16.06.2011, 23:43
Не работает TIC 8148
#include ‹mega16.h›
#include ‹delay.h›
// Standard Input/Output functions
#include ‹stdio.h›
#define DCLC PORTC.3
#define DIN PORTC.2
#define LOAD PORTC.1
// Declare your global variables here
void main(void)
int i,j;
char num[9]={1,1,0,1,1,1,1,0,0};
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
PORTC=0x00;
DDRC=0xFF;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=0xFF
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer1 Stopped
// Mode: Normal top=0xFFFF
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART Receiver: Off
// USART Transmitter: On
// USART Mode: Asynchronous
// USART Baud Rate: 9600
UCSRA=0x00;
UCSRB=0x08;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=0x33;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// ADC initialization
// ADC disabled
ADCSRA=0x00;
// SPI initialization
// SPI disabled
SPCR=0x00;
// TWI initialization
// TWI disabled
TWCR=0x00;
while (1)
LOAD=0;
delay_ms(1);
for(i=0;i‹72;i++)
DIN=0; //ca?eaaai ana naaiaiou
delay_ms(1);
DCLC=0;
delay_ms(1);
DCLC=1;
delay_ms(1);
LOAD=1;
delay_ms(5000);
// Place your code here
//for(i=0;i‹8;i++)
for(j=0;j‹9;j++)
LOAD=0;
delay_ms(1);
DCLC=0;
if (num[j]==1)
{DIN=1;}
else
{DIN=0;}
delay_ms(1);
DCLC=1;
delay_ms(1);
LOAD=1;
delay_ms(5000);
подскажите не могу добиться того чтобы отражало нужную мне цифру. все сегменты могу зажечь, и погасить, а вот чтобы вывести некую цифру не удается. как только один сегмент зажигаю а следующий нет то начинают загораться различные сегменты в чем дело?
20.06.2011, 23:19
Re: Не работает TIC 8148
всем спасибо, тема закрыта, проблема была в последовательности разрядов.
23.01.2017, 00:58
Сказал спасибо: 11,170
А немного времени на разбор своего же исходного кода с комментариями по приведению его в рабочее состояние.
Для упрощения выполнить diff на два варианта и расписать причину и лекарство для сделанных изменений.
Будет полезно будущим поколениям.
23.01.2017, 01:24
Сообщение от mike-y-k
через семь лет? некропостер!
23.01.2017, 02:26
Сказал спасибо: 498
Лучше поздно, чем никогда
Часовой пояс GMT +4, время: 20:13.
