19.01.2021, 11:00
#571
Сказал спасибо: 735
Сказали Спасибо 3,835 раз(а) в 2,726 сообщении(ях)
Re: Общие вопросы по программе Multisim
В продолжении того, что я написал. Вот как в HELP LTspice:
B. Arbitrary Behavioral Voltage or Current Sources
abs(x) - Absolute value of x
absdelay(x,t[,tmax]) - x delayed by t. Optional max delay notification tmax.
acos(x) Real part of the arc cosine of x, e.g., acos(-5) returns 3.14159, not 3.14159+2.29243i
arccos(x) - Synonym for acos()
acosh(x) - Real part of the arc hyperbolic cosine of x, e.g., acosh(.5) returns 0, not 1.0472i
asin(x) - Real part of the arc sine of x, asin(-5) is -1.57080, not -1.57080+2.29243i
arcsin(x) - Synonym for asin()
asinh(x) - Arc hyperbolic sine
atan(x) - Arc tangent of x
arctan(x) - Synonym for atan()
atan2(y,x) - Four quadrant arc tangent of y/x
atanh(x) - Arc hyperbolic tangent
buf(x) - 1 if x › .5, else 0
ceil(x) - Integer equal or greater than x
cos(x) - Cosine of x
cosh(x) - Hyperbolic cosine of x
ddt(x) - Time derivative of x
delay(x,t[,tmax] - Same as absdelay()
dnlim(x,y,z) -Similar to max(x,y) but with a continuous 1st derivative transition width z
exp(x) - e to the x
floor(x) - Integer equal to or less than x
hypot(x,y) - sqrt(x**2 + y**2)
idt(x[,ic[,a]]) - Integrate x, optional initial condition ic, reset if a is true.
idtmod(x[,ic[,m[,o]]] -
Integrate x, optional initial condition ic, reset on reaching modulus m, offset output by o.
if(x,y,z) - If x › .5, then y else z
int(x) - Convert x to integer
inv(x) - 0. if x › .5, else 1.
limit(x,y,z) - Intermediate value of x, y, and z
ln(x) - Natural logarithm of x
log(x) - Alternate syntax for ln()
log10(x) - Base 10 logarithm
max(x,y) - The greater of x or y
min(x,y) - The smaller of x or y
pow(x,y) - Real part of x**y, e.g., pow(-1,.5)=0, not i.
pwr(x,y) - abs(x)**y
pwrs(x,y) - sgn(x)*abs(x)**y
rand(x) - Random number between 0 and 1 depending on the integer value of x.
random(x) - Similar to rand(), but smoothly transitions between values.
round(x)- Nearest integer to x
sdt(x[,ic[,assert]]) - Alternate syntax for idt()
sgn(x) - Sign of x
sin(x) - Sine of x
sinh(x) - Hyperbolic sine of x
smallsig() - Returns 1 if a .ac or .noise analysis is being done. Otherwise 0.
sqrt(x) - Square root of x
table(x,a,b,c,d,...) -
Interpolate a value for x based on a look up table given as a set of pairs of points.
tan(x) - Tangent of x.
tanh(x)- Hyperbolic tangent of x
u(x) - Unit step, i.e., 1 if x › 0., else 0.
uplim(x,y,z) - Similar to min(x,y) but with a continuous 1st derivative transition width z
uramp(x) - x if x › 0., else 0.
white(x) -
Random number between -.5 and .5 smoothly transitions between values even more smoothly than random().
!(x) - Alternative syntax for inv(x)
~(x) - Alternative syntax for inv(x)
• The following operations, grouped in reverse order of precedence of evaluation:
& - Convert the expressions to either side to Boolean, then AND.
| - Convert the expressions to either side to Boolean, then OR.
^ - Convert the expressions to either side to Boolean, then XOR
› - True if expression on the left is greater than the expression on the right, otherwise false.
‹ - True if expression on the left is less than the expression on the right, otherwise false.
True if expression on the left is greater than or equal the expression on the right, otherwise false.
True if expression on the left is less than or equal the expression on the right, otherwise false.
+ - Floating point addition
- - Floating point subtraction
* - Floating point multiplication
/ - Floating point division
Raise left hand side to power of right hand side. Only the real part is returned, e.g., -1**1.5 gives zero not i.
! - Convert the following expression to Boolean and invert.
Советую найти в Мультисиме аналогичную таблицу!
Сказали "Спасибо" bordodynov
19.01.2021, 11:34
#572
Сказал спасибо: 735
Вот файл с описанием одной программы с синтаксисом Spice3. Описание управляемых источников тока и напряжения на страницах 50-52. В Мультисиме зачем то добавили фигурные скобки.
19.01.2021, 17:11
#573
Сказал спасибо: 735
Я предложил использовать как диод, а не питать другой диод. Я дома попробую показать вам пример. Сейчас у меня заканчивается работа и я не успеваю.
19.01.2021, 19:11
#574
Сказал спасибо: 735
Вот пример идеализированных диодов. Выведены ВАХи. Для большей наглядности я увеличил крутизну. Катоды заземлены.
19.01.2021, 19:14
#575
Сказал спасибо: 735
Сообщение от tipa
съедобные функции ABM- источника
Если бы вы почитали файл, который я загрузил, а именно страницы 50 - 52, то вам не пришлось бы определять методом тыка допустимые функции. И не придётся гадать как пишутся имена функций.
Мультисим=Spice3+Xspice.
Последний раз редактировалось bordodynov; 19.01.2021 в 19:17.
19.01.2021, 19:22
#576
Сказал спасибо: 241
Сообщение от tipa
задание неправильно понял..
а и к это узлы.попробуйте 1 и 0
Сообщение от tipa
Выцарапанные мультяшные функции...и это, что-ли,- всё?!
Мало?Вы покажите ка эти то,то что есть применить.
С уважением,Сергей.
Последний раз редактировалось mike-y-k; 18.12.2022 в 06:10.
Причина: 6.6
24.01.2021, 16:59
#577
Сказал спасибо: 735
Изучайте если хотите:
26.01.2021, 19:42
#578
Сказал спасибо: 74
Сказали Спасибо 43 раз(а) в 22 сообщении(ях)
Прошу проконсультировать начинающего. При попытке моделировать ГЛИН периодически (я полагаю от источника ~ 17В) появляется ниже осевой линии на экране осцилографа какой-то "выброс". Не могу добиться качественной картинки пилообразного напряжения. Помогите пож.
Последний раз редактировалось Anatoliy563; 26.01.2021 в 19:45.
26.01.2021, 22:50
#579
Сказал спасибо: 735
Сообщение от Anatoliy563
Советую уменьшить максимальный шаг времени. Мультисим грешит большим шагом времени. Видимо разработчики программы таким образом ускоряют счёт. Это может вносить заметные погрешности. Это обмен точности на скорость. Есть и другие способы повысить точность (другие параметры)
26.01.2021, 22:52
#580
Сказал спасибо: 36
Сказали Спасибо 78 раз(а) в 69 сообщении(ях)
Anatoliy563, Вам нужно просто уменьшить максимальный шаг TMAX в параметрах анализа.
Сказали "Спасибо" gena_d07
Часовой пояс GMT +4, время: 21:39.
