB, PDF (conv)
Язык: English
Raspberry Pi being a miniature general-purpose desktop computer can also form a basis for building numerous measurement and control systems by both professionals and hobbyists. This is due to the general purpose input/output port (GPIO) available on the Raspberry Pi board.
This book is thought as a highly practical guide which can help the readers to design measurement and control systems based upon Raspberry Pi. These systems can comprise external electronic circuits controlled by programs written in Python. Projects described in the book illustrate processing digital and analog signals and using I/O expanders. Since many measurement systems process analog signals, the guide contains a brief theory and practical applications dedicated to use of popular high-resolution Analog-To-Digital converters. The guide contains projects which illustrate processing small signals with instrumentation amplifiers and measuring frequencies of digital and analog signals using high-precision Frequency-To-Voltage converters.
The material of the book also covers digital signal synthesis with digital potentiometers and Digital-To-Analog converters. The readers will find practical designs of digitally programmable wide-band oscillators, signal amplifiers and PWM circuits. The guide describes practical aspects of interfacing and programming high-precision wide-band sinusoidal, triangular and rectangular waveform generators using popular high-resolution Direct Digital Synthesizer (DDS) chips. Each project is accompanied by a brief description which helps to make things clear. Most projects described in the book can be improved or modified if necessary. Each project includes a schematic circuit accompanied by a Python source code with the detail explanation. All projects were designed using Raspberry Pi Model B Rev.2 board running Raspbian OS.
На всякий Гугол свой Йобибайт найдется!
Эти 2 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
22.01.2017, 23:03
Сказал спасибо: 337
Re: Книги
Режимы нейтрали электрических сетей
Название: Режимы нейтрали электрических сетей
Автор: Сирота И.М., Кисленко С.Н., Михайлов А.М.
Издательство: К.: Наукова думка
Год: 1985
Страниц: 264
Формат: PDF
Язык: русский
В монографии показано влияние режимов нейтрали на важнейшие показатели работы электрических распределительных сетей различных напряжений. Изложены основные принципы работы сетей с изолированной, заземленной через активное сопротивление, эффективно заземленной нейтралью и с компенсацией емкостных токов замыкания на землю.
Описаны принципы автоматического регулирования индуктивности реакторов. Представлены конструкции заземляющих устройств активных сопротивлений, дугогасящих реакторов с изменяющимся зазором, подмагничиванием, тиристорным переключением витков и др. Значительное внимание уделено теории, расчету и методам предотвращения феррорезонансных процессов, возникающих в сетях при неблагоприятном режиме нейтрали. Рассмотрены требования к селективной релейной защите и сигнализации замыканий на землю в электрических сетях в зависимости от режимов нейтрали.
Для научных и инженерно-технических работников, занятых в области электроэнергетики.
Оглавление
Напряжения и токи в сети при однофазном замыкании на землю
Некомпенсированная сеть с изолированной нейтралью
Сеть с заземлением нейтрали через высокоомное активное сопротивление
Компенсированная сеть
Сети с эффективным заземлением нейтрали
Феррорезонансные процессы в ЭС при замыкании фазы на землю
Феррорезонансные процессы в сети, возникающие при ее исправном состоянии
Способы выполнения заземления нейтрали некомпенсированных сетей и автоматическое замыкание на землю поврежденной фазы
Автоматическая настройка компенсации тока замыкания на землю
Ограничение напряжения нейтрали в компенсированной сети
Целесообразные режимы нейтрали электрических сетей
23.01.2017, 02:20
Сказал спасибо: 337
Re: Книги
Большая энциклопедия электрика
Название: Большая энциклопедия электрика
Автор: Черничкин М.Ю.
Издательство: Эксмо
Год: 2011
Страниц: 271
ISBN: 978-5-699-48399-0
Формат: PDF
Язык: русский
Серия: Ремонт от А до Я
Самая полная на сегодняшний день книга, в которой вы найдете массу полезной информации, начиная с азов. В книге раскрыты все основные проблемы, с которыми можно столкнуться при работе с электричеством и электрооборудованием.
Описание видов кабелей, проводов и шнуров, монтаж и ремонт электропроводки и многое другое.
Эта книга станет полезным справочником и для электрика-специалиста, и для домашнего умельца.
Эти 4 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
23.01.2017, 19:54
Сказал спасибо: 456
Сказали Спасибо 47,137 раз(а) в 3,118 сообщении(ях)
Re: Книги
Основы проектирования систем цифровой обработки радиолокационной информации. Кузьмин С.З. 1986
5.5 MB, DjVu
https://yadi.sk/i/LvyBZPVH3AV6XF
http://depositfiles.com/files/znc3j6x0h
Scan: AAW, DjVuing: pohorsky
Владимир
Эти 11 пользователя(ей) сказали Спасибо AversT за это сообщение:
asdzxcop (25.01.2017), AYuM (27.01.2017), beebeep (27.01.2017), mcu51 (29.01.2017), Nikolay-starikov (03.02.2017), scenter (23.01.2017), seanta (16.02.2017), stiv_fil (29.01.2017), valesyk (23.01.2017), vasilenko_pit (27.01.2017), Vlad German (29.01.2017) |
23.01.2017, 21:43
Сказал спасибо: 337
Re: Книги
Ham Radio from Indoors
Название: Ham Radio from Indoors
Автор: ARRL
Издательство: ARRL Inc
Год: 2017
Страниц: 78
ISBN: 978-1-62595-067-3
Язык: English
You’d be surprised at how many amateurs operate stations that are entirely indoors. By “entirely indoors,” I mean stations that exist completely within the confines of the homes in which the operators live. Some hams can install semi-invisible antennas outdoors by cleverly hiding wires along exterior walls, or by exploiting the classic ruse of using rain gutters as antennas, but this book is devoted to those who lack even that luxury. When I say “HF indoors,” I mean that everything is indoors – including the antenna system.
Contents
1. The Indoor Challenge
Learn how to make the most of indoor operating with CW and digital modes.
2. Indoor Antenna Design
From loops to dipoles, there is an indoor antenna that’s guaranteed to work for you.
3. Dealing with Interference
When operating indoors, you’re likely to be plagued with interference from your neighbors, and you may cause some interference yourself. This chapter offers concrete solutions.
4. RF Safety
You and your neighbors will be living in proximity to the RF you’ll generate. There is no danger, but it never hurts to be cautious.
24.01.2017, 18:54
Сказал спасибо: 337
Re: Книги
Электромеханические реле. Основые теории, проектирования и расчета
Название: Электромеханические реле. Основые теории, проектирования и расчета
Автор: Ступель Ф.А.
Издательство: Изд-во Харьк. ун-та
Год: 1956
Страниц: 358
Формат: PDF, DJVU
Язык: русский
Электромеханические реле являются одним из наиболее распространенных элементов устройств автоматики и телемеханики. Методы расчета реле базируются на теории ферромагнетизма, теории электромагнитного поля и на теории электромагнитных цепей.
В книге излагаются основы теории и инженерные методы расчета и проектирования злектромеханических реле и механизмов разных принципов действия: электромагнитных, индукционных, магнитоэлектрических и других. Рассмотрены вопросы расчета отдельных узлов реле: катушек, контактных систем, пружин и опор.
Книга составлена в виде учебного пособия для изучения теории реле, а также для курсового и дипломного проектирования студентов электротехнических специальностей. Книга может быть полезной инженерно-техническим работникам в их практической работе по проектированию и применению электрических реле и механизмов.
24.01.2017, 21:39
Сказал спасибо: 337
Re: Книги
Электрические машины
Автор: Кацман М.М.
Издательство: Академия
Год: 2013
Страниц: 496
ISBN: 978-5-7695-9705-3
Формат: PDF
Язык: русский
В учебнике рассматриваются теория, принцип действия, устройство и анализ режимов работы электрических машин и трансформаторов как общего, так и специального назначения, получивших распространение в различных отраслях техники.
Учебник может быть использован при освоении профессионального модуля ПМ.01. «Организация технического обслуживания и ремонта электрического и электромеханического оборудования» (МДК.01.01) по специальности 140448 «Техническая эксплуатация и обслуживание электрического и электромеханического оборудования».
Для студентов учреждений среднего профессионального образования. Может быть использовано студентами вузов.
Эти 3 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
25.01.2017, 10:51
Сказал спасибо: 337
Re: Книги
Electronics All-in-One For Dummies, 2nd Edition
Название: Electronics All-in-One For Dummies, 2nd Edition
Автор: Doug Lowe
Издательство: Wiley
Год: 2017
Страниц: 960
ISBN: 978-1119320791, 1119320798
Формат: EPUB
Язык: English
A comprehensive collection of 8 books in 1 offering electronics guidance that can't be found anywhere else!
If you know a breadboard from a breadbox but want to take your hobby electronics skills to the next level, this is the only reference you need. Electronics All-in-One For Dummies has done the legwork for you — offering everything you need to enhance your experience as an electronics enthusiast in one convenient place.
Written by electronics guru and veteran For Dummies author Doug Lowe, this down-to-earth guide makes it easy to grasp such important topics as circuits, schematics, voltage, and safety concerns. Plus, it helps you have tons of fun getting your hands dirty working with the Raspberry Pi, creating special effects, making your own entertainment electronics, repairing existing electronics, learning to solder safely, and so much more.
Create your own schematics and breadboards
Become a circuit-building expert
Tackle analog, digital, and car electronics
Debunk and grasp confusing electronics concepts
If you're obsessed with all things electronics, look no further! This comprehensive guide is packed with all the electronics goodies you need to add that extra spark to your game!
25.01.2017, 12:26
Сказал спасибо: 337
Re: Книги
Все об электрике. Современная иллюстрированная энциклопедия
Название: Все об электрике. Современная иллюстрированная энциклопедия
Автор: Черничкин М.Ю. и др.
Издательство: Эксмо
Год: 2016
Страниц: 290
ISBN: 978-5-699-88032-4
Формат: PDF/ DJVU
Размер: 26.3 Мб / 11.2 Мб
Язык: русский
Практическое пособие, в котором вы узнаете о материалах и инструментах, о разных видах кабеля, маркировке проводов цветом, монтаже электропроводки, квартирного щитка или уличного освещения.
Ремонт электропроводки в квартире у многих вызывает недоумение и даже страх. Нам кажется, что с этим справится только настоящий мастер. Взяв в руки эту книгу, вы убедитесь в обратном. В ней пошагово и с большим количеством иллюстраций рассказано обо всем, что нужно знать и новичку, и профессионалу. Это именно практическое пособие, в котором вы узнаете о материалах и инструментах, о разных видах кабеля, маркировке проводов цветом, монтаже электропроводки, квартирного щитка или уличного освещения. Узнаете об особенностях электрификации кухни и санузла. Сможете понять причины почти любых неисправностей и устранить их. Соблюдая технику безопасности, которой уделено особое внимание в книге, вы откроете в себе электрика.
Последний раз редактировалось mihail62; 25.01.2017 в 12:41.
25.01.2017, 20:11
Сказал спасибо: 337
Re: Книги
Raspberry Pi Electronics Projects for the Evil Genius (Tab)
Название: Raspberry Pi Electronics Projects for the Evil Genius (Tab)
Автор: Donald Norris
Издательство: McGraw-Hill
Год: 2016
Страниц: 304
ISBN: 1259640582
Формат: EPUB
Язык: English
Ten brand new, hands-on DIY projects for the Raspberry Pi!
This fully illustrated guide shows how to create all kinds of entertaining and practical gadgets with the Raspberry Pi.Raspberry Pi Electronics Projects for the Evil Genius features ten fun DIY projects that showcase the RasPi's applications in computing, communications, robotics, photography, and video.
Each Evil Genius project includes a detailed list of materials, sources for parts, schematics, and clear, step-by-step assembly and programming instructions. Readers will get up and running right away by learning how to program a touchscreen, interface with an Arduino processor, build a fully working cell phone-even build a super computer using a cluster of RasPis! Advanced projects include a Software Defined Radio, BrickPi robot controller, robotic arm, point-and-shoot camera, and a complete infrared surveillance system.
Covers all RasPi models, including the latest A+, B+ and B model 2 units
Features C, Java, and Python programming techniques
Software downloads available through mhprofessional.com
Сказали "Спасибо" mihail62
Часовой пояс GMT +4, время: 19:18.
