Definitions for P1 (8 bits), P1.0, and P1.1.
sfr P1 = 0x90; /* SFR for P1 */
sbit P1_0 = P1^0; /* SFR for P1.0 */
sbit P1_1 = P1^1; /* SFR for P1.1 */
MAIN C function
void main (void)
P1_0 = 1; /* Configure P1.0 as an input */
This loop reads P1.0 and writes the value read
to P1.1.
Open the Port 1 Dialog from the Peripherals Menu
and change the value of the P1.0 Pin. When you
set P1.0 LO, P1.1 outputs LO. When you set
P1.0 HI, P1.1 outputs HI.
while (1)
P1_1 = P1_0; /* Copy P1.0 to P1.1 */
