23.12.2007, 23:19
Немогу разобратся с RS-232 и Delphi
Ребят подскажите решение. Проблема:
Короче у мя МК соберает с датчиков (4 штуки) ds1621 показание и мне надо чтоб в прогу поступали данные в обьекты TEdit (их тоже 4 штуки) каждую секунду.
Прогу для контроллера написал.
Помогите плиз
24.12.2007, 00:23
Вот пример из MSDN - с него можно начать:
Monitoring Communications Events
The following example code opens the serial port for overlapped I/O, creates an event mask to monitor CTS and DSR signals, and then waits for an event to occur. The WaitCommEvent function should be executed as an overlapped operation so the other threads of the process cannot perform I/O operations during the wait.
Код:
HANDLE hCom;
OVERLAPPED o;
BOOL fSuccess;
DWORD dwEvtMask;
hCom = CreateFile( "COM1",
GENERIC_READ | GENERIC_WRITE,
0, // exclusive access
NULL, // no security attributes
OPEN_EXISTING,
FILE_FLAG_OVERLAPPED,
NULL
if (hCom == INVALID_HANDLE_VALUE)
// Handle the error.
// We will build on the current configuration, and skip setting the size
// of the input and output buffers with SetupComm.
fSuccess = GetCommState(hCom, &dcb);
if (!fSuccess) {
printf ("GetCommState failed with error %d.
", GetLastError());
return (2);
// Fill in the DCB: baud=57,600 bps, 8 data bits, no parity, and 1 stop bit.
dcb.BaudRate = CBR_57600; // set the baud rate
dcb.ByteSize = 8; // data size, xmit, and rcv
dcb.Parity = NOPARITY; // no parity bit
dcb.StopBits = ONESTOPBIT; // one stop bit
fSuccess = SetCommState(hCom, &dcb);
if (!fSuccess) {
printf ("SetCommState failed with error %d.
", GetLastError());
return (3);
// Set the event mask.
fSuccess = SetCommMask(hCom, EV_CTS | EV_DSR);
if (!fSuccess)
// Create an event object for use in WaitCommEvent.
o.hEvent = CreateEvent(
FALSE, // auto reset event
FALSE, // not signaled
NULL // no name
assert(o.hEvent);
if (WaitCommEvent(hCom, &dwEvtMask, &o))
if (dwEvtMask & EV_DSR)
// To do.
if (dwEvtMask & EV_CTS)
// To do.
он на си, но на дельфи только синтаксис поменять...
это просто вызовы win api.
24.12.2007, 00:33
Сказал спасибо: 37
работа с портами под Win NT и выше осуществляется с помощью API функций, а именно открытие/закрытие, чтение/запись в файл только в место файла имя порта или с помощью драйвера, а подробнее можно почитать Последовательные интерфейсы ПК. Практика программирования
и если поискать то можно еще пару книжек найти
24.12.2007, 00:51
Сказал спасибо: 1,955
Re: Немогу разобратся с RS-232 и Delphi
Сообщение от Kanava
Как я понял - нужен пример работы с RS232 на дельфи.
Тогда идите на .... на http://avr.nikolaew.org/primer4.htm там я как-то выкладывал рабочий пример.
Часовой пояс GMT +4, время: 16:46.
