На самом деле уже давно версия SimulIDE_0.3.12-SR5 - последняя стабильная версия, SimulIDE_0.4.13-RC5 - более совершенная версия, но не стабильная.
Список улучшений по сравнению с Simu lIDE 0.3.12.SR3:
SimulIDE_0.3.12-SR4:
List of changes since last version:
New Features:
- Circuit Zoom with key sequence: Ctrl+ Ctrl-
- Serial Terminal: "Clear" and "CR" buttons.
- New Dialog: create and edit Package Pins.
- Create Subcircuit and Package files in one shot.
Bug Fixes:
- Pic asm Compiler: gpasm does not find includes in project folder.
- Time widget scrollBars shown in some systems.
- Executable detected as shared lib in some builds.
- AVR timer mode 14: Fast PWM, Top=ICR1, doesn't update in OCRX changes.
- Send Text in Serial monitor limited to 50 characters.
- ATtinyX4 wrong Pin asignation in Timer0,1.
- ATtinyX4 wrong ADC definition.
- Use Chip Symbol if Logic Symbol file not found.
- Package should save file relative path, not absolute.
- Create Subcircuit taking Component Circuit Id instead of unique Id.
- Avoid dash "-" in Subcircuits Pin Ids.
- Avoid save Backup in read only filesystems.
- Subcircuits fixed (thanks to Sergey Roenko):
74HC42, 74HC74, 74HC75, 74HC151, 74HC155, 74HC192, 74HC93, 74HC393, 74HC592, 74HC4017, 74HC4026, 74HC4033,
New Components:
- IC74 (thanks to Sergey Roenko)
74XX01 74HC73 74HC76 74HC107 74HC109 74HC112 74HC113 74HC173 74HC175 74HC259 74HC373 74HC374 74HC375 74HC377
SimulIDE_0.3.12-SR5:
Bug Fixes:
- I2C module: wrong output impedance when transmiting.
- Editor: closing unsaved doc + cancel not working.
- Editor: close unsaved doc whith no focus, editor takes the focused one.
- PIC with OSCCAL Reg. not working if call 0x3FF is made.
- Crash: Debug session + Close doc. + RamTable-›LoadVAriables.
- AVR SPI: MOSI pin should be high when idle.
- Wrong extension creating Subcircuits in some cases.
- Crash creating Subcircuit with 2 Package Pins connected together.
- Ground not working in Subcircuits.
- Subcircuits fixed (Sergey Roenko strikes again)
74HC73 74HC76 74HC107 74HC109 74HC112 74HC113 74HC173 74HC175 74HC259 74HC279 74HC373 74HC374 74HC375 74HC377
New Components:
- IC74 (Sergey Roenko strikes again)
74XX91 74XX95 74XX96 74XX166 74XX170 74XX178 74XX179 74XX195 74XX198 74XX199 74HC670 74XX381 74XX382
About 0.4.13:
0.4.13 is still very unstable, but have some good things for logic circuits:
- New Buses.
- Small Gates.
- You can place wires at 1/2 grid.
- 16 bit Encoder/Decoder.
- 100 MHz max. circuit speed.
- WS2812 LED
Во вложении список всех моделей (более 60 микросхем еще нет в официальном релизе)
Более подробная информация здесь:
http://www.nedopc.org/forum/viewtopi...33d89181724c03
