sID 11 - это ECU Reset. Для него есть следующие resetMode (pID):
Hex Description Cvt Mnemonic
00 reservedByDocument This value is reserved by this document.
01 powerOn This value identifies the power-on reset cycle which shall simulate the reset cycle performed when power is connected to an un-powered server (ECU). When the
server (ECU) performs the reset the client (tester) shall be prepared to reestablish
communication.
02 reservedByDocument This value is reserved by this document.
03 keyOn This value identifies the power-on reset cycle which shall simulate the reset cycle performed at the starter key OFF to DRIVING POSITION switching (ignition
OFF/ON cycle). When the server (ECU) performs the reset the client (tester) shall
be prepared to re-establish communication.
04 - 7F reservedByDocument This range of values is reserved by this document for future definition.
80 sendResetStatus This value shall indicate to the server (ECU) that it shall send the resetStatus parameter in the positive response message.
81 - F9 vehicleManufacturerSpecific This range of values is reserved for vehicle manufacturer specific use.
FA - FE systemSupplierSpecific This range of values is reserved for system supplier specific use.
FF reservedByDocument This value is reserved by this document.
Сообщение от FUZZY_
Идентификатоp запpоса inputOutputControlByLocalIdentifier 0x30
84 10 F1 30 61 07 17 cs ??
В чем именно вопрос? Действительно, 0x30 - inputOutputControlByLocalIdentifier.
