Сообщение от MisterDi
проект Квартуса можно дать? что-бы не плодить мне своих ошибок При компиляции предупреждения выдает?
Да, конечно! Вот мой проект. Есть подозрение, что отсутствует высокий уровень на сбросе clrn триггеров.
А варнинги следующие:
Warning: Using design file counter.bdf, which is not specified as a design file for the current project, but contains definitions for 1 design units and 1 entities in project
Info: Found entity 1: counter
Warning: Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for details
Критикал варнинг:
Critical Warning: No exact pin location assignment(s) for 7 pins of 7 total pins
Info: Pin q1 not assigned to an exact location on the device
Info: Pin q2 not assigned to an exact location on the device
Info: Pin q3 not assigned to an exact location on the device
Info: Pin q4 not assigned to an exact location on the device
Info: Pin high_level not assigned to an exact location on the device
Info: Pin clk not assigned to an exact location on the device
Info: Pin clrn not assigned to an exact location on the device
Critical Warning: Synopsys Design Constraints File file not found: 'counter.sdc'. A Synopsys Design Constraints File is required by the TimeQuest Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design.
Critical Warning: Timing requirements not met
