Поиск схем. Делимся схемами Если вы ищете схему телевизора, видеомагнитофона, игровой приставки - этот раздел для вас...
Непрочитано 05.07.2011, 00:13
AIBon
Сказал спасибо: 105
Сказали Спасибо 272 раз(а) в 173 сообщении(ях)
AIBon на пути к лучшему
По умолчанию Re: Альтернативная энергия
Сообщение от Aleksandir Посмотреть сообщение
На эти как раз и прицел.
В Январе этого (2011) года запросил информацию у дочерней компании Боинга
о ячейках C1MJ.
Вот их ответ:
dear sir
Assuming 50 W/cm2 flux and efficiency of 37.5% under 25° C, our 36% cell produces 18.8 W. Since actual operating temperature will be higher, counting on 18 W per cell is a reasonable assumption.
Our most common cell size is the 36% efficiency cell. This is a concentrator cell with dual busbars (the two metal bars on the edge of the solar cell), and an area of 1 cm2. This cell can be purchased in three configurations:
1) Bare cell USD 15 DOLLAR BIG ORDER PER PIECE
minimum 100000 pieces order
A: We have achieved 40.7% conversion efficiency in December 2006. This result was verified independently . This record efficiency was achieved at 240x concentration and 25° C
non-uniform flux, the efficiency will drop and temperature variation could cause reliability issues.
The question of how to cool the cells is up to the CPV system designer.. Typically dense-array modules are actively cooled; whereas point focus systems may be actively or passively cooled.
During assembly, the cells can be exposed to temperatures as high as 300° C for a few minutes. During operation, we suggest maintaining a temperature below 100°C. Higher operating temperatures will reduce the cell efficiency and may jeopardize the lifetime of the cells in the field. Cell performance is a function of temperature. For every 10° C rise in cell temperature, the cell efficiency drops by about 0.5% absolute efficiency. That is, a 38% cell at 25° C will be a 37% cell at 45° C.
payment term 100 % tt
Умножаем 15 у.е. на 100'000 и получаем 1,5 млн. у.е. - минимальная партия заказа.
Вот это серьезный подход к делу, ("бизнесу")!
На мой запрос о двух других вариантах поставки ячеек и о цене для NNNN-ого дистрибьютора и пробных семплах - ни ответа, ни привета.
Вот реквизиты, в надежде - может кому-то повезет больше:
Trelok Suri
Goldengate Solar Tech,
424, 44th avenue, Suite 4,
San Francisco, CA 94121
Office No..415 221 4544
Fax...415 422 0002
Cell...415 310 9267
415 407 5108
А вот вложения к письму:
Миниатюры:
Название: BOEING COMPANY CELLS MODEL NO C1MJ CDO-100 1.jpeg
ID:	23432   Нажмите на изображение для увеличения
Название: BOEING COMPANY CELLS MODEL NO C1MJ CDO-100 2.jpeg
AIBon вне форума
Непрочитано 05.07.2011, 00:37
eleg77
Сказал спасибо: 105
Сказали Спасибо 87 раз(а) в 68 сообщении(ях)
eleg77 на пути к лучшему
на даче стоит квазаровская kv-10 заряжает акумулятор умного дома реально в день при солнце за сутки дает 5-6 ампер часов при 14 вольт пока зарядки хватает с избытком для
ночного освещения ,зарядки мобилки и умного дома (PLC OMRON) прад что будет зимой пока не знаю как основное энергоснабжение не рассматриваеться ибо по моим подсчетам стоимость электроэнергии от фотоэлементов пока очень дорогая 1-1.5гривны (Украина 1квт.час сейчас стоит 0.24 гривны) смысла нет
а вот для нагрева воды использовать вакуумные трубки очень даже выгодно
я себе медный радиатор на крышу ставил под стекло так все лето бойлер даже в розетку не включал
eleg77 вне форума
Непрочитано 05.07.2011, 10:19
Viktorych
Сказал спасибо: 139
Сказали Спасибо 34 раз(а) в 13 сообщении(ях)
Viktorych на пути к лучшему
Сообщение от NOPROBLEM Посмотреть сообщение
В этом вопросе ИМХО все предельно просто: То, что можно посмотреть, послушать, пощупать, померять прямыми или косвенными методами, то реально существует и достойно анализа, изучения, обсуждения и взаимых вопросов. Напротив, то что не имеет реального воплощения не покидает головы безграмотных психов, то пусть там и остается. Обсуждать это можно если только лежишь с ним в одной палате и нет ничего, чем занять вечер...
Такое создается ощущение, что все тут лежат в одной палате...
Валерий.
Последний раз редактировалось Viktorych; 05.07.2011 в 10:21.
Viktorych вне форума
Непрочитано 05.07.2011, 10:48
VladimirIvan
Аватар для VladimirIvan
Сказал спасибо: 7,316
Сказали Спасибо 18,366 раз(а) в 6,406 сообщении(ях)
VladimirIvan на пути к лучшему
Если суммировать чаловекочасы затраченные на рассуждения об альтернативщине, можно давно построить средних размеров электростанцию..
VladimirIvan вне форума
Эти 2 пользователя(ей) сказали Спасибо VladimirIvan за это сообщение:
astral5 (07.07.2011), novo123 (05.07.2011)
Непрочитано 05.07.2011, 12:07
BigElectricCat
BigElectricCat на пути к лучшему
Сообщение от gary2007 Посмотреть сообщение
Они завышают. Возьмем калькулятор, один из модулей, которые они предлагают пусть это будет KV-10
Вы выбрали немного не тот модуль, его основное назначение «Заряд аккумуляторных батарей "12V"», а не построение генерирующих систем.
Возьмите модуль для крыши/стен дома, например такой: K5M165L-N (125х125 мм) — его КПД 15-17%.
С наилучшими пожеланиями…
BigElectricCat вне форума
Непрочитано 05.07.2011, 20:02
fivin07
Аватар для fivin07
Сказал спасибо: 818
Сказали Спасибо 529 раз(а) в 192 сообщении(ях)
fivin07 на пути к лучшему
Сообщение от Viktorych Посмотреть сообщение
Уважаемый не стоит излишне утрировать и так не лёгкую тему... Наполеоны - отдельно, Энштейны - отдельно
fivin07 вне форума
Эти 2 пользователя(ей) сказали Спасибо fivin07 за это сообщение:
makakus (06.07.2011), VladimirIvan (05.07.2011)
Непрочитано 05.07.2011, 21:21
DFedor
Аватар для DFedor
Сказал спасибо: 118
Сказали Спасибо 440 раз(а) в 146 сообщении(ях)
DFedor на пути к лучшему
Сообщение от Ar-Gen-Tum Посмотреть сообщение
Это утверждение не истинно.
Доля УФ в солнечном спектре у поверхности земли весьма не велика.
Основная доля приходится на желто-зеленую часть.
Из Википедии:
В данном случае спектр нам по барабану, зрите в корень! (в тему)
DFedor вне форума
Непрочитано 05.07.2011, 21:26
DFedor
Аватар для DFedor
Сказал спасибо: 118
Сообщение от eleg77 Посмотреть сообщение
Да почему же вакуумные опять? Надеюсь оговорка...
А вот для нагрева как раз ультрафиолет не особо нужен, лучше инфракрас
Ну да на юге летние души так и обогреваются, до 50 градусов легко. (Я сегодня дважды освежался)
DFedor вне форума
Непрочитано 05.07.2011, 23:42
homo_sapiens
Аватар для homo_sapiens
Сказал спасибо: 28
homo_sapiens на пути к лучшему
Да не легкая эта тема. Но ребята давайте не буем валить все в одну кучу. Тепловая энергия это -одно и фото электрическая, это другое. (чуть не сказал фото синтез) _ ЭТО У ЖИВОЙ ПРИРОДЫ. может подойдем и к ней. дай то бог к разумным решениям. Иначе человечество вымрет как динозавры.
homo_sapiens вне форума
Непрочитано 06.07.2011, 01:15
trampampusha
Аватар для trampampusha
Сказал спасибо: 1,450
trampampusha на пути к лучшему
Сообщение от homo_sapiens Посмотреть сообщение
Так ведь тема об альтернативе, а она есть везде, во всех сверах.
В авто например газ, это альтернатива бензину.
Альтернатива?
Альтернатива!
Зажигалка в ряде случаев альтернатива спичкам. А на кухне, у газовой плиты, им альтернатива пьезозажигалка. Это если из быта.
Если из взаимоотношений полов, то любовница - альтернатива жене.
Альтернатива?
trampampusha вне форума
Свободная энергия isosimowo Отвлекитесь, эмбеддеры! 4130 04.10.2018 19:46
Куда уходит энергия в конденсаторах? po3 Электроника - это просто 569 06.11.2011 00:26
Куда уходит энергия в индуктивностях? tauP10 Электроника - это просто 166 10.06.2009 23:16
Куда девается энергия в велотренажере? Russky Отвлекитесь, эмбеддеры! 4 07.03.2009 23:53
[Решено] "Первые на луне" - альтернативная история рус косм avr123-nm-ru Отвлекитесь, эмбеддеры! 1 29.01.2008 15:38
Часовой пояс GMT +4, время: 16:20.
