11.12.2007, 21:58
New CodeVisionAVR 1.25.8
Нашел на сонсиври:
http://www.sonsivri.com/forum/index.php?board=30.0
Но я ссылки не могу видеть:
You are not allowed to view links, check the Announcements Board
Подскажите, почему?
Мог бы кто то скачать эту новую версию компилятора? Хотя бы серийник...
12.12.2007, 09:16
Сказали Спасибо 36 раз(а) в 32 сообщении(ях)
С официального сайта
V1.25.8 Commercial Release
added support for the ATmega48P(V), ATmega88P(V), ATmega168P(V), ATmega328P(V), ATmega325P(V), ATmega3250P(V), ATmega329P(V) and ATmega3290P(V) chips
assignments of a variable expression result to a PORT.bit now produces atomic access to the I/O PORT’s bit using the SBI and CBI instructions, if the I/O PORT address is in the 0...31 range
added the predefined C preprocessor macro __UNIX_TIME__ which is in an unsigned long that represents the number of seconds elapsed since midnight UTC of 1 January 1970, not counting leap seconds
fixed: in some rare cases “relative branch out of reach” assembly errors occurred for function calls when the source contained large portions of inline assembly code and the size of the chip FLASH was larger than 8kbytes
fixed: in some rare cases the common subexpression elimination optimizer produced incorect code for complex expressions
fixed: the sign function from math.h returned sometimes wrong values when called with a variable with value 0 as argument
fixed: the ds18b20_temperature function (ds18b20.h) returned incorrect values for negative temperatures
improved the size and speed of the csign function (math.h)
improved the code optimizer
improved the C preprocessor
the EEPROM writing routine now periodically generates a watchdog reset while waiting the write to complete
fixed: the Navigator didn’t display correctly the register allocation for global pointers to RAM for the TINY memory model
fixed: the CodeWizardAVR didn’t create the macro definitions for some bits in the USART control registers when using only USART2 or USART3 for chips with 4 USARTs
fixed: the number of interrupt vectors allowed by the compiler was not correct for the ATmega644P and ATmega644PV chips
fixed: for some large programs for the ATtiny26 chip the Compression Buffer Overflow error occurred
fixed: the chip signature for the AT90CAN64 in the Programmer was not correct
fixed: slow programming for FLASH word addresses above FFFFh for the ATmega2560 and ATmega2561 chips when programming using the Kanda STK200/300 LPT port programmer
Переводить думаю не нужно? Сами поймете
12.12.2007, 09:43
Re: New CodeVisionAVR 1.25.8
Сообщение от dimonbest
Нашел на сонсиври:
Подскажите, почему?
Кури их мануал ![Улыбка](images/smilies/icon_smile.gif)
Где-то мельком наткнулся на то, что должно быть не менее 7 постов и тогда сможешь видеть их линки
12.12.2007, 10:14
Сказал спасибо: 76
[quote="mrKirill"]С официального сайта
Эти уж несколько версий поддерживаются прекрасно и мастером тоже.
12.12.2007, 10:19
12.12.2007, 10:53
Сказал спасибо: 76
12.12.2007, 13:26
Сообщение от avr123-nm-ru
Видимо для "объемности и солидности" он это написал
12.12.2007, 13:34
Кто скачал - там при установке нужно вводить пароль, кто скажет?
12.12.2007, 16:56
Сообщение от mrKirill
u$wwe1heruisjmlt%8k
21.12.2007, 00:04
Так-с, товарищи, какие-то непонятки возникли с новой версией у меня:
Стояла версия V1.25.7 установил поверх версию V1.25.8
Возникла необходимость перекомпилировать один проект и что я вижу - размер HEX файла стал практически в 2 раза больше, и если он занимал у меня ~48% всей памяти, то сейчас стал занимать ~98%, из изменений кода - только изменил конфигурацию Таймера1
Завтра конечно попробую на чистую поставить версию V1.25.8 и сравнить, но также просьба к остальным, попробуйте старый какой-нить проектик перекомпильнуть на новой версии.
Часовой пояс GMT +4, время: 13:30.
