Доступна новая публичная версия программы:
SimulIDE 0.3.12-SR8
Скачать можно здесь:
https://simulide.blogspot.com/2020/0...published.html
Более новые версии здесь (пока по подписке):
https://www.patreon.com/simulide
Список изменений:
SimulIDE_0.3.12-SR8
New Features:
- Help files: Spanish translation ( Kike_Gl ).
- Help files: Spanish help for 74 Series ( Kike_Gl ).
Bug Fixes:
- Stepper: bounding box overlaping pins.
- Stepper not updating after change steps number.
- Arduino 1.8.10 issue solved.
- AppImage tries to backup in Readonly FS.
- Some Help Files not Found.
- Some wrong error strings higlighted in Arduino Compile.
- Text Encoding errors.
- Missing file extension filters in Editor-›SaveAs.
- Bad Led visualisation when cpu can not keep speed.
- Atmega 1280,1281, 2560, wrong package file.
- Crash if mcu can't be created + new circuit.
- Pic18F4420 missing data file.
SimulIDE_0.3.12-SR7
List of changes since last version:
Bug Fixes:
SR7
- Editor: Sintax highlight error parsing some rules.
- Oscope not updating when signal dissapears.
- Fixed 74HC194_LS.package (Sergey Roenko)
New Components:
SR7:
- IC74 (Sergey Roenko)
74HC156, 74HC157, 74HC158, 74HC251, 74HC257, 74HC258, 74HC298, 74HC352
74HC353, 74HC354, 74HC356, 74HC4052, 74HC4053, 74HC4067
74XX150, 74XX582, 74XX583
- ICCD (Sergey Roenko)
CD4019, CD4029, CD4066, CD4512, CD4532, CD4553
- Keys (Sergey Roenko)
DG401, DG403, DG405
- Ternary (Sergey Roenko)
Ternary_AND, Ternary_Buffer, Ternary_Multiplexer, Ternary_NAND
Ternary_NOR, Ternary_NOT. Ternary_OR
SimulIDE_0.3.12-SR6
Bug Fixes:
- Circuits from 0.4.13: Try to position elements in grid.
- Crash closing file with debugger when no mcu ( 0.3.12-SR5 ).
- PIC: if PIC goes to sleep fail to exit sleep afther reset.
- Crash setting MCU to logic Symbol (No LS available for MCU yet).
- Crash on some actions while creating connector.
- Audio Out latency too high.
- LatchD randomly not properly initialized.
New Components:
- IC74(Sergey Roenko)
74HC245, 74HC260, 74HC4094
- ICCD(Sergey Roenko)
CD4006, CD4013, CD4014, CD4015, CD4021, CD4027, CD4035, CD4042, CD4043, CD4044, CD4076, CD4094, CD4095,
CD4096, CD4099, CD4508, CD40174, CD40175
SimulIDE_0.3.12-SR5
Bug Fixes:
- I2C module: wrong output impedance when transmiting.
- Editor: closing unsaved doc + cancel not working.
- Editor: close unsaved doc whith no focus, editor takes the focused one.
- PIC with OSCCAL Reg. not working if call 0x3FF is made.
- Crash: Debug session + Close doc. + RamTable-›LoadVAriables.
- AVR SPI: MOSI pin should be high when idle.
- Wrong extension creating Subcircuits in some cases.
- Crash creating Subcircuit with 2 Package Pins connected together.
- Ground not working in Subcircuits.
- Subcircuits fixed (Sergey Roenko strikes again)
74HC73, 74HC76, 74HC107, 74HC109, 74HC112, 74HC113, 74HC173, 74HC175, 74HC259, 74HC279, 74HC373, 74HC374,
74HC375, 74HC377
New Components:
- IC74 (Sergey Roenko strikes again)
74XX91, 74XX95, 74XX96, 74XX166, 74XX170, 74XX178, 74XX179, 74XX195, 74XX198, 74XX199, 74HC670, 74XX381,
74XX382
SimulIDE_0.3.12-SR4
New Features:
- Circuit Zoom with key sequence: Ctrl+ Ctrl-
- Serial Terminal: "Clear" and "CR" buttons.
- New Dialog: create and edit Package Pins.
- Create Subcircuit and Package files in one shot.
Bug Fixes:
- Pic asm Compiler: gpasm does not find includes in project folder.
- Time widget scrollBars shown in some systems.
- Executable detected as shared lib in some builds.
- AVR timer mode 14: Fast PWM, Top=ICR1, doesn't update in OCRX changes.
- Send Text in Serial monitor limited to 50 characters.
- ATtinyX4 wrong Pin asignation in Timer0,1.
- ATtinyX4 wrong ADC definition.
- Use Chip Symbol if Logic Symbol file not found.
- Package should save file relative path, not absolute.
- Create Subcircuit taking Component Circuit Id instead of unique Id.
- Avoid dash "-" in Subcircuits Pin Ids.
- Avoid save Backup in read only filesystems.
- Subcircuits fixed (thanks to Sergey Roenko):
74HC42, 74HC74, 74HC75, 74HC151, 74HC155, 74HC192, 74HC93, 74HC393, 74HC592, 74HC4017, 74HC4026, 74HC4033
New Components:
- IC74 (thanks to Sergey Roenko)
74XX01, 74HC73, 74HC76, 74HC107, 74HC109, 74HC112, 74HC113, 74HC173, 74HC175, 74HC259, 74HC373, 74HC374, 74HC375, 74HC377
Как видим, программа развивается, обрастает новыми возможностями.
Качаем, тестим, отписывается.
