;; Dallas DS1820 multidrop routines using timer 1 in mode 3 for MCS51
;; External power for DS1820 assumed
;; Clock is 11.0592 MHz -› one cycle is 1.0850694 us
;; Copyright 1999, Leon Kos, University of Ljubljana
;; TODO: Initial check routines for external power on each device
NAME DS1820
data_bit BIT 0EFh ; P4.7
EAL BIT 0AFh ; enable all interrupts (SAB80C515 specific)
ds1820_routines SEGMENT CODE
T1_interrupt SEGMENT CODE
ds1820rom SEGMENT CODE
dowcrc SEGMENT CODE
ds1820data SEGMENT DATA
bitvar SEGMENT BIT
public ds1820_init
public _ds1820_start
public touch_byte
public convert_time
public ds1820error
public scratchpad
public ds1820crc_ok
public errornum
CSEG AT 0001BH
jmp timer1
RSEG T1_interrupt
timer1:
push acc ; 2
push psw ; 2
push dpl ; 2
push dph ; 2
jnb bit_state, matchROM_loop
bit_loop: ; bit writing/reading loop
setb data_bit
setb bit_state ; enable this state
mov c, read_slot
mov a, touch_byte
rrc a
mov touch_byte, a
djnz bitcnt, touch_bit
mov bitcnt, #9
clr bit_state
jmp exit_t1
touch_bit:
clr data_bit
nop
nop
nop
nop
mov data_bit, c
nop
nop
nop
nop
nop
nop
mov c, data_bit
mov read_slot, c
mov TH0, #(0FFh - 20)
pop dph ; 2
pop dpl ; 2
pop psw ; 2
pop acc ; 2
reti
matchROM_loop:
jnb matchROM_state, reset_state_loop
mov a, loop ; test the loop counter
clr C ; clear for one byte substraction
subb a, #8 ; loop couner in incrementing
jz _rom_end ; substract to match zero at end
mov dptr, #rom_table; point to in CODE device table
mov a, ds1820device ; which device
rl a ; address
rl a ; is multiple of
rl a ; 8 offset
add a, loop ; select byte from table
movc a, @a+dptr
mov touch_byte, a
inc loop
jmp bit_loop
_rom_end:
clr matchROM_state
inc state
jmp state_loop
reset_state_loop:
jnb reset_state, state_loop
mov a, loop
dec a
jz _reset_end
mov loop, a
add a, #254
jnz _rst0
setb data_bit
_rst0: jmp exit_t1
_reset_end:
clr reset_state
inc state
state_loop: ; Main state machine loop
mov a, state ; must be in the middle
mov dptr, #jump_table; of the code
movc a, @a+dptr
jmp @a+dptr
jump_table:
db reset0 - jump_table
db match_rom0 - jump_table
db convertT - jump_table
db readbusy - jump_table
db reset1 - jump_table
db match_rom1 - jump_table
db read_scratchpad - jump_table
db temp_lsb - jump_table
db temp_msb - jump_table
db user_byte1 - jump_table
db user_byte2 - jump_table
db reserved1 - jump_table
db reserved2 - jump_table
db count_remain - jump_table
db count_per_c - jump_table
db crc - jump_table
db stop - jump_table
reset0:
mov loop, #4
setb reset_state
mov TH0, #(255-200) ; first half of the reset time
clr data_bit
jmp exit_t1
match_rom0:
mov touch_byte, #55h
mov loop, #0
setb matchROM_state
jmp bit_loop
convertT:
mov touch_byte, #44h
inc state
mov convert_time, #00h
mov convert_time + 1, #00h
jmp bit_loop
readbusy: ; check every 280us
inc convert_time + 1;
mov a, convert_time + 1
jnz _noinc
inc convert_time
mov a, #08h ; 8*72ms=569ms overrun
anl a, convert_time
jz _noinc
setb ds1820error ; short circuit
mov errornum, #1 ; to long zero resonse
jmp end_t1
_noinc: mov a, touch_byte
mov touch_byte, #0FFh
inc a
jz converted
jmp bit_loop
converted:
clr C
mov a, convert_time+1; compare the conversion
subb a, #20 ; time must be over 20
mov a, convert_time ; typical time is 240
subb a, #0
jnc _endcvt
setb ds1820error ; to quick ready response
mov errornum, #2 ; no device or no power on
jmp end_t1 ; device or line open
_endcvt:
inc state
reset1:
mov loop, #4
setb reset_state
clr data_bit
jmp exit_t1
match_rom1:
mov loop, #0
setb matchROM_state
jmp bit_loop
read_scratchpad:
mov touch_byte, #0BEh
inc state
jmp bit_loop
temp_lsb: ; larger but easy to fetch bytes
inc state
jmp bit_loop
temp_msb:
mov scratchpad, touch_byte
inc state
jmp bit_loop
user_byte1:
mov scratchpad + 1, touch_byte
inc state
jmp bit_loop
user_byte2:
mov scratchpad + 2, touch_byte
inc state
jmp bit_loop
reserved1:
mov scratchpad + 3, touch_byte
inc state
jmp bit_loop
reserved2:
mov scratchpad + 4, touch_byte
inc state
jmp bit_loop
count_remain:
mov scratchpad + 5, touch_byte
inc state
jmp bit_loop
count_per_c:
mov scratchpad + 6, touch_byte
inc state
jmp bit_loop
crc:
mov scratchpad + 7, touch_byte
inc state
jmp bit_loop
stop:
mov scratchpad + 8, touch_byte
end_t1:
clr ET1 ; disable interrupt
clr TR1 ; stop the timer
mov state, #0 ; reset the machine state
setb data_bit ; power the line
exit_t1: ; exit from interrupt
pop dph ; 2
pop dpl ; 2
pop psw ; 2
pop acc ; 2
reti
RSEG ds1820_routines
ds1820_init: ; initialize the variables
mov bitcnt, #9 ; bit counter
setb data_bit ; power the devices on line 1
clr matchROM_state ; not sending match ROM to ds1820
clr bit_state ; not in the bit delay state
clr reset_state ; not in the reset state
mov state, #0 ; clear machine state
mov ds1820device,#0 ; default is reading device0
mov TMOD, #033h ; timer 0 & timer 1 -› mode 3
setb EAL
ret
_ds1820_start: ; R7 has the device number to read
mov ds1820device,R7
mov TH0,#0FAh
clr ds1820error ; no error at beginning
mov errornum, #0
setb ET1
setb TR1
ret
RSEG dowcrc
ds1820crc_ok: ; extern bit ds1820crc_ok(void);
mov loop, #9 ; 8+1 byte CRC
mov ds1820crc, #0 ; clear CRC register
mov dptr, #dowcrc_table
mov r0, #scratchpad
_crc:
mov a, @r0 ; scratchad value
xrl a, ds1820crc
movc a, @a+dptr
mov ds1820crc, a
inc r0
djnz loop, _crc
jz _ok
clr CY
ret
_ok: setb CY
ret
dowcrc_table: DB 0, 94, 188, 226, 97, 63, 221, 131
DB 194, 156, 126, 32, 163, 253, 31, 65
DB 157, 195, 33, 127, 252, 162, 64, 30
DB 95, 1, 227, 189, 62, 96, 130, 220
DB 35, 125, 159, 193, 66, 28, 254, 160
DB 225, 191, 93, 3, 128, 222, 60, 98
DB 190, 224, 2, 92, 223, 129, 99, 61
DB 124, 34, 192, 158, 29, 67, 161, 255
DB 70, 24, 250, 164, 39, 121, 155, 197
DB 132, 218, 56, 102, 229, 187, 89, 7
DB 219, 133, 103, 57, 186, 228, 6, 88
DB 25, 71, 165, 251, 120, 38, 196, 154
DB 101, 59, 217, 135, 4, 90, 184, 230
DB 167, 249, 27, 69, 198, 152, 122, 36
DB 248, 166, 68, 26, 153, 199, 37, 123
DB 58, 100, 134, 216, 91, 5, 231, 185
DB 140, 210, 48, 110, 237, 179, 81, 15
DB 78, 16, 242, 172, 47, 113, 147, 205
DB 17, 79, 173, 243, 112, 46, 204, 146
DB 211, 141, 111, 49, 178, 236, 14, 80
DB 175, 241, 19, 77, 206, 144, 114, 44
DB 109, 51, 209, 143, 12, 82, 176, 238
DB 50, 108, 142, 208, 83, 13, 239, 177
DB 240, 174, 76, 18, 145, 207, 45, 115
DB 202, 148, 118, 40, 171, 245, 23, 73
DB 8, 86, 180, 234, 105, 55, 213, 139
DB 87, 9, 235, 181, 54, 104, 138, 212
DB 149, 203, 41, 119, 244, 170, 72, 22
DB 233, 183, 85, 11, 136, 214, 52, 106
DB 43, 117, 151, 201, 74, 20, 246, 168
DB 116, 42, 200, 150, 21, 75, 169, 247
DB 182, 232, 10, 84, 215, 137, 107, 53
alternate_dowcrc: ; slower and thus not used
mov ds1820crc, #0
mov loop, #8 ; 8 bytes
mov r0, #scratchpad
_dcrc: mov a, @r0
call do_crc
inc r0
djnz loop, _dcrc
ret
do_crc: push acc
push b
push acc
mov b, #8
crc_loop:
xrl a, ds1820crc
rrc a
mov a, ds1820crc
jnc zero
xrl a, #18h
zero: rrc a
mov ds1820crc, a
pop acc
rr a
push acc
djnz b, crc_loop
pop acc
pop b
pop acc
ret
RSEG ds1820data
bitcnt: ds 1 ; bit couter
touch_byte: ds 1 ; touch byte
scratchpad: ds 9 ; DS1820 scratchpad
convert_time: ds 2 ; time required for conversion
state: ds 1 ; machine state
loop: ds 1 ; shared byte for loops
errornum: ds 1 ; error number
ds1820device: ds 1 ; which device number 0,1,...
ds1820crc: ds 1 ; DOW 8 bit CRC value
RSEG bitvar
read_slot: DBIT 1 ; read bit from ds1820
bit_state: DBIT 1 ; delaying one bit state
matchROM_state: DBIT 1 ; sending MATCH ROM state
reset_state: DBIT 1 ; resetting the bus state
ds1820error: DBIT 1 ; error getting temperature
RSEG ds1820rom
rom_table: ; avalable devices on the 1-wire net
device0: DB 10h, 088h, 3Dh, 0Ch, 00h, 00h, 00h, 0CAh
device1: DB 10h, 05Bh, 49h, 09h, 00h, 00h, 00h, 0A4h
device2: DB 10h, 022h, 49h, 09h, 00h, 00h, 00h, 0AAh
device3: DB 10h, 0DAh, 4Ah, 09h, 00h, 00h, 00h, 037h
device4: DB 10h, 099h, 48h, 09h, 00h, 00h, 00h, 098h
device5: DB 10h, 09Ah, 4Bh, 09h, 00h, 00h, 00h, 08Fh
device6: DB 10h, 021h, 47h, 09h, 00h, 00h, 00h, 051h
device7: DB 10h, 0EEh, 47h, 09h, 00h, 00h, 00h, 0EAh
device8: DB 10h, 06Eh, 47h, 09h, 00h, 00h, 00h, 000h
device9: DB 10h, 0D3h, 49h, 09h, 00h, 00h, 00h, 0EFh
device10: DB 10h, 09Ah, 47h, 09h, 00h, 00h, 00h, 0AEh
device11: DB 10h, 0B1h, 4Ah, 09h, 00h, 00h, 00h, 00Ch
device12: DB 10h, 08Bh, 4Ah, 09h, 00h, 00h, 00h, 02Eh
device13: DB 10h, 03Ch, 4Bh, 09h, 00h, 00h, 00h, 061h
device14: DB 10h, 074h, 49h, 09h, 00h, 00h, 00h, 036h
device15: DB 10h, 024h, 48h, 09h, 00h, 00h, 00h, 0D5h
device16: DB 10h, 057h, 49h, 09h, 00h, 00h, 00h, 0D9h
device17: DB 10h, 050h, 04h, 0B0h,90h, 00h, 00h, 0DFh
END |
