а вот реализация /*
CodeVisionAVR C Compiler
(C) 1998-2007 Pavel Haiduc, HP InfoTech S.R.L.
Dallas Semiconductor DS18B20 1 Wire bus temperature sensor functions
#include ‹delay.h›
#include ‹ds18b20.h›
struct __ds18b20_scratch_pad_struct __ds18b20_scratch_pad;
// temp. conversion time [ms] depending on the resolution
static flash int conv_delay[4]={100,200,400,800};
// valid temp. bit mask depending on the resolution
static flash unsigned bit_mask[4]={0xFFF8,0xFFFC,0xFFFE,0xFFFF};
unsigned char ds18b20_select(unsigned char *addr)
unsigned char i;
if (w1_init()==0) return 0;
if (addr)
w1_write(0x55);
i=0;
do
w1_write(*(addr++));
while (++i‹
else w1_write(0xcc);
return 1;
unsigned char ds18b20_read_spd(unsigned char *addr)
unsigned char i;
unsigned char *p;
if (ds18b20_select(addr)==0) return 0;
w1_write(0xbe);
i=0;
p=(char *) &__ds18b20_scratch_pad;
do
*(p++)=w1_read();
while (++i‹9);
return !w1_dow_crc8(&__ds18b20_scratch_pad,9);
float ds18b20_temperature(unsigned char *addr)
unsigned char resolution;
if (ds18b20_read_spd(addr)==0) return -9999;
resolution=(__ds18b20_scratch_pad.conf_register››5 ) & 3;
if (ds18b20_select(addr)==0) return -9999;
w1_write(0x44);
delay_ms(conv_delay[resolution]);
w1_init();
return (*((int *) &__ds18b20_scratch_pad.temp_lsb) & ((int) bit_mask[resolution]))*0.0625;
unsigned char ds18b20_init(unsigned char *addr,signed char temp_low,signed char temp_high,
unsigned char resolution)
resolution=(resolution‹‹5) | 0x1f;
w1_write(0x4e);
w1_write(temp_high);
w1_write(temp_low);
w1_write(resolution);
if (ds18b20_read_spd(addr)==0) return 0;
if ((__ds18b20_scratch_pad.temp_low!=temp_low) ||
(__ds18b20_scratch_pad.temp_high!=temp_high) ||
(__ds18b20_scratch_pad.conf_register!=resolution)) return 0;
w1_write(0x4
delay_ms(15);
return w1_init();
