компилировал MPASMWIN вот код ошибки:
Warning[205] C:THERMTHERM18B20.ASM 7 : Found directive in column 1. (LIST)
Message[301] C:PROGRAM FILESLABCENTER ELECTRONICSPROTEUS 7 DEMONSTRATIONTOOLSMPASMP16F84.INC 37 : MESSAGE: (Processor-header file mismatch. Verify selected processor.)
Warning[205] C:THERMTHERM18B20.ASM 10 : Found directive in column 1. (__config)
Warning[205] C:THERMTHERM18B20.ASM 59 : Found directive in column 1. (CONSTANT)
Message[302] C:THERMTHERM18B20.ASM 63 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:THERMTHERM18B20.ASM 64 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:THERMTHERM18B20.ASM 110 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:THERMTHERM18B20.ASM 111 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[305] C:THERMTHERM18B20.ASM 118 : Using default destination of 1 (file).
Message[302] C:THERMTHERM18B20.ASM 127 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:THERMTHERM18B20.ASM 128 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:THERMTHERM18B20.ASM 184 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[305] C:THERMTHERM18B20.ASM 346 : Using default destination of 1 (file).
Message[305] C:THERMTHERM18B20.ASM 347 : Using default destination of 1 (file).
Warning[207] C:THERMTHERM18B20.ASM 419 : Found label after column 1. (L72)
Warning[207] C:THERMTHERM18B20.ASM 423 : Found label after column 1. (L73)
Warning[207] C:THERMTHERM18B20.ASM 430 : Found label after column 1. (L74)
Warning[207] C:THERMTHERM18B20.ASM 439 : Found label after column 1. (L2B)
Warning[207] C:THERMTHERM18B20.ASM 443 : Found label after column 1. (L2A)
Warning[207] C:THERMTHERM18B20.ASM 446 : Found label after column 1. (L2C)
Warning[207] C:THERMTHERM18B20.ASM 450 : Found label after column 1. (L76)
Warning[207] C:THERMTHERM18B20.ASM 461 : Found label after column 1. (L2D)
Warning[207] C:THERMTHERM18B20.ASM 464 : Found label after column 1. (L2E)
Warning[207] C:THERMTHERM18B20.ASM 467 : Found label after column 1. (L8
![Горд собой](images/smilies/icon_dovl.gif)
Message[302] C:THERMTHERM18B20.ASM 634 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:THERMTHERM18B20.ASM 641 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:THERMTHERM18B20.ASM 690 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:THERMTHERM18B20.ASM 692 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:THERMTHERM18B20.ASM 694 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:THERMTHERM18B20.ASM 695 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:THERMTHERM18B20.ASM 697 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:THERMTHERM18B20.ASM 699 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:THERMTHERM18B20.ASM 714 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[173] C:THERMTHERM18B20.ASM 721 : Source file path exceeds 62 characters (C:PROGRAM FILESLABCENTER ELECTRONICSPROTEUS 7 DEMONSTRATIONTOOLSMPASMP16F84.INC)
Помогите пожалуста
