Попробуй эту : upa23full.zip
http://www.auto-by.com/forums/index.php?showtopic=1859
Сам не пробовал , но в окне "Programmer" видел функцию "Emulator" (переключатель в правом верхнем углу)
ЗЫ.Чтобы долго не искал как подключать...
The Emulator works under Windows95/98/ME only!
Emulator allows the computer to be used like an EEPROM.
I2C
SCK Input1-4
SDA Input2-3 and Output4-9
Microwire
CLK Input1-4
DI Input2-3
DO Output2-11 and resistor 4.7k connected to Vcc
CS Input4-1
First open a file consisting data of the EEPROM which will be emulated, connect all wires as shown above, start emulator and the end power target device. Emulator may be stopped by pressing the stop button on UPA's PCB. When the protocol is too fast (clock › 100kHz) emulating can not be done.
