unit pdu7bits;
interface
function EncodePDU7bits(const Source: String): String;
function DecodePDU7bits(const CodedStr: String): String;
implementation
procedure Bin2Hex(Buffer, Text: PChar; BufSize: Integer); assembler;
const
Convert: array[0..15] of Char = '0123456789ABCDEF';
p: array[1..7] of Byte = ($1, $3, $7, $F, $1F, $3F, $7F);
var
i, Count: Integer;
c, Tmp, r: Byte;
begin
r:= Byte(Buffer[0]);
Count:= 1;
for i := 0 to BufSize - 1 do
if Count ‹ 8 then
begin
c:= r;
if i ‹ (BufSize - 1) then
begin
Tmp:= Byte(Buffer[I + 1]);
r:= Tmp shr Count;
c:= c or ((Tmp and p[Count]) shl (8 - Count));
Inc(Count);
end;
Text[0] := Convert[c shr 4];
Text[1] := Convert[c and $F];
Inc(Text, 2);
end
else
begin
Count:= 1;
if i ‹ BufSize then
r:= Byte(Buffer[i + 1]);
end;
end;
function Hex2Bin(Text, Buffer: PChar; BufSize: Integer): Integer; assembler;
const
Convert: array['0'..'f'] of SmallInt =
( 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,-1,-1,-1,-1,-1,-1,
-1,10,11,12,13,14,15,-1,-1,-1,-1,-1,-1,-1,-1,-1,
-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,
-1,10,11,12,13,14,15);
p: array[1..7] of Byte = ($7F, $3F, $1F, $F, $7, $3, $1);
var
i, Count: Integer;
Tmp, c, r: Byte;
begin
I := BufSize;
Count:= 1;
while i › 0 do
begin
if not (Text[0] in ['0'..'f']) or not (Text[1] in ['0'..'f']) then Break;
c:= (Convert[Text[0]] shl 4) + Convert[Text[1]];
tmp:= c shr (8 - Count);
c:= c and p[Count];
if Count › 1 then
c:= (c shl (Count - 1)) or r;
r:= Tmp;
Buffer[0] := Char(c);
if Count = 7 then
begin
Inc(Buffer);
Buffer[0] := Char(r);
Count:= 1;
end
else
Inc(Count);
Inc(Buffer);
Inc(Text, 2);
Dec(i);
end;
Result := BufSize - i;
end;
var Leng: Integer;
begin
Leng:= Length(Source);
Leng:= (Leng * 2)- ((Leng div 8) * 2);
SetLength(Result, Leng);
Bin2Hex(PChar(Source), PChar(Result), Length(Source));
end;
var Leng: Integer;
begin
Leng:= Length(CodedStr) div 2;
SetLength(Result, Leng+ (Leng div 7));
Hex2Bin(PChar(CodedStr), PChar(Result), Leng);
end;
end.[/QUOTE]
или так:
[QUOTE]function cnv(s: string):string;
var i: integer;
begin
delete(s,1,1);
if length(s) mod 2›0 then s:=s + 'F';
i:= 1;
while (i‹length(s)+1) do begin
result:= result + s[i+1]+s[i];
inc(i);inc(i)
end
end;
function ucs2(s: string): string;
var i,k: integer;
begin
for i:=1 to length(s) do begin
k:= ord(s[i]);
if k›=192 then k:= k + 1040 - 192;
result:= result + inttohex(k,4)
end
end;
function tcod: string;
begin
if pduf.fsms.Checked then result:= 'F8'
else result:= '08'
end;
function cpdu(ksz,sz,num,msg: string): string;
begin
result:= inttohex(length(sz),2) + // 07=длина номера SMSC
'91' + // 91=интернациональность номера SMSC
cnv(ksz + sz) + // 97103701F0=+790173100 плюс признак окончания номера F
'01' + // 01=PDU Type: MTI=01 -› исходящий SMS
'00' + // 00=MR - параметр, который устанавливается в SMSC
inttohex(length(num)-1,2) + // длина номера получателя-1
'91' + // 91=интернациональность получателя
cnv(num) + // 9710276338F6=+79017236836 - номер получателя
'00' + // 00=PID идентификатор номера протокола
tcod + // F8/08=DCS схема кодирования на экран/вну: кириллическое
inttohex(length(msg)*2,2)+ // длина сообщения
ucs2(msg) // сообщение
end;
procedure Tpduf.tpduClick(Sender: TObject);
begin
if (sz.Text='')and(ksz.Text='') then caption:= ' !!! номер центра будет взят из SIM'
else caption:= ' PDU conversion TEST [Siemens C-35]';
pdu.Text:= cpdu(ksz.Text, sz.Text,num.Text, txt.Text)
end; |
