Сообщение от chipssss
код ф студию, а не сцылку на лево...
#include ‹tiny13.h›
#include ‹delay.h›
// Declare your global variables here
void main(void)
// Declare your local variables here
// Crystal Oscillator division factor: 1
#pragma optsize-
CLKPR=0x80;
CLKPR=0x00;
#ifdef _OPTIMIZE_SIZE_
#pragma optsize+
#endif
// Input/Output Ports initialization
// Port B initialization
// Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=In
// State5=0 State4=0 State3=0 State2=0 State1=0 State0=P
PORTB=0x01;
DDRB=0x3E;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0A output: Disconnected
// OC0B output: Disconnected
TCCR0A=0x00;
TCCR0B=0x00;
TCNT0=0x00;
OCR0A=0x00;
OCR0B=0x00;
// External Interrupt(s) initialization
// INT0: Off
// Interrupt on any change on pins PCINT0-5: Off
GIMSK=0x00;
MCUCR=0x00;
// Timer/Counter 0 Interrupt(s) initialization
TIMSK0=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
ACSR=0x80;
ADCSRB=0x00;
while (1){
if (!PINB.0){ //Кнопка нажата
PORTB.1 = 1;
delay_ms(1);
PORTB.1 = 0;
delay_ms(19);
else{ //Кнопка отпущена
PORTB.1 = 1;
delay_ms(2);
PORTB.1 = 0;
delay_ms(1
